Example MPC5744P LIN Master Slave test GHS614
* Detailed Description:
* LINFlexD_1 configured as Master
*   - sends Header
*   - either transmits a data to LIN Slave or receives data from a LIN Slave
*   - no interrupt is used, just SW pooling
* LINFlexD_0 as Slave
*   - receives header from a LIN Master
*   - either receives data from a LIN Master or transmits a data to Master
*   - filter is enabled
*   - TX interrupt is used to prepare data to send and
*   - RX interrupt to read received data
* EVB connection:
*   Switches on Motherboard:
*   P6.1 to P8.1  ... SW1 to PA0
*   P6.2 to P8.2  ... SW2 to PA1
*   P6.3 to P8.3  ... SW3 to PA2
*   P6.4 to P8.4  ... SW4 to PA3
*   Unconnect LINFlexD_0 from UART transceiver
*   J14 SCI_RX open
*   J13 SCI_TX open
*   As only single LIN transceiver is available LINFlex modules are connected
*   together before this transceiver in the way TX pins together and RX pins together.
*   TX pins must be configured as open drain and use a pullup resistor.
*   P11.15 to P12.8    TX pins
*   P11.16 to P12.7    RX pins
*   Connect LINFlexD_1 to LIN transceiver on Motherboard
*   J17 - LIN_TX ON
*   J16 - LIN_RX ON
*   J15 - LIN_EN ON
*   P3 1-2 ON ... VSUP to 12V
*   See LIN signal on P3.3 or J4.4.
* Test HW:  MPC5744P
* Maskset:  1N65H
* Target :  RAM, internal_FLASH
* Fsys:     200 MHz PLL with 40 MHz crystal reference
* Terminal: None
Revision History:
1.0     Feb-22-2016     PetrS          Initial Version of LIN example
Original Attachment has been moved to: Example-MPC5744P-LINFlex-LIN-Master-Slave-test-v1_0-GHS614.zip
标签 (1)
附件
%3CLINGO-SUB%20id%3D%22lingo-sub-1128126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5744P%20LIN%20%E4%B8%BB%E4%BB%8E%E6%B5%8B%E8%AF%95%20GHS614%20%E7%A4%BA%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E********************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20LINFlexD_1%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%B8%BB%E7%AB%99%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20-%20%E5%8F%91%E9%80%81%E6%A0%87%E9%A2%98%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20-%20%E8%A6%81%E4%B9%88%E5%90%91%20LIN%20%E4%BB%8E%E7%AB%99%E5%8F%91%E9%80%81%E6%95%B0%E6%8D%AE%EF%BC%8C%E8%A6%81%E4%B9%88%E4%BB%8E%20LIN%20%E4%BB%8E%E7%AB%99%E6%8E%A5%E6%94%B6%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20-%20%E4%B8%8D%E4%BD%BF%E7%94%A8%E4%B8%AD%E6%96%AD%EF%BC%8C%E4%BB%85%E4%BD%BF%E7%94%A8%20SW%20%E6%B1%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20LINFlexD_0%20%E4%BD%9C%E4%B8%BA%E4%BB%8E%E8%AE%BE%E5%A4%87%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20-%20%E4%BB%8E%20LIN%20%E4%B8%BB%E7%AB%99%E6%8E%A5%E6%94%B6%E6%A0%87%E5%A4%B4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20-%20%E4%BB%8E%20LIN%20%E4%B8%BB%E7%AB%99%E6%8E%A5%E6%94%B6%E6%95%B0%E6%8D%AE%E6%88%96%E5%90%91%E4%B8%BB%E7%AB%99%E5%8F%91%E9%80%81%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20-%20%E8%BF%87%E6%BB%A4%E5%99%A8%E5%B7%B2%E5%90%AF%E7%94%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20-%20TX%20%E4%B8%AD%E6%96%AD%E7%94%A8%E4%BA%8E%E5%87%86%E5%A4%87%E8%A6%81%E5%8F%91%E9%80%81%E7%9A%84%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%B9%B6%E4%B8%94%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20-%20RX%E4%B8%AD%E6%96%AD%E8%AF%BB%E5%8F%96%E6%8E%A5%E6%94%B6%E7%9A%84%E6%95%B0%E6%8D%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20%E4%B8%BB%E6%9D%BF%E4%B8%8A%E7%9A%84%E5%BC%80%E5%85%B3%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20P6.1%20%E5%88%B0%20P8.1%20...%20SW1%20%E5%88%B0%20PA0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20P6.2%20%E5%88%B0%20P8.2%20...%20SW2%20%E5%88%B0%20PA1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20P6.3%20%E5%88%B0%20P8.3%20...%20SW3%20%E5%88%B0%20PA2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20P6.4%20%E8%87%B3%20P8.4%20...%20SW4%20%E8%87%B3%20PA3%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20%E6%96%AD%E5%BC%80%20LINFlexD_0%20%E4%B8%8E%20UART%20%E6%94%B6%E5%8F%91%E5%99%A8%E7%9A%84%E8%BF%9E%E6%8E%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20J14%20SCI_RX%20%E6%89%93%E5%BC%80%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20J13%20SCI_TX%20%E6%89%93%E5%BC%80%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20%E7%94%B1%E4%BA%8E%E4%BB%85%E6%9C%89%E5%8D%95%E4%B8%AA%20LIN%20%E6%94%B6%E5%8F%91%E5%99%A8%E5%8F%AF%E7%94%A8%EF%BC%8CLINFlex%20%E6%A8%A1%E5%9D%97%E8%BF%9E%E6%8E%A5%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20%E5%B0%86%E6%AD%A4%E6%94%B6%E5%8F%91%E5%99%A8%E4%B9%8B%E5%89%8D%E7%9A%84%20TX%20%E5%BC%95%E8%84%9A%E8%BF%9E%E6%8E%A5%E5%9C%A8%E4%B8%80%E8%B5%B7%EF%BC%8C%E5%B0%86%20RX%20%E5%BC%95%E8%84%9A%E8%BF%9E%E6%8E%A5%E5%9C%A8%E4%B8%80%E8%B5%B7%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20TX%20%E5%BC%95%E8%84%9A%E5%BF%85%E9%A1%BB%E9%85%8D%E7%BD%AE%E4%B8%BA%E6%BC%8F%E6%9E%81%E5%BC%80%E8%B7%AF%E5%B9%B6%E4%BD%BF%E7%94%A8%E4%B8%8A%E6%8B%89%E7%94%B5%E9%98%BB%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20P11.15%20%E8%87%B3%20P12.8%20TX%20%E5%BC%95%E8%84%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20P11.16%20%E8%87%B3%20P12.7%20RX%20%E5%BC%95%E8%84%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20%E5%B0%86%20LINFlexD_1%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%BB%E6%9D%BF%E4%B8%8A%E7%9A%84%20LIN%20%E6%94%B6%E5%8F%91%E5%99%A8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20J17-LIN_TX%E5%BC%80%E5%90%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20J16-LIN_RX%E5%BC%80%E5%90%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20J15-LIN_EN%20%E5%BC%80%E5%90%AF%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20P3%201-2%20%E5%BC%80%E5%90%AF...VSUP%20%E8%87%B3%2012V%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E**%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20%E5%8F%82%E8%A7%81%20P3.3%20%E6%88%96%20J4.4%20%E4%B8%8A%E7%9A%84%20LIN%20%E4%BF%A1%E5%8F%B7%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20------------------------------------------------------------------------------%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC5744P%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20Maskset%3A%26nbsp%3B%201N65H%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9ARAM%E3%80%81%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20Fsys%3A%20200%20MHz%20PLL%EF%BC%8C%E5%B8%A6%2040%20MHz%20%E6%99%B6%E6%8C%AF%E5%8F%82%E8%80%83%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*%20%E7%BB%88%E7%AB%AF%EF%BC%9A%E6%97%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E********************************************************************************%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E%E4%BF%AE%E8%AE%A2%E5%8E%86%E5%8F%B2%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E1.0%202016%E5%B9%B42%E6%9C%8822%E6%97%A5%20PetrS%20LIN%20%E7%A4%BA%E4%BE%8B%E7%9A%84%E5%88%9D%E5%A7%8B%E7%89%88%E6%9C%AC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2010pt%3B%22%3E*******************************************************************************%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E5%8E%9F%E5%A7%8B%E9%99%84%E4%BB%B6%E5%B7%B2%E7%A7%BB%E8%87%B3%EF%BC%9A%20%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-339878%22%20target%3D%22_blank%22%3EExample-MPC5744P-LINFlex-LIN-Master-Slave-test-v1_0-GHS614.zip%3C%2FA%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1128126%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎02-23-2016 08:02 AM
更新人:
