Example MPC5744P FlexPWM CTU ADC synchronization GHS614
* Detailed Description:
* This example shows synchronization between FlexPWM, CTU and ADC modules.
* The FlexPWM Submodule 0 is initialized to generate PWM signal, and rising edge
* of PWM B0 signal is used to generate trigger signal for CTU module. The CTU module
* sends two commands to ADCs. Single conversion mode is used, so ADC0 ch0 and ch1
* are sampled. The conversion result is used to modify PWM B0 rising egde position
* and change delay between external trigger and ADC sequence triggering.
* Test HW:  MPC57xx
* Maskset:  1N65H
* Target :  internal_FLASH
* Fsys:     200 MHz PLL with 40 MHz crystal reference
* EVB connection:
* P8.1  - A[0]  .. GPIO output, used to see CTU-ADC ISR period
* P9.1     - B[7]  .. ADC0 AN[0] input
* P9.2     - B[8]  .. ADC0 AN[1] input
* P16.4 - I[3] .. CTU0 EXT TRG output
* P8.12    - A[11] .. FlexPWM A[0] output
* P8.11    - A[10] .. FlexPWM B[0] output
* connect Trimmer J53.1 to P9.1 to change position of PWM B0 rising edge
* connect Trimmer J53.1 to P9.2 to change CTU trigger delay from PWM B0 rising edge
* see CTU0 EXT TRG output signal (toggle on each trigger) on P16.4 with respect of PWM signals
添付
コメント
wsc
There are some errors in this file for "MPC5744P_IsrVecTab.c". But I don't know how to solve it ..
%3CLINGO-SUB%20id%3D%22lingo-sub-1128788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8B%20MPC5744P%20FlexPWM%20CTU%20ADC%20%E5%90%8C%E6%9C%9F%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81FlexPWM%E3%80%81CTU%E3%80%81ADC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E9%96%93%E3%81%AE%E5%90%8C%E6%9C%9F%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%20FlexPWM%E3%82%B5%E3%83%96%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB0%E3%81%AF%E3%80%81PWM%E4%BF%A1%E5%8F%B7%E3%81%A8%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%20PWM%20B0%E4%BF%A1%E5%8F%B7%E3%81%AF%E3%80%81CTU%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E4%BF%A1%E5%8F%B7%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82CTU%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3C%2FP%3E%3CP%3E*%20%E3%81%AF%202%20%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%20ADC%20%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%82%B3%E3%83%B3%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81ADC0%20ch0%E3%81%A8ch1%3C%2FP%3E%3CP%3E*%E3%81%AF%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E5%A4%89%E6%8F%9B%E7%B5%90%E6%9E%9C%E3%81%AF%E3%80%81PWM%20B0%20%E3%81%AE%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%20egde%20%E4%BD%8D%E7%BD%AE%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%E5%A4%96%E9%83%A8%E3%83%88%E3%83%AA%E3%82%AC%E3%81%A8ADC%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%83%88%E3%83%AA%E3%82%AC%E3%81%AE%E9%96%93%E3%81%AE%E9%81%85%E5%BB%B6%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC57xx%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%201N65H%3C%2FP%3E%3CP%3E*%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH%3C%2FP%3E%3CP%3E*%20Fsys%3A200MHz%20PLL%E3%80%8140MHz%E6%B0%B4%E6%99%B6%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E%E3%83%BBP8.1%20-%20A%5B0%5D%20..GPIO%E5%87%BA%E5%8A%9B%E3%80%81CTU-ADC%20ISR%E6%9C%9F%E9%96%93%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%81%AB%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E%E3%83%BBP9.1%20-%20B%5B7%5D%20..ADC0%20AN%5B0%5D%E5%85%A5%E5%8A%9B%3C%2FP%3E%3CP%3E%E3%83%BBP9.2%20-%20B%5B8%5D%20..ADC0%20AN%5B1%5D%E5%85%A5%E5%8A%9B%3C%2FP%3E%3CP%3E%E3%83%BBP16.4%20-%20I%5B3%5D%20..CTU0%20EXT%20TRG%E5%87%BA%E5%8A%9B%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E2%80%BBP8.12%20-%20A%5B11%5D%20..FlexPWM%20A%5B0%5D%E5%87%BA%E5%8A%9B%3C%2FP%3E%3CP%3E%E2%80%BBP8.11%20-%20A%5B10%5D%20..FlexPWM%20B%5B0%5D%E5%87%BA%E5%8A%9B%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%E3%83%88%E3%83%AA%E3%83%9E%E3%83%BCJ53.1%E3%82%92P9.1%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%80%81PWMB0%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AE%E4%BD%8D%E7%BD%AE%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%20%E3%83%88%E3%83%AA%E3%83%9E%E3%83%BCJ53.1%E3%82%92P9.2%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%80%81CTU%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E9%81%85%E5%BB%B6%E3%82%92PWM%20B0%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%8B%E3%82%89%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20PWM%E4%BF%A1%E5%8F%B7%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81P16.4%E3%81%AECTU0%20EXT%20TRG%E5%87%BA%E5%8A%9B%E4%BF%A1%E5%8F%B7(%E5%90%84%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%AE%E3%83%88%E3%82%B0%E3%83%AB)%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1128788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1128789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20%E4%BE%8B%20MPC5744P%20FlexPWM%20CTU%20ADC%20%E5%90%8C%E6%9C%9F%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1128789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%20%22MPC5744P_IsrVecTab.c%22%20%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%A7%E3%82%82%E3%80%81%E3%81%A9%E3%81%86%E3%82%84%E3%81%A3%E3%81%A6%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%9F%E3%82%89%E3%81%84%E3%81%84%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84...%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎04-10-2015 05:06 AM
更新者:
