Example MPC5777M PIT ISR GHS614
* Detailed Description:
* PIT channel 0 is used to generate 1sec interrupt where PA0 pin is toggled.
* Test HW:  MPC5777M, MPC57xx Motherboard + MPC5777M_512DS minimodule
* Maskset:  0N78H
* Target :  RAM, internal_FLASH
* Fsys:     600 MHz PLL1 with 40 MHz crystal reference
*               core2 at 200MHz generated from PPL1
* Terminal: None
%3CLINGO-SUB%20id%3D%22lingo-sub-1105210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5777M%20PIT%20ISR%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20PIT%20channel%200%20is%20used%20to%20generate%201sec%20interrupt%20where%20PA0%20pin%20is%20toggled.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%20MPC5777M%2C%20MPC57xx%20Motherboard%20%2B%20MPC5777M_512DS%20minimodule%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%200N78H%3C%2FP%3E%3CP%3E*%20Target%20%3A%26nbsp%3B%20RAM%2C%20internal_FLASH%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20600%20MHz%20PLL1%20with%2040%20MHz%20crystal%20reference%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20core2%20at%20200MHz%20generated%20from%20PPL1%3C%2FP%3E%3CP%3E*%20Terminal%3A%20None%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1105210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎02-11-2016 05:01 AM
Updated by:
