Example XPC567XRKIT PinToggleStationery CW210
* Detailed Description:
* Application performs basic initialization, setup PLL to maximum allowed freq.,
* initializes interrupts, blinking one LED by interrupt, second LED by software
* loop (by second core), initializes and display notice via UART terminal and
* then terminal ECHO.
* The example configures the device for maximum performance (OPTIMIZATIONS_ON).
* For XPC567XKIT516 it initializes EBI for mounted external SRAM device.
* Test HW:         XPC567XKIT516 - MPC567xADAT516 Rev.D, MPC567XEVBFXMB Rev.C
* MCU:             PPC5676RDMVY1 3N23A
* Terminal:        19200-8-no parity-1 stop bit-no flow control on eSCI_A
* Fsys:            180MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          RAM, internal_FLASH
* EVB connection:  ETPUC0(J24-0) -> USER_LED_8 (J5-8)
*                  ETPUC1(J24-1) -> USER_LED_7 (J5-7)(to see blinking LEDs)
附件
评论
Thank you very much for your demo! I will try my best to study the demo before programming on the device.
Hi David,
thank you for your demo! I've already learned few new things with your code. However, I am having a hard time to compile the entire project. I am using S32, C project, Newlib. I copied your *.h files into `include` and the *.c into `src`. What else? This is the output of the compiler:
make -j8 all
Building file: ../src/main.c
Executing target #7 ../src/main.c
Invoking: Standard S32DS C Compiler
powerpc-eabivle-gcc "@src/main.args" -MMD -MP -MF"src/main.d" -MT"src/main.o" -c -o "src/main.o" "../src/main.c"
In file included from ../src/main.c:65:0:
/home/fab/Projects/gm/quicksilver/testl/testl_Z7_0/include/Exceptions.h:21:0: warning: ignoring #pragma section RX [-Wunknown-pragmas]
 #pragma section RX ".__exception_handlers_p0"
/home/fab/Projects/gm/quicksilver/testl/testl_Z7_0/include/Exceptions.h:26:21: error: expected ')' before string constant
 __declspec (section ".__exception_handlers_p0") void EXCEP_DefaultExceptionHandler(void);
/home/fab/Projects/gm/quicksilver/testl/testl_Z7_0/include/Exceptions.h:44:7: error: expected '(' before 'void'
 __asm void EXCEP_InitExceptionHandlers(void);
In file included from ../src/main.c:66:0:
/home/fab/Projects/gm/quicksilver/testl/testl_Z7_0/include/IntcInterrupts.h:36:7: error: expected '(' before 'void'
 __asm void INTC_InitINTCInterrupts(void);
src/subdir.mk:109: recipe for target 'src/main.o' failed
/home/fab/Projects/gm/quicksilver/testl/testl_Z7_0/include/IntcInterrupts.h:52:0: warning: ignoring #pragma section RX [-Wunknown-pragmas]
/home/fab/Projects/gm/quicksilver/testl/testl_Z7_0/include/IntcInterrupts.h:58:21: error: expected ')' before string constant
 __declspec (section ".__exception_handlers_p0") void INTC_INTCInterruptHandler(void);
In file included from ../src/main.c:67:0:
/home/fab/Projects/gm/quicksilver/testl/testl_Z7_0/include/uart.h:29:2: error: #error _MSL_CONSOLE_SUPPORT must not be defined to 1.
../src/main.c:111:8: error: expected identifier or '(' before 'asm'
 static asm void BranchPredictionEnable(void);
../src/main.c:119:8: error: expected identifier or '(' before 'asm'
 static asm void External_SRAM_MMU_init(void);
../src/main.c: In function 'DisableWatchdog':
../src/main.c:193:5: error: expected '(' before '{' token
../src/main.c:194:9: error: unknown type name 'mfhid0'
         mfhid0  r11       /* Move from spr HID0 to r11 (copies HID0) */
../src/main.c:195:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'li'
         li      r12, 0xBFFF  /* Load immed. data of ~0x4000 to r12 */
../src/main.c:216:13: error: invalid storage class for function 'External_SRAM_init'
 static void External_SRAM_init(void)
../src/main.c: In function 'External_SRAM_init':
../src/main.c:221:5: warning: implicit declaration of function 'External_SRAM_MMU_init' [-Wimplicit-function-declaration]
     External_SRAM_MMU_init();
../src/main.c:305:8: error: expected identifier or '(' before 'asm'
../src/main.c:339:13: error: invalid storage class for function 'eTPU_RAM_init'
 static void eTPU_RAM_init(void)
../src/main.c: In function 'eTPU_RAM_init':
../src/main.c:355:5: error: expected '(' before '{' token
../src/main.c:356:9: error: unknown type name 'lis'
         lis r3, 0x1004
../src/main.c:356:17: error: expected identifier or '(' before numeric constant
         lis r3, 0x1004
../src/main.c:356:13: warning: unused variable 'r3' [-Wunused-variable]
         lis r3, 0x1004
../src/main.c:413:13: error: invalid storage class for function 'FMPLL_init'
 static void FMPLL_init(void)
../src/main.c:441:13: error: invalid storage class for function 'GPIO_init'
 static void GPIO_init(void)
../src/main.c:464:13: error: invalid storage class for function 'PIT3_isr'
 static void PIT3_isr(void)
../src/main.c:484:13: error: invalid storage class for function 'PIT3_init'
 static void PIT3_init(void)
../src/main.c:512:13: error: invalid storage class for function 'Interrupts_init'
 static void Interrupts_init(void)
../src/main.c:535:13: error: invalid storage class for function 'Terminal_ECHO'
 static void Terminal_ECHO(void)
../src/main.c:576:5: warning: 'main' is normally a non-static function [-Wmain]
 int main(void)
../src/main.c: In function 'main':
../src/main.c:578:22: warning: unused variable 'cnt' [-Wunused-variable]
     register int32_t cnt = 0;
../src/main.c:608:1: error: expected declaration or statement at end of input
../src/main.c: At top level:
../src/main.c:113:13: warning: 'FMPLL_init' used but never defined
 static void FMPLL_init(void);
../src/main.c:117:13: warning: 'eTPU_RAM_init' used but never defined
 static void eTPU_RAM_init(void);
../src/main.c:118:13: warning: 'External_SRAM_init' used but never defined
 static void External_SRAM_init(void);
../src/main.c:112:13: warning: 'GPIO_init' declared 'static' but never defined [-Wunused-function]
 static void GPIO_init(void);
../src/main.c:114:13: warning: 'Interrupts_init' declared 'static' but never defined [-Wunused-function]
 static void Interrupts_init(void);
../src/main.c:115:13: warning: 'PIT3_isr' declared 'static' but never defined [-Wunused-function]
 static void PIT3_isr(void);
../src/main.c:116:13: warning: 'PIT3_init' declared 'static' but never defined [-Wunused-function]
 static void PIT3_init(void);
../src/main.c:120:13: warning: 'Terminal_ECHO' declared 'static' but never defined [-Wunused-function]
 static void Terminal_ECHO(void);
make: *** [src/main.o] Error 1
17:13:53 Build Finished (took 322ms)
Can you help me with this? I would like to be able to use the UART for a very important project we are working on.
Fab
Hi, pay attention to following link:
https://community.nxp.com/docs/DOC-335330
Colleagues ported some of our PinToggleStationery example project into S32DS environment.
Hope it helps
%3CLINGO-SUB%20id%3D%22lingo-sub-1111079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20XPC567XRKIT%20PinToggleStationery%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E*%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%89%A7%E8%A1%8C%E5%9F%BA%E6%9C%AC%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C%E5%B0%86%20PLL%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9C%80%E5%A4%A7%E5%85%81%E8%AE%B8%E9%A2%91%E7%8E%87%EF%BC%8C%3C%2FP%3E%3CP%3E*%20%E5%88%9D%E5%A7%8B%E5%8C%96%E4%B8%AD%E6%96%AD%EF%BC%8C%E9%80%9A%E8%BF%87%E4%B8%AD%E6%96%AD%E9%97%AA%E7%83%81%E4%B8%80%E4%B8%AA%20LED%EF%BC%8C%E9%80%9A%E8%BF%87%E8%BD%AF%E4%BB%B6%E9%97%AA%E7%83%81%E7%AC%AC%E4%BA%8C%E4%B8%AA%20LED%3C%2FP%3E%3CP%3E*%20%E5%BE%AA%E7%8E%AF%EF%BC%88%E7%94%B1%E7%AC%AC%E4%BA%8C%E4%B8%AA%E6%A0%B8%E5%BF%83%EF%BC%89%EF%BC%8C%E5%88%9D%E5%A7%8B%E5%8C%96%E5%B9%B6%E9%80%9A%E8%BF%87%20UART%20%E7%BB%88%E7%AB%AF%E6%98%BE%E7%A4%BA%E9%80%9A%E7%9F%A5%E5%92%8C%3C%2FP%3E%3CP%3E*%20%E7%84%B6%E5%90%8E%E6%98%AF%E7%BB%88%E7%AB%AF%20ECHO%E3%80%82%3C%2FP%3E%3CP%3E*%20%E8%AF%A5%E7%A4%BA%E4%BE%8B%E5%B0%86%E8%AE%BE%E5%A4%87%E9%85%8D%E7%BD%AE%E4%B8%BA%E5%AE%9E%E7%8E%B0%E6%9C%80%E4%BD%B3%E6%80%A7%E8%83%BD%EF%BC%88OPTIMIZATIONS_ON%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E*%20%E5%AF%B9%E4%BA%8E%20XPC567XKIT516%EF%BC%8C%E5%AE%83%E4%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%E5%A4%96%E9%83%A8%20SRAM%20%E8%AE%BE%E5%A4%87%E7%9A%84%20EBI%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20XPC567XKIT516%20-%20MPC567xADAT516%20Rev.D%2C%20MPC567XEVBFXMB%20Rev.C%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5676RDMVY1%203N23A%3C%2FP%3E%3CP%3E*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%20%E5%81%9C%E6%AD%A2%E4%BD%8D-eSCI_A%20%E4%B8%8A%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%3C%2FP%3E%3CP%3E*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%EF%BC%9A180MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9ARAM%E3%80%81internal_FLASH%3C%2FP%3E%3CP%3E*%20EVB%20%E8%BF%9E%E6%8E%A5%EF%BC%9AETPUC0(J24-0)%20-%26gt%3B%20USER_LED_8%20(J5-8)%3C%2FP%3E%3CP%3E*%20ETPUC1(J24-1)%20-%26gt%3B%20USER_LED_7%20(J5-7)%EF%BC%88%E6%9F%A5%E7%9C%8B%E9%97%AA%E7%83%81%E7%9A%84%20LED%EF%BC%89%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1111079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E*%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%89%A7%E8%A1%8C%E5%9F%BA%E6%9C%AC%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C%E5%B0%86%20PLL%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E6%9C%80%E5%A4%A7%E5%85%81%E8%AE%B8%E9%A2%91%E7%8E%87%EF%BC%8C%3C%2FP%3E%3CP%3E*%20%E5%88%9D%E5%A7%8B%E5%8C%96%E4%B8%AD%E6%96%AD%EF%BC%8C%E9%80%9A%E8%BF%87%E4%B8%AD%E6%96%AD%E9%97%AA%E7%83%81%E4%B8%80%E4%B8%AA%20LED%EF%BC%8C%E9%80%9A%E8%BF%87%E8%BD%AF%E4%BB%B6%E9%97%AA%E7%83%81%E7%AC%AC%E4%BA%8C%E4%B8%AA%20LED%3C%2FP%3E%3CP%3E*%20%E5%BE%AA%E7%8E%AF%EF%BC%88%E7%94%B1%E7%AC%AC%E4%BA%8C%E4%B8%AA%E6%A0%B8%E5%BF%83%EF%BC%89%EF%BC%8C%E5%88%9D%E5%A7%8B%E5%8C%96%E5%B9%B6%E9%80%9A%E8%BF%87%20UART%20%E7%BB%88%E7%AB%AF%E6%98%BE%E7%A4%BA%E9%80%9A%E7%9F%A5%E5%92%8C%3C%2FP%3E%3CP%3E*%20%E7%84%B6%E5%90%8E%E6%98%AF%E7%BB%88%E7%AB%AF%20ECHO%E3%80%82%3C%2FP%3E%3CP%3E*%20%E8%AF%A5%E7%A4%BA%E4%BE%8B%E5%B0%86%E8%AE%BE%E5%A4%87%E9%85%8D%E7%BD%AE%E4%B8%BA%E5%AE%9E%E7%8E%B0%E6%9C%80%E4%BD%B3%E6%80%A7%E8%83%BD%EF%BC%88OPTIMIZATIONS_ON%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E*%20%E5%AF%B9%E4%BA%8E%20XPC567XKIT516%EF%BC%8C%E5%AE%83%E4%BC%9A%E5%88%9D%E5%A7%8B%E5%8C%96%E5%B7%B2%E5%AE%89%E8%A3%85%E7%9A%84%E5%A4%96%E9%83%A8%20SRAM%20%E8%AE%BE%E5%A4%87%E7%9A%84%20EBI%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20XPC567XKIT516%20-%20MPC567xADAT516%20Rev.D%2C%20MPC567XEVBFXMB%20Rev.C%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5676RDMVY1%203N23A%3C%2FP%3E%3CP%3E*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%20%E5%81%9C%E6%AD%A2%E4%BD%8D-eSCI_A%20%E4%B8%8A%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%3C%2FP%3E%3CP%3E*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%EF%BC%9A180MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9ARAM%E3%80%81internal_FLASH%3C%2FP%3E%3CP%3E*%20EVB%20%E8%BF%9E%E6%8E%A5%EF%BC%9AETPUC0(J24-0)%20-%26gt%3B%20USER_LED_8%20(J5-8)%3C%2FP%3E%3CP%3E*%20ETPUC1(J24-1)%20-%26gt%3B%20USER_LED_7%20(J5-7)%EF%BC%88%E6%9F%A5%E7%9C%8B%E9%97%AA%E7%83%81%E7%9A%84%20LED%EF%BC%89%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1111079%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111082%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20XPC567XRKIT%20PinToggleStationery%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111082%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%AF%B7%E5%85%B3%E6%B3%A8%E4%BB%A5%E4%B8%8B%E9%93%BE%E6%8E%A5%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335330%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-335330%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%8C%E4%BA%8B%E5%B0%86%E6%88%91%E4%BB%AC%E7%9A%84%E4%B8%80%E4%BA%9B%20PinToggleStationery%20%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E7%A7%BB%E6%A4%8D%E5%88%B0%20S32DS%20%E7%8E%AF%E5%A2%83%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E6%9C%89%E5%B8%AE%E5%8A%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20XPC567XRKIT%20PinToggleStationery%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111081%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20David%2C%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%BC%94%E7%A4%BA%EF%BC%81%E6%88%91%E5%B7%B2%E7%BB%8F%E9%80%9A%E8%BF%87%E4%BD%A0%E7%9A%84%E4%BB%A3%E7%A0%81%E5%AD%A6%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%E6%96%B0%E4%B8%9C%E8%A5%BF%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E6%88%91%E5%BE%88%E9%9A%BE%E7%BC%96%E8%AF%91%E6%95%B4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20S32%E3%80%81C%20%E9%A1%B9%E7%9B%AE%E3%80%81Newlib%E3%80%82%E6%88%91%E5%B0%86%E6%82%A8%E7%9A%84%20*.h%20%E6%96%87%E4%BB%B6%E5%A4%8D%E5%88%B6%E5%88%B0%E2%80%9Cinclude%E2%80%9D%E4%B8%AD%EF%BC%8C%E5%B9%B6%E5%B0%86%20*.c%20%E5%A4%8D%E5%88%B6%E5%88%B0%E2%80%9Csrc%E2%80%9D%E4%B8%AD%E3%80%82%E8%BF%98%E6%9C%89%E4%BB%80%E4%B9%88%EF%BC%9F%E8%BF%99%E6%98%AF%E7%BC%96%E8%AF%91%E5%99%A8%E7%9A%84%E8%BE%93%E5%87%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CBLOCKQUOTE%20class%3D%22jive_macro_quote%20jive-quote%20jive_text_macro%22%3E%3CP%3E%E5%85%A8%E9%83%A8%E5%88%B6%E4%BD%9C-j8%3CBR%20%2F%3E%E6%9E%84%E5%BB%BA%E6%96%87%E4%BB%B6%EF%BC%9A..%2Fsrc%2Fmain.c%3CBR%20%2F%3E%E6%89%A7%E8%A1%8C%E7%9B%AE%E6%A0%87%20%237%20..%2Fsrc%2Fmain.c%3CBR%20%2F%3E%E8%B0%83%E7%94%A8%EF%BC%9A%E6%A0%87%E5%87%86S32DS%20C%E7%BC%96%E8%AF%91%E5%99%A8%3CBR%20%2F%3Epowerpc-eabivle-gcc%E2%80%9C%40src%2Fmain.args%E2%80%9D-MMD%20-MP%20-MF%E2%80%9Csrc%2Fmain.d%E2%80%9D-MT%E2%80%9Csrc%2Fmain.o%E2%80%9D-c%20-o%E2%80%9Csrc%2Fmain.o%E2%80%9D%E2%80%9C..%2Fsrc%2Fmain.c%E2%80%9D%3CBR%20%2F%3E%E5%9C%A8%E5%8C%85%E5%90%AB%E4%BA%8E..%2Fsrc%2Fmain.c%3A65%3A0%20%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20%2Fhome%2Ffab%2FProjects%2Fgm%2Fquicksilver%2Ftestl%2Ftestl_Z7_0%2Finclude%2FExceptions.h%3A21%3A0%3A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%BF%BD%E7%95%A5%23pragma%20section%20RX%20%5B-Wunknown-pragmas%5D%3CBR%20%2F%3E%20%23pragma%20%E9%83%A8%E5%88%86%20RX%20%22.__exception_handlers_p0%22%3CBR%20%2F%3E%5E%3CBR%20%2F%3E%20%2Fhome%2Ffab%2FProjects%2Fgm%2Fquicksilver%2Ftestl%2Ftestl_Z7_0%2Finclude%2FExceptions.h%3A26%3A21%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%AD%97%E7%AC%A6%E4%B8%B2%E5%B8%B8%E9%87%8F%E5%89%8D%E5%BA%94%E4%B8%BA%E2%80%9C)%E2%80%9D%3CBR%20%2F%3E%20__declspec%20(section%20%22.__%20exception_handlers_p0%22)%20void%20EXCEP_DefaultExceptionHandler(void)%3B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20%2Fhome%2Ffab%2FProjects%2Fgm%2Fquicksilver%2Ftestl%2Ftestl_Z7_0%2Finclude%2FExceptions.h%3A44%3A7%3A%E9%94%99%E8%AF%AF%EF%BC%9A'void'%20%E4%B9%8B%E5%89%8D%E5%BA%94%E4%B8%BA%20'('%3CBR%20%2F%3E%20__asm%20void%20EXCEP_InitException%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%EF%BC%88void%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%E5%9C%A8%E5%8C%85%E5%90%AB%E4%BA%8E..%2Fsrc%2Fmain.c%3A66%3A0%20%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20%2Fhome%2Ffab%2FProjects%2Fgm%2Fquicksilver%2Ftestl%2Ftestl_Z7_0%2Finclude%2FIntcInterrupts.h%3A36%3A7%3A%E9%94%99%E8%AF%AF%EF%BC%9A'void'%20%E4%B9%8B%E5%89%8D%E5%BA%94%E4%B8%BA%20'('%3CBR%20%2F%3E%20__asm%20void%20INTC_InitINTCInterrupts(void)%3B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20src%2Fsubdir.mk%3A109%EF%BC%9A%E7%9B%AE%E6%A0%87%E2%80%98src%2Fmain.o%E2%80%99%E7%9A%84%E9%85%8D%E6%96%B9%E5%A4%B1%E8%B4%A5%E7%9A%84%3CBR%20%2F%3E%2Fhome%2Ffab%2FProjects%2Fgm%2Fquicksilver%2Ftestl%2Ftestl_Z7_0%2Finclude%2FIntcInterrupts.h%3A52%3A0%3A%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%BF%BD%E7%95%A5%23pragma%20section%20RX%20%5B-Wunknown-pragmas%5D%3CBR%20%2F%3E%20%23pragma%20%E9%83%A8%E5%88%86%20RX%20%22.__exception_handlers_p0%22%3CBR%20%2F%3E%5E%3CBR%20%2F%3E%20%2Fhome%2Ffab%2FProjects%2Fgm%2Fquicksilver%2Ftestl%2Ftestl_Z7_0%2Finclude%2FIntcInterrupts.h%3A58%3A21%3A%E9%94%99%E8%AF%AF%EF%BC%9A%E5%AD%97%E7%AC%A6%E4%B8%B2%E5%B8%B8%E9%87%8F%E5%89%8D%E5%BA%94%E4%B8%BA%E2%80%9C)%E2%80%9D%3CBR%20%2F%3E%20__declspec%20(section%20%22.__%20exception_handlers_p0%22)%20void%20INTC_INTCInterruptHandler(void)%3B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%E5%9C%A8%E5%8C%85%E5%90%AB%E4%BA%8E..%2Fsrc%2Fmain.c%3A67%3A0%20%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20%2Fhome%2Ffab%2FProjects%2Fgm%2Fquicksilver%2Ftestl%2Ftestl_Z7_0%2Finclude%2Fuart.h%3A29%3A2%3A%E9%94%99%E8%AF%AF%EF%BC%9A%23error%20_MSL_CONSOLE_SUPPORT%20%E4%B8%8D%E8%83%BD%E5%AE%9A%E4%B9%89%E4%B8%BA%201%E3%80%82%3CBR%20%2F%3E%20%23error%20_MSL_CONSOLE_SUPPORT%20%E4%B8%8D%E8%83%BD%E5%AE%9A%E4%B9%89%E4%B8%BA%201%E3%80%82%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A111%3A8%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%98asm%E2%80%99%20%E4%B9%8B%E5%89%8D%E5%BA%94%E6%9C%89%E6%A0%87%E8%AF%86%E7%AC%A6%E6%88%96%E2%80%98(%E2%80%99%3CBR%20%2F%3E%E9%9D%99%E6%80%81%20asm%20void%20BranchPredictionEnable(void)%3B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A119%3A8%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%98asm%E2%80%99%20%E4%B9%8B%E5%89%8D%E5%BA%94%E6%9C%89%E6%A0%87%E8%AF%86%E7%AC%A6%E6%88%96%E2%80%98(%E2%80%99%3CBR%20%2F%3E%E9%9D%99%E6%80%81%20asm%20void%20External_SRAM_MMU_init(void)%3B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%98DisableWatchdog%E2%80%99%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A193%3A5%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E9%A2%84%E6%9C%9F%E2%80%9C(%E2%80%9D%E5%9C%A8%E2%80%9C%7B%E2%80%9D%E6%A0%87%E8%AE%B0%E4%B9%8B%E5%89%8D%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A194%3A9%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E7%9F%A5%E7%B1%BB%E5%9E%8B%E5%90%8D%E7%A7%B0%E2%80%9Cmfhid0%E2%80%9D%3CBR%20%2F%3E%20mfhid0%20r11%20%2F*%20%E4%BB%8E%20spr%20HID0%20%E7%A7%BB%E5%8A%A8%E5%88%B0%20r11%EF%BC%88%E5%A4%8D%E5%88%B6%20HID0%EF%BC%89*%2F%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A195%3A9%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%9C%A8%20'li'%20%E4%B9%8B%E5%89%8D%E5%BA%94%E4%B8%BA%20'%3D'%E3%80%81'%2C'%E3%80%81'%3B'%E3%80%81'asm'%20%E6%88%96%20'%20__attribute__%20'%3CBR%20%2F%3E%20li%20r12%2C%200xBFFF%20%2F*%20%E7%AB%8B%E5%8D%B3%E5%8A%A0%E8%BD%BD%E3%80%82~0x4000%20%E7%9A%84%E6%95%B0%E6%8D%AE%E5%88%B0%20r12%20*%2F%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A216%3A13%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E2%80%98External_SRAM_init%E2%80%99%E7%9A%84%E5%AD%98%E5%82%A8%E7%B1%BB%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20External_SRAM_init%EF%BC%88void%EF%BC%89%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%98External_SRAM_init%E2%80%99%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A221%3A5%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E5%87%BD%E6%95%B0%E2%80%98External_SRAM_MMU_init%E2%80%99%E7%9A%84%E9%9A%90%E5%BC%8F%E5%A3%B0%E6%98%8E%20%5B-Wimplicit-function-declaration%5D%3CBR%20%2F%3E%E5%A4%96%E9%83%A8_SRAM_MMU_%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%98DisableWatchdog%E2%80%99%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A305%3A8%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%98asm%E2%80%99%20%E4%B9%8B%E5%89%8D%E5%BA%94%E6%9C%89%E6%A0%87%E8%AF%86%E7%AC%A6%E6%88%96%E2%80%98(%E2%80%99%3CBR%20%2F%3E%E9%9D%99%E6%80%81%20asm%20void%20External_SRAM_MMU_init(void)%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A339%3A13%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E2%80%98eTPU_RAM_init%E2%80%99%E7%9A%84%E5%AD%98%E5%82%A8%E7%B1%BB%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20eTPU_RAM_init%EF%BC%88void%EF%BC%89%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%98eTPU_RAM_init%E2%80%99%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A355%3A5%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E9%A2%84%E6%9C%9F%E2%80%9C(%E2%80%9D%E5%9C%A8%E2%80%9C%7B%E2%80%9D%E6%A0%87%E8%AE%B0%E4%B9%8B%E5%89%8D%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A356%3A9%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E7%9F%A5%E7%B1%BB%E5%9E%8B%E5%90%8D%E7%A7%B0%E2%80%9Clis%E2%80%9D%3CBR%20%2F%3E%20lis%20r3%2C%200x1004%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A356%3A17%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%95%B0%E5%AD%97%E5%B8%B8%E9%87%8F%E5%89%8D%E5%BA%94%E6%9C%89%E6%A0%87%E8%AF%86%E7%AC%A6%E6%88%96%E2%80%9C(%E2%80%9D%3CBR%20%2F%3E%20lis%20r3%2C%200x1004%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A356%3A13%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8F%98%E9%87%8F%E2%80%9Cr3%E2%80%9D%5B-Wunused-variable%5D%3CBR%20%2F%3E%20lis%20r3%2C%200x1004%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A413%3A13%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E2%80%9CFMPLL_init%E2%80%9D%E7%9A%84%E5%AD%98%E5%82%A8%E7%B1%BB%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20FMPLL_init%EF%BC%88void%EF%BC%89%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A441%3A13%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E2%80%98GPIO_init%E2%80%99%E7%9A%84%E5%AD%98%E5%82%A8%E7%B1%BB%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20GPIO_init%EF%BC%88void%EF%BC%89%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A464%3A13%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E2%80%9CPIT3_isr%E2%80%9D%E7%9A%84%E5%AD%98%E5%82%A8%E7%B1%BB%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20PIT3_isr%EF%BC%88void%EF%BC%89%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A484%3A13%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E2%80%9CPIT3_init%E2%80%9D%E7%9A%84%E5%AD%98%E5%82%A8%E7%B1%BB%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20PIT3_init%EF%BC%88void%EF%BC%89%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A512%3A13%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E2%80%9CInterrupts_init%E2%80%9D%E7%9A%84%E5%AD%98%E5%82%A8%E7%B1%BB%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20Interrupts_init%EF%BC%88void%EF%BC%89%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A535%3A13%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E5%87%BD%E6%95%B0%E2%80%9CTerminal_ECHO%E2%80%9D%E7%9A%84%E5%AD%98%E5%82%A8%E7%B1%BB%E6%97%A0%E6%95%88%3CBR%20%2F%3E%E9%9D%99%E6%80%81%E6%97%A0%E6%95%88%E7%BB%88%E7%AB%AF_ECHO%EF%BC%88%E6%97%A0%E6%95%88%EF%BC%89%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A576%3A5%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A'main'%20%E9%80%9A%E5%B8%B8%E6%98%AF%E9%9D%9E%E9%9D%99%E6%80%81%E5%87%BD%E6%95%B0%20%5B-Wmain%5D%3CBR%20%2F%3E%20int%20main%EF%BC%88%E7%A9%BA%EF%BC%89%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%9Cmain%E2%80%9D%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A578%3A22%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8F%98%E9%87%8F%E2%80%9Ccnt%E2%80%9D%5B-Wunused-variable%5D%3CBR%20%2F%3E%E6%B3%A8%E5%86%8Cint32_t%20cnt%20%3D%200%3B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%98eTPU_RAM_init%E2%80%99%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A608%3A1%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E8%BE%93%E5%85%A5%E6%9C%AB%E5%B0%BE%E5%BA%94%E6%9C%89%E5%A3%B0%E6%98%8E%E6%88%96%E8%AF%AD%E5%8F%A5%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%E2%80%98DisableWatchdog%E2%80%99%E4%B8%AD%EF%BC%9A%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A608%3A1%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E8%BE%93%E5%85%A5%E6%9C%AB%E5%B0%BE%E5%BA%94%E6%9C%89%E5%A3%B0%E6%98%8E%E6%88%96%E8%AF%AD%E5%8F%A5%3CBR%20%2F%3E..%2Fsrc%2Fmain.c%EF%BC%9A%E5%9C%A8%E9%A1%B6%E5%B1%82%EF%BC%9A%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A113%3A13%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E2%80%98FMPLL_init%E2%80%99%E5%B7%B2%E4%BD%BF%E7%94%A8%E4%BD%86%E4%BB%8E%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20FMPLL_init%EF%BC%88void%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A117%3A13%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E2%80%98eTPU_RAM_init%E2%80%99%E5%B7%B2%E4%BD%BF%E7%94%A8%E4%BD%86%E4%BB%8E%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20eTPU_RAM_init%EF%BC%88void%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A118%3A13%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A%E2%80%98External_SRAM_init%E2%80%99%E5%B7%B2%E4%BD%BF%E7%94%A8%E4%BD%86%E4%BB%8E%E6%9C%AA%E5%AE%9A%E4%B9%89%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20External_SRAM_init%EF%BC%88void%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A112%3A13%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A'GPIO_init'%20%E5%A3%B0%E6%98%8E%E4%B8%BA%20'static'%20%E4%BD%86%E4%BB%8E%E6%9C%AA%E5%AE%9A%E4%B9%89%20%5B-Wunused-function%5D%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20GPIO_init%EF%BC%88void%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A114%3A13%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A'Interrupts_init'%20%E5%A3%B0%E6%98%8E%E4%B8%BA%20'static'%20%E4%BD%86%E4%BB%8E%E6%9C%AA%E5%AE%9A%E4%B9%89%20%5B-Wunused-function%5D%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20Interrupts_init%EF%BC%88void%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A115%3A13%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A'PIT3_isr'%20%E5%A3%B0%E6%98%8E%E4%B8%BA%20'static'%20%E4%BD%86%E4%BB%8E%E6%9C%AA%E5%AE%9A%E4%B9%89%20%5B-Wunused-function%5D%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20PIT3_isr%EF%BC%88void%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A116%3A13%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A'PIT3_init'%20%E5%A3%B0%E6%98%8E%E4%B8%BA'%E9%9D%99%E6%80%81'%E4%BD%86%E4%BB%8E%E6%9C%AA%E5%AE%9A%E4%B9%89%20%5B-Wunused-function%5D%3CBR%20%2F%3E%E9%9D%99%E6%80%81void%20PIT3_init%EF%BC%88void%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%20..%2Fsrc%2Fmain.c%3A120%3A13%3A%20%E8%AD%A6%E5%91%8A%EF%BC%9A'Terminal_ECHO'%20%E5%A3%B0%E6%98%8E%E4%B8%BA%20'static'%20%E4%BD%86%E4%BB%8E%E6%9C%AA%E5%AE%9A%E4%B9%89%20%5B-Wunused-function%5D%3CBR%20%2F%3E%E9%9D%99%E6%80%81%E6%97%A0%E6%95%88%E7%BB%88%E7%AB%AF_ECHO%EF%BC%88void%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%20%5E%3CBR%20%2F%3E%E5%88%B6%E4%BD%9C%EF%BC%9A***%20%5Bsrc%2Fmain.o%5D%E9%94%99%E8%AF%AF%201%3CBR%20%2F%3E%3CBR%20%2F%3E%2017%3A13%3A53%20%E6%9E%84%E5%BB%BA%E5%AE%8C%E6%88%90%EF%BC%88%E8%80%97%E6%97%B6%20322%20%E6%AF%AB%E7%A7%92%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E5%90%97%EF%BC%9F%E6%88%91%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%A4%9F%E5%B0%86%20UART%20%E7%94%A8%E4%BA%8E%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E8%BF%9B%E8%A1%8C%E7%9A%84%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E9%87%8D%E8%A6%81%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EFab%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1111080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20XPC567XRKIT%20PinToggleStationery%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1111080%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%BC%94%E7%A4%BA%EF%BC%81%E6%88%91%E5%B0%86%E5%9C%A8%E8%AE%BE%E5%A4%87%E4%B8%8A%E7%BC%96%E7%A8%8B%E4%B9%8B%E5%89%8D%E5%B0%BD%E5%8A%9B%E7%A0%94%E7%A9%B6%E8%AF%A5%E6%BC%94%E7%A4%BA%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎11-07-2014 06:35 AM
更新人:
