Example MPC5777C-eQADC_Simple+Calibration_bandgap GHS714
* Detailed Description:
* Initializes eQADC module, performs calibration and converts channel 145
* (bandgap voltage chosen as a source for the channel) and displays it into
* terminal window. No external connection required excluding terminal via eSCI.
* Test HW: MPC5777C-512DS Rev.A + MPC57xx MOTHER BOARD Rev.C
* MCU: PPC5777CMM03 2N45H CTZZS1521A
* Fsys: PLL1 = core_clk = 264MHz, PLL0 = 192MHz
* Debugger: Lauterbach Trace32
* Target: internal_FLASH
* Terminal: 19200-8-no parity-1 stop bit-no flow control on eSCI_A
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1527326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8B%20MPC5777C-eQADC_Simple%2BCalibration_bandgap%20GHS714%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1527326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%0A%3CPRE%20translate%3D%22no%22%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20Initializes%20eQADC%20module%2C%20performs%20calibration%20and%20converts%20channel%20145%20%3CBR%20%2F%3E*%20(bandgap%20voltage%20chosen%20as%20a%20source%20for%20the%20channel)%20and%20displays%20it%20into%20%3CBR%20%2F%3E*%20terminal%20window.%20No%20external%20connection%20required%20excluding%20terminal%20via%20eSCI.%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%20MPC5777C-512DS%20Rev.A%20%2B%20MPC57xx%20MOTHER%20BOARD%20Rev.C%3CBR%20%2F%3E*%20MCU%3A%20PPC5777CMM03%202N45H%20CTZZS1521A%3CBR%20%2F%3E*%20Fsys%3A%20PLL1%20%3D%20core_clk%20%3D%20264MHz%2C%20PLL0%20%3D%20192MHz%3CBR%20%2F%3E*%20Debugger%3A%20Lauterbach%20Trace32%3CBR%20%2F%3E*%20Target%3A%20internal_FLASH%3CBR%20%2F%3E*%20Terminal%3A%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%20%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FPRE%3E%0A%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎11-14-2022 03:54 AM
更新者:
