Example MPC5775K IIC Communication with RTC PCA8565TS/1 S32DS_1.0
* Detailed Description:
* This example shows, how to communicate with RTC module PCA8565TS/1 via I2C bus.
* For this purpose is used I2C driver created by Petr Stancik. Information from
* RTC are sent using DMA via UART. The whole example consists from two parts.
* Second part is PC application called GraphicalTerminalExample. This application
* handles data from RTC and displays them. RTC also can be set using PC application.
* Microcontroller receives data from PC application using DMA via UART.
* Received data are written to RTC module.
* UART connection parameters:
* Baud rate 19200b/s
* 8 data bits
* 1 stop bit
* none parity
* For correct function of java application, it is required Java 1.8.0_40
* Test HW:         MPC5775K-356DS, MPC57xx Motherboard
* MCU:             PPC5775KMMY3B 0N76P
* Fsys:            PLL0 266MHz
*                    Z4 Core 133MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          internal_FLASH (debug mode, release mode)
* EVB connection:
*                     UART connection
*                     J14.1 connected to P12.6 (RX)
*                     J13.1 connected to P12.7 (TX)
*                     RTC connection
*                     RTC pin 4 - connected to any GROUND pin
*                     RTC pin 8 - connected to any 3.3V pin
*                     RTC pin 6 - connected to P8.10 (SCL - I2C clock)
*                     RTC pin 5 - connected to P8.11 (SDA - I2C data)
添付
%3CLINGO-SUB%20id%3D%22lingo-sub-1113534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8BMPC5775K%20RTC%20PCA8565TS%2F1%20S32DS_1.0%20%E3%81%AB%E3%82%88%E3%82%8B%20IIC%20%E9%80%9A%E4%BF%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%3E*%20%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81I2C%E3%83%90%E3%82%B9%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6RTC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%ABPCA8565TS%2F1%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%E3%81%93%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81Petr%20Stancik%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9FI2C%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%8B%E3%82%89%E3%81%AE%E6%83%85%E5%A0%B1%3C%2FP%3E%3CP%3E*%20RTC%E3%81%AFUART%E7%B5%8C%E7%94%B1%E3%81%A7DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%85%A8%E4%BD%93%E3%81%AE%E4%BE%8B%E3%81%AF%202%20%E3%81%A4%E3%81%AE%E9%83%A8%E5%88%86%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BB%E5%BE%8C%E7%B7%A8%E3%81%AFGraphicalTerminal%E3%81%A8%E3%81%84%E3%81%86PC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FP%3E%3CP%3E%E2%80%BBRTC%E3%81%8B%E3%82%89%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E3%82%8A%E6%89%B1%E3%81%84%E3%80%81%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82RTC%E3%81%AFPC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BB%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E3%81%AF%E3%80%81UART%E7%B5%8C%E7%94%B1%E3%81%A7DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6PC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BB%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AFRTC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20UART%E6%8E%A5%E7%B6%9A%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%3A%3C%2FP%3E%3CP%3E*%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%3A19200b%20%2F%20s%3C%2FP%3E%3CP%3E*%208%E3%83%87%E3%83%BC%E3%82%BF%E3%83%93%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E*%201%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E*%20%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E%E2%80%BBjava%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81Java%201.8.0_40%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC5775K-356DS%E3%80%81MPC57xx%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5775KMMY3B%200N76P%3C%2FP%3E%3CP%3E*%20Fsys%3APLL0%20266MHz%3C%2FP%3E%3CP%3E*%20Z4%E3%82%B3%E3%82%A2133MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E%E2%80%BB%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89)%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%3C%2FP%3E%3CP%3E*%20UART%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20J14.1%E3%82%92P12.6(RX)%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%3C%2FP%3E%3CP%3E*%20J13.1%E3%82%92P12.7(TX)%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20RTC%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20RTC%E3%83%94%E3%83%B34%20-%20%E4%BB%BB%E6%84%8F%E3%81%AEGROUND%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20RTC%E3%83%94%E3%83%B38%20-%20%E4%BB%BB%E6%84%8F%E3%81%AE3.3V%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20RTC%E3%83%94%E3%83%B36%20-%20P8.10%E3%81%AB%E6%8E%A5%E7%B6%9A(SCL%20-%20I2C%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF)%3C%2FP%3E%3CP%3E*%20RTC%E3%83%94%E3%83%B35%20-%20P8.11%E3%81%AB%E6%8E%A5%E7%B6%9A(SDA-I2C%E3%83%87%E3%83%BC%E3%82%BF)%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1113534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%3E*%20%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81I2C%E3%83%90%E3%82%B9%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6RTC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%ABPCA8565TS%2F1%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%E3%81%93%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81Petr%20Stancik%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%9FI2C%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%8B%E3%82%89%E3%81%AE%E6%83%85%E5%A0%B1%3C%2FP%3E%3CP%3E*%20RTC%E3%81%AFUART%E7%B5%8C%E7%94%B1%E3%81%A7DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%85%A8%E4%BD%93%E3%81%AE%E4%BE%8B%E3%81%AF%202%20%E3%81%A4%E3%81%AE%E9%83%A8%E5%88%86%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BB%E5%BE%8C%E7%B7%A8%E3%81%AFGraphicalTerminal%E3%81%A8%E3%81%84%E3%81%86PC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FP%3E%3CP%3E%E2%80%BBRTC%E3%81%8B%E3%82%89%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%96%E3%82%8A%E6%89%B1%E3%81%84%E3%80%81%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82RTC%E3%81%AFPC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BB%E3%83%9E%E3%82%A4%E3%82%B3%E3%83%B3%E3%81%AF%E3%80%81UART%E7%B5%8C%E7%94%B1%E3%81%A7DMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6PC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8B%E3%82%89%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BB%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AFRTC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20UART%E6%8E%A5%E7%B6%9A%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%3A%3C%2FP%3E%3CP%3E*%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%3A19200b%20%2F%20s%3C%2FP%3E%3CP%3E*%208%E3%83%87%E3%83%BC%E3%82%BF%E3%83%93%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E*%201%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88%3C%2FP%3E%3CP%3E*%20%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E%E2%80%BBjava%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%81%AF%E3%80%81Java%201.8.0_40%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC5775K-356DS%E3%80%81MPC57xx%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5775KMMY3B%200N76P%3C%2FP%3E%3CP%3E*%20Fsys%3APLL0%20266MHz%3C%2FP%3E%3CP%3E*%20Z4%E3%82%B3%E3%82%A2133MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E%E2%80%BB%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89)%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%3C%2FP%3E%3CP%3E*%20UART%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20J14.1%E3%82%92P12.6(RX)%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%3C%2FP%3E%3CP%3E*%20J13.1%E3%82%92P12.7(TX)%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20RTC%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20RTC%E3%83%94%E3%83%B34%20-%20%E4%BB%BB%E6%84%8F%E3%81%AEGROUND%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20RTC%E3%83%94%E3%83%B38%20-%20%E4%BB%BB%E6%84%8F%E3%81%AE3.3V%E3%83%94%E3%83%B3%E3%81%AB%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E*%20RTC%E3%83%94%E3%83%B36%20-%20P8.10%E3%81%AB%E6%8E%A5%E7%B6%9A(SCL%20-%20I2C%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF)%3C%2FP%3E%3CP%3E*%20RTC%E3%83%94%E3%83%B35%20-%20P8.11%E3%81%AB%E6%8E%A5%E7%B6%9A(SDA-I2C%E3%83%87%E3%83%BC%E3%82%BF)%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1113534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎04-26-2016 06:16 AM
更新者:
