Example MPC5777M MCAN simple TX/RX GHS614
* Detailed Description:
* Configures the MCANs to transmit and receive a CAN message.
* In this config, MCAN_1 transmits a message. MCAN_2 receives the message.
* MCAN_1 sends message each 1sec. This interval is generated by PIT.
* Single TX buffer is used to send n bytes. The message ID is changed for each
* transmission. Two standard and 2 extended IDs are sent.
* MCAN_2 is configured to receive a message, SW polling is used.
* There are 2 standard and 2 extended ID filter tables defined. Classic filter
* configuration is set, means filter ID & mask.
* Messages with matched standard ID are received into RXFIFO_0, messages with matched
* extended ID then stored in RXFIFO_1.
* EVB connection:
* J37 and J38 to position 1-2 to connect MCAN1 TX/RX to transceiver
* CAN0-CANH on P15-1 to CAN1-CANH on P14-1
* CAN0-CANL on P15-2 to CAN1-CANL on P14-2
* Test HW:  MPC5777M, MPC57xx Motherboard + MPC5777M_512DS minimodule
* Maskset:  0N78H
* Target :  internal_FLASH
* Fsys:     600 MHz PLL1 with 40 MHz crystal reference,
*        core2 at 200MHz generated from PPL1
* Terminal: None
Revision History:
1.0     Jan-5-2017     PetrS    Initial Version of MCAN example
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1125575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8BMPC5777M%20MCAN%20%E3%82%B7%E3%83%B3%E3%83%97%E3%83%AB%20TX%2FRX%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1125575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E*%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%3A%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20MCAN%20%E3%81%8C%20CAN%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20%3CBR%20%2F%3E*%20%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81MCAN_1%20%E3%81%8C%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MCAN_2%20%E3%81%AF%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20MCAN_1%201%20%E7%A7%92%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E9%96%93%E9%9A%94%E3%81%AF%20PIT%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20%E5%8D%98%E4%B8%80%E3%81%AETX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6n%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%20ID%20%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%E6%84%9F%E6%9F%93%E3%80%822%20%E3%81%A4%E3%81%AE%E6%A8%99%E6%BA%96%20ID%20%E3%81%A8%202%20%E3%81%A4%E3%81%AE%E6%8B%A1%E5%BC%B5%20ID%20%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%E2%80%BB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E8%A8%AD%E5%AE%9AMCAN_2%E3%80%81SW%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%202%20%E3%81%A4%E3%81%AE%E6%A8%99%E6%BA%96%20ID%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A8%202%20%E3%81%A4%E3%81%AE%E6%8B%A1%E5%BC%B5%20ID%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AF%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3CBR%20%2F%3E*%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BFID%E3%81%A8%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E6%A8%99%E6%BA%96ID%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%9F%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AFRXFIFO_0%E3%81%AB%E5%8F%97%E4%BF%A1%E3%81%95%E3%82%8C%E3%80%81%E4%B8%80%E8%87%B4%E3%81%97%E3%81%9F%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%3CBR%20%2F%3E*%20%E6%8B%A1%E5%BC%B5%20ID%20%E3%81%AF%20RXFIFO_1%20%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20J37%E3%81%8A%E3%82%88%E3%81%B3J38%E3%82%921-2%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%81%AB%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81MCAN1%20TX%20%2F%20RX%E3%82%92%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%20%3CBR%20%2F%3E*%20P15-1%E3%81%AECAN0-CANH%E3%81%8B%E3%82%89P14-1%E3%81%AECAN1-CANH%3CBR%20%2F%3E*%20P15-2%20%E3%81%AE%20CAN0-CANL%20%E3%81%8B%E3%82%89%20P14-2%20%E3%81%AE%20CAN1-CANL%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC5777M%E3%80%81MPC57xx%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%2B%20MPC5777M_512DS%E3%83%9F%E3%83%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%E2%80%BB%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%BB%E3%83%83%E3%83%88%3A0N78H%3CBR%20%2F%3E*%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH%3CBR%20%2F%3E*%20Fsys%3A600%20MHz%20PLL1%E3%80%8140%20MHz%E6%B0%B4%E6%99%B6%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%80%81%3CBR%20%2F%3E*%20PPL1%E3%81%8B%E3%82%89%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F200MHz%E3%81%AEcore2%3CBR%20%2F%3E*%E7%AB%AF%E6%9C%AB%3A%E3%81%AA%E3%81%97%3CBR%20%2F%3E********************************************************************************%3CBR%20%2F%3E%E6%94%B9%E8%A8%82%E5%B1%A5%E6%AD%B4%3A%3CBR%20%2F%3E1.0%202017%E5%B9%B41%E6%9C%885%E6%97%A5%20PetrS%20MCAN%E3%81%AE%E5%88%9D%E6%9C%9F%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E4%BE%8B%3CBR%20%2F%3E*******************************************************************************%2F%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-07-2021 03:15 AM
更新者:
