Detailed Description:
This config tool simplifies DCF records calculation for MPC5777C device.
Look at HowToUse sheet for simple guideline, then work with DCF sheet
Notes:
- Macros have to be enabled!
- Programming more than 104 DCF records on Cut1.0b will result in incorrect device operation (FCCU faults, SSCM[CER] bit set, etc)
BR, Petr
Hello PetrS ,
The file is not available....
