Assembly problem from S32DS using MPC5744P
金翅大鹏鸟
I built a project which is used to driving the SBC MC33908NAE with MPC5744.I met a problem during building the project.The phenomenon is put in accessory file.Can you help me to solve the problem?Than you
petervlna
it looks like your compiler does not recognize se_li instruction
try replacing it with e_li
regards,
Peter
