Can I get simple CAN driver code for MPC5668G?
2,181 次查看
sukruthrameshba
I am using MPC5668G microcontroller. And I need to flash simple CAN driver code with the functionality to send and receive the frames. Can anyone attach the same?
Sukruth.
1,964 次查看
sukruthrameshba
Hello Mr. Petr,
Thanks for your support on CAN Driver code.
I modified the sample code you sent for MPC5668G.
Its working fine for my requirements.
Thank you.
Sukruth
1,964 次查看
sukruthrameshba
Still i am getting a stuff bit error. Please view the attached snap for the error i am getting.
Will the same code work for MPC5668g?
1,964 次查看
PetrS
See https://community.nxp.com/message/667805#comment-667805, I tested it on the EVB and it is running well.
BR, Petr
