Example MPC5744P PIT triggering interrupts
No ratings
* Detailed Description:
* This example shows how to use PIT module for triggering interrupts on its timeout.
* For closer details on how PIT works I suggest you to check reference manual as this is quite simple timer.
* This example sets PIT timer0 channel0 for 5000000 cycles.
* As soon as it exceeds the interrupt is triggered.
* Pin state is toggling in ISR
* Test HW:  MPC57xx Motherboard + MPC5744PE257DC minimodule, MPC5744P,
* silicon mask set 1N65H
* Target :  internal_FLASH*
Version history
Last update:
‎01-26-2015 02:19 AM
Updated by:
