Example MPC5748G BCTU GHS614
* Detailed Description:
* This example implements ADC driver and demonstrated the usage of ADC in BCTU mode.
* When PIT timer exceeds the trigger is sent to BCTU and BCTU triggers ADC_0 conversion.
* Test HW:  MPC57xx
* Maskset:  1N81M
* Target :  SRAM
* Fsys:     160 MHz PLL
Revision History:
1.0     Oct-29-2014     b21190(Vlna Peter)  Initial Version
1.1    Nov-20-2014    b21190(Vlna Peter)  Modified for Cut2.0
1.2    Nov-20-2014    b21190(Vlna Peter)  Added SWT_0 dissabling in startup
1.3    Mar-10-2016    b21190(Vlna Peter)  Fixed clock configuraion for PLL
1.4    Mar-10-2016    b21190(Vlna Peter)  Added ADC driver
1.5    Mar-16-2016    b21190(Vlna Peter)  Added BCTU and PIT drivers
%3CLINGO-SUB%20id%3D%22lingo-sub-1104340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5748G%20BCTU%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1104340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20This%20example%20implements%20ADC%20driver%20and%20demonstrated%20the%20usage%20of%20ADC%20in%20BCTU%20mode.%3C%2FP%3E%3CP%3E*%20When%20PIT%20timer%20exceeds%20the%20trigger%20is%20sent%20to%20BCTU%20and%20BCTU%20triggers%20ADC_0%20conversion.%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%20MPC57xx%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%201N81M%3C%2FP%3E%3CP%3E*%20Target%20%3A%26nbsp%3B%20SRAM%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20160%20MHz%20PLL%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3ERevision%20History%3A%3C%2FP%3E%3CP%3E1.0%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Oct-29-2014%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Initial%20Version%3C%2FP%3E%3CP%3E1.1%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Nov-20-2014%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Modified%20for%20Cut2.0%3C%2FP%3E%3CP%3E1.2%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Nov-20-2014%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Added%20SWT_0%20dissabling%20in%20startup%3C%2FP%3E%3CP%3E1.3%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Mar-10-2016%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Fixed%20clock%20configuraion%20for%20PLL%3C%2FP%3E%3CP%3E1.4%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Mar-10-2016%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Added%20ADC%20driver%3C%2FP%3E%3CP%3E1.5%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Mar-16-2016%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Added%20BCTU%20and%20PIT%20drivers%3C%2FP%3E%3CP%3E*******************************************************************************%2F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1104340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20This%20example%20implements%20ADC%20driver%20and%20demonstrated%20the%20usage%20of%20ADC%20in%20BCTU%20mode.%3C%2FP%3E%3CP%3E*%20When%20PIT%20timer%20exceeds%20the%20trigger%20is%20sent%20to%20BCTU%20and%20BCTU%20triggers%20ADC_0%20conversion.%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%20MPC57xx%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%201N81M%3C%2FP%3E%3CP%3E*%20Target%20%3A%26nbsp%3B%20SRAM%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20160%20MHz%20PLL%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3ERevision%20History%3A%3C%2FP%3E%3CP%3E1.0%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Oct-29-2014%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Initial%20Version%3C%2FP%3E%3CP%3E1.1%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Nov-20-2014%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Modified%20for%20Cut2.0%3C%2FP%3E%3CP%3E1.2%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Nov-20-2014%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Added%20SWT_0%20dissabling%20in%20startup%3C%2FP%3E%3CP%3E1.3%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Mar-10-2016%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Fixed%20clock%20configuraion%20for%20PLL%3C%2FP%3E%3CP%3E1.4%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Mar-10-2016%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Added%20ADC%20driver%3C%2FP%3E%3CP%3E1.5%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Mar-16-2016%26nbsp%3B%26nbsp%3B%26nbsp%3B%20b21190(Vlna%20Peter)%26nbsp%3B%20Added%20BCTU%20and%20PIT%20drivers%3C%2FP%3E%3CP%3E*******************************************************************************%2F%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1104340%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
No ratings
Version history
Last update:
‎03-22-2016 01:54 AM
Updated by:
