Example MPC5744P FlexPWM CTU SGEN triggering
* Detailed Description:
* This example shows usage of FlexPWM and Sine Wave generator (SGEN) modules.
* The setting is selected in the way to have a PWM output signal synhronized with
* SWG output signal. This is necessary for resolver usage in motor control appls.
* The CTU_0 is triggered from FlexPWM_0's. The PMWB output rising edge is used here.
* The CTU generates the eTIMER1_TRG signal, that is a trigger signal for the
* SGEN module. The delay between PWMB and SGEN trigger is changed so you can see
* the generated sinusoidal signal change phase against the PWMB output.
* See attached Excel sheet for calculation of parammeters used here (AUX0_clk_DIV0,
* AUX0_clk_DIV1, SGEN_IOFREQ, PWM_PRESCALER, PWM_MODULO).
* This example is set for 9.765625KHz SGEN/PWM frequency.
* Note  because the SGEN trigger input is an asynchronous signal, it must be held high
* for at least 2 SGEN clock cycles in order to capture the input trigger.
* As the CTU generates the trigger as a pulse of single CTU clock width, the CTU clock must be
* half of the SGEN clock at least.
* Use the AUX0_clk_DIV0 to test this behaviour.
* Test HW:  MPC57xx
* Maskset:  1N65H
* Target :  internal_FLASH
* Fsys:     200 MHz PLL with 40 MHz crystal reference
* EVB connection:
* P11.8 - D[7] .. SGEN output
*          connected to FEC PHY's MIIMODE input on motherboard,
*          to see full amplitude remove J26
* P8.12    - A[11] .. FlexPWM A[0] output
* P8.11    - A[10] .. FlexPWM B[0] output
标签 (1)
附件
%3CLINGO-SUB%20id%3D%22lingo-sub-1100734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5744P%20FlexPWM%20CTU%20SGEN%20%E8%A7%A6%E5%8F%91%E7%A4%BA%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1100734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E6%AD%A4%E7%A4%BA%E4%BE%8B%E5%B1%95%E7%A4%BA%E4%BA%86%20FlexPWM%20%E5%92%8C%E6%AD%A3%E5%BC%A6%E6%B3%A2%E5%8F%91%E7%94%9F%E5%99%A8%20(SGEN)%20%E6%A8%A1%E5%9D%97%E7%9A%84%E4%BD%BF%E7%94%A8%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E*%20%E8%AE%BE%E7%BD%AE%E6%96%B9%E5%BC%8F%E9%80%89%E6%8B%A9PWM%E8%BE%93%E5%87%BA%E4%BF%A1%E5%8F%B7%E4%B8%8E%20%3C%2FP%3E%3CP%3E*%20SWG%E8%BE%93%E5%87%BA%E4%BF%A1%E5%8F%B7%E3%80%82%E8%BF%99%E5%AF%B9%E4%BA%8E%E7%94%B5%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%BA%94%E7%94%A8%E4%B8%AD%E7%9A%84%E6%97%8B%E8%BD%AC%E5%8F%98%E5%8E%8B%E5%99%A8%E7%9A%84%E4%BD%BF%E7%94%A8%E6%98%AF%E5%BF%85%E8%A6%81%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E*%20CTU_0%20%E7%94%B1%20FlexPWM_0%20%E8%A7%A6%E5%8F%91%E3%80%82%E8%BF%99%E9%87%8C%E4%BD%BF%E7%94%A8PMWB%E8%BE%93%E5%87%BA%E4%B8%8A%E5%8D%87%E6%B2%BF%E3%80%82%3C%2FP%3E%3CP%3E*%20CTU%20%E7%94%9F%E6%88%90%20eTIMER1_TRG%20%E4%BF%A1%E5%8F%B7%EF%BC%8C%E8%BF%99%E6%98%AF%3C%2FP%3E%3CP%3E*%20SGEN%E6%A8%A1%E5%9D%97%E3%80%82PWMB%20%E5%92%8C%20SGEN%20%E8%A7%A6%E5%8F%91%E5%99%A8%E4%B9%8B%E9%97%B4%E7%9A%84%E5%BB%B6%E8%BF%9F%E5%8F%91%E7%94%9F%E4%BA%86%E5%8F%98%E5%8C%96%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%3C%2FP%3E%3CP%3E*%20%E7%94%9F%E6%88%90%E7%9A%84%E6%AD%A3%E5%BC%A6%E4%BF%A1%E5%8F%B7%E6%A0%B9%E6%8D%AEPWMB%E8%BE%93%E5%87%BA%E6%94%B9%E5%8F%98%E7%9B%B8%E4%BD%8D%E3%80%82%20%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E8%AF%B7%E5%8F%82%E9%98%85%E9%99%84%E4%BB%B6%20Excel%20%E8%A1%A8%EF%BC%8C%E4%BA%86%E8%A7%A3%E6%AD%A4%E5%A4%84%E4%BD%BF%E7%94%A8%E7%9A%84%E5%8F%82%E6%95%B0%E8%AE%A1%E7%AE%97%E6%96%B9%E6%B3%95%EF%BC%88AUX0_clk_DIV0%E3%80%81%3C%2FP%3E%3CP%3E*%20AUX0_clk_DIV1%2C%20SGEN_IOFREQ%2C%20PWM_PRESCALER%2C%20PWM_MODULO).%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E6%AD%A4%E7%A4%BA%E4%BE%8B%E8%AE%BE%E7%BD%AE%E4%B8%BA%209.765625KHz%20SGEN%2FPWM%20%E9%A2%91%E7%8E%87%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%E6%B3%A8%E6%84%8F%EF%BC%8C%E7%94%B1%E4%BA%8E%20SGEN%20%E8%A7%A6%E5%8F%91%E8%BE%93%E5%85%A5%E6%98%AF%E5%BC%82%E6%AD%A5%E4%BF%A1%E5%8F%B7%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%BF%85%E9%A1%BB%E4%BF%9D%E6%8C%81%E9%AB%98%E7%94%B5%E5%B9%B3%3C%2FP%3E%3CP%3E*%20%E8%87%B3%E5%B0%91%202%20%E4%B8%AA%20SGEN%20%E6%97%B6%E9%92%9F%E5%91%A8%E6%9C%9F%E6%89%8D%E8%83%BD%E6%8D%95%E8%8E%B7%E8%BE%93%E5%85%A5%E8%A7%A6%E5%8F%91%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E*%20%E7%94%B1%E4%BA%8E%20CTU%20%E7%94%9F%E6%88%90%E7%9A%84%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E4%B8%BA%E5%8D%95%E4%B8%AA%20CTU%20%E6%97%B6%E9%92%9F%E5%AE%BD%E5%BA%A6%E7%9A%84%E8%84%89%E5%86%B2%EF%BC%8C%E5%9B%A0%E6%AD%A4%20CTU%20%E6%97%B6%E9%92%9F%E5%BF%85%E9%A1%BB%E6%98%AF%3C%2FP%3E%3CP%3E*%20%E8%87%B3%E5%B0%91%E4%B8%80%E5%8D%8A%E7%9A%84SGEN%E6%97%B6%E9%92%9F%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E4%BD%BF%E7%94%A8%20AUX0_clk_DIV0%20%E6%9D%A5%E6%B5%8B%E8%AF%95%E6%AD%A4%E8%A1%8C%E4%B8%BA%E3%80%82%20%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC57xx%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%201N65H%3C%2FP%3E%3CP%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9Ainternal_FLASH%3C%2FP%3E%3CP%3E*%20Fsys%3A%20200%20MHz%20PLL%EF%BC%8C%E5%B8%A6%2040%20MHz%20%E6%99%B6%E6%8C%AF%E5%8F%82%E8%80%83%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20EVB%E8%BF%9E%E6%8E%A5%EF%BC%9A%20%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20P11.8%20-%20D%5B7%5D..%20SGEN%E8%BE%93%E5%87%BA%3C%2FP%3E%3CP%3E*%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%BB%E6%9D%BF%E4%B8%8A%E7%9A%84%20FEC%20PHY%20%E7%9A%84%20MIIMODE%20%E8%BE%93%E5%85%A5%EF%BC%8C%3C%2FP%3E%3CP%3E*%20%E8%A6%81%E6%9F%A5%E7%9C%8B%E5%AE%8C%E6%95%B4%E6%8C%AF%E5%B9%85%EF%BC%8C%E8%AF%B7%E7%A7%BB%E9%99%A4%20J26%20%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20P8.12%20-%20A%5B11%5D..%20FlexPWM%20A%5B0%5D%20%E8%BE%93%E5%87%BA%20%3C%2FP%3E%3CP%3E*%20P8.11%20-%20A%5B10%5D..%20FlexPWM%20B%5B0%5D%20%E8%BE%93%E5%87%BA%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1100734%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
无评分
版本历史
最后更新:
‎09-17-2015 01:16 AM
更新人:
