Can I get simple CAN driver code for MPC5668G?
2,135件の閲覧回数
sukruthrameshba
I am using MPC5668G microcontroller. And I need to flash simple CAN driver code with the functionality to send and receive the frames. Can anyone attach the same?
Sukruth.
3 返答(返信)
1,918件の閲覧回数
sukruthrameshba
Hello Mr. Petr,
Thanks for your support on CAN Driver code.
I modified the sample code you sent for MPC5668G.
Its working fine for my requirements.
Thank you.
Sukruth
1,918件の閲覧回数
sukruthrameshba
Still i am getting a stuff bit error. Please view the attached snap for the error i am getting.
Will the same code work for MPC5668g?
1,918件の閲覧回数
PetrS
See https://community.nxp.com/message/667805#comment-667805, I tested it on the EVB and it is running well.
BR, Petr
