ADC wrong reading MPC5748G
1,813件の閲覧回数
medhedibasly
I get wrong reading of voltage from the ADC, for exemple the voltage on the adc pin is 0.720v and the the adc is getting 1.020v
2 返答(返信)
1,658件の閲覧回数
davidtosenovjan
Hi, do you have chosen reference voltage you expect (3.3V/5V) ?
1,657件の閲覧回数
medhedibasly
Thank you for your reply, the issue was related to a hardware implementation on my board, the voltage divider was influenced by the some command signal related to  a transistor that changed the voltage divider gain value used on software.
i corrected the schematic and the problem disappeared.
