Example MPC5744P 1b+2b_PERRAM_ECC_error_injection GHS614
* Detailed Description:
* Purpose of the example is to show how to simulate Multi-bit or Single-bit ECC
* error in internal DMA TCD RAM (user must choose it in the option at the end of
* main function).
* EIM (Error Injection Module) is used to simulate a multi-bit or single-bit
* ECC error in DMA TCD RAM (Peripheral RAM).
* When corrupted data is accessed the IVOR1 exception handler is called in case
* of multi-bit ECC error (IVOR1 exception occurs) and FCCU_Alarm_Interrupt
* handler is called in case of single-bit ECC error (FCCU interrupt occurs).
* Both function calls MEMU handler.
* The example displays notices in the terminal window (connector J19 on
* MPC57xx_Motherboard)(19200-8-no parity-1 stop bit-no flow control on eSCI_A).
* No other external connection is required.
* Test HW:         MPC57xx_Motherboard + MPC5744P-144DC
* MCU:             PPC5744PFMLQ8,0N15P,QQAA1515N, Rev2.1B
* Fsys:            200 MHz PLL with 40 MHz crystal reference
* Debugger:        Lauterbach Trace32
* Target:          internal_FLASH, RAM
* Terminal:        19200-8-no parity-1 stop bit-no flow control
* EVB connection:  default
添付
コメント
Hello, I encountered a problem in the process of testing 5744: MEMU_PERIPH_RAM_CERR,MEMU_PERIPH_RAM_UNCERR injection failed to make the MEMU_ERR_FLAG register PR_CE,PR_UCE set, the test code is downloaded from the NXP website. At the end of the main function injection, the code is as follows:
#define EIM_EICHEN_DMA_memory_0 0x80000000u
// must be somewhere in DMA TCD area i.e. 0xFC0A1000-0xFC0A13FE
#define Injected_ECC_error_address 0xFC0A1000u
void Generate_1b_ECC_error_in_DMA_TCD(void)
register vuint32_t test_read = 0u;
//printf("ECC 1b error injected into RAM\r\n");
/* invert 1 LSB bits to create non-correctable data error */
EIM.EICHD_Word1.R = 0x00000001u;
/* PRAMC_0 channel error injection enable */
EIM.EICHEN.R = EIM_EICHEN_DMA_memory_0;
/* global error injection enable */
EIM.EIMCR.R = 1u;
/* error caused by read (it should set MCSR[MAV, LD, BUS_DRERR]) */
test_read = *(unsigned int*) Injected_ECC_error_address;
void Generate_2b_ECC_error_in_DMA_TCD_duplicate(void)
//printf("ECC 2b error injected into RAM\r\n");
/* invert 2 LSB bits to create non-correctable data error */
EIM.EICHD_Word1.R = 0x00000003u;
EIM.EIMCR.R = 1u;
note: FLASH_RAM,SYS_RAM can use NXP Web site code to implement error_injection.
Thank you very much for your help!
I am sorry but I don't understand you. Could you clarify what exactly does not work for you? Thanks
Hello David ,
      1b+2b_PERRAM_ECC_error_injection doesn't work in my main function,PR_CE and PR_UCE of MEMU_ERR_FLAG register are always zero,my chip is SPC5744PFK1AMLQ9,the 1b+2b_PERRAM_ECC_error_injection code that injected into the main function is as the follows pictures:
      Thanks for your help!!
%3CLINGO-SUB%20id%3D%22lingo-sub-1112573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8B%20MPC5744P%201b%2B2b_PERRAM_ECC_error_injection%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E*%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%3A%3CBR%20%2F%3E*%20%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%83%93%E3%83%83%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%93%E3%83%83%E3%83%88%20ECC%20%E3%81%AE%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%3CBR%20%2F%3E*%E5%86%85%E9%83%A8DMA%20TCD%20RAM%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC(%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3CBR%20%2F%3E*%E4%B8%BB%E3%81%AA%E6%A9%9F%E8%83%BD)%E3%80%82%3CBR%20%2F%3E*%20EIM(Error%20Injection%20Module)%E3%81%AF%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%83%93%E3%83%83%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%20DMA%20TCD%20RAM%20(%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%ABRAM)%20%E3%81%AE%20ECC%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%20%3CBR%20%2F%3E*%20%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%20IVOR1%20%E4%BE%8B%E5%A4%96%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E3%83%9E%E3%83%AB%E3%83%81%E3%83%93%E3%83%83%E3%83%88ECC%E3%82%A8%E3%83%A9%E3%83%BC(IVOR1%E4%BE%8B%E5%A4%96%E7%99%BA%E7%94%9F)%E3%81%8A%E3%82%88%E3%81%B3FCCU_Alarm_Interrupt%3CBR%20%2F%3E*%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%AF%E3%80%81%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%93%E3%83%83%E3%83%88ECC%E3%82%A8%E3%83%A9%E3%83%BC(FCCU%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E7%99%BA%E7%94%9F)%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%82MEMU%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E7%AB%AF%E6%9C%AB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6(%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BFJ19%E3%81%8C%E3%82%AA%E3%83%B3)%E3%81%AB%E9%80%9A%E7%9F%A5%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%20MPC57xx_Motherboard)(19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-eSCI_A)%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97)%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E4%BB%96%E3%81%AE%E5%A4%96%E9%83%A8%E6%8E%A5%E7%B6%9A%E3%81%AF%E4%B8%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC57xx_Motherboard%20%2B%20MPC5744P-144DC%3CBR%20%2F%3E%E2%80%BBMCU%3APPC5744PFMLQ8%2C0N15P%2CQQAA1515N%2C%20Rev2.1B%3CBR%20%2F%3E*%20Fsys%3A200MHz%20PLL%E3%80%8140MHz%E6%B0%B4%E6%99%B6%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%3CBR%20%2F%3E*%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%3ALauterbach%20Trace32%3CBR%20%2F%3E*%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH%E3%80%81RAM%3CBR%20%2F%3E*%E7%AB%AF%E6%9C%AB%3A19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%3CBR%20%2F%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1112573%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E*%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%3A%3CBR%20%2F%3E*%20%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%AE%E7%9B%AE%E7%9A%84%E3%81%AF%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%83%93%E3%83%83%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%93%E3%83%83%E3%83%88%20ECC%20%E3%81%AE%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E6%96%B9%E6%B3%95%E3%82%92%E7%A4%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%3CBR%20%2F%3E*%E5%86%85%E9%83%A8DMA%20TCD%20RAM%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC(%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AF%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%3CBR%20%2F%3E*%E4%B8%BB%E3%81%AA%E6%A9%9F%E8%83%BD)%E3%80%82%3CBR%20%2F%3E*%20EIM(Error%20Injection%20Module)%E3%81%AF%E3%80%81%E3%83%9E%E3%83%AB%E3%83%81%E3%83%93%E3%83%83%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E3%82%B7%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%20DMA%20TCD%20RAM%20(%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%ABRAM)%20%E3%81%AE%20ECC%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%82%20%3CBR%20%2F%3E*%20%E7%A0%B4%E6%90%8D%E3%81%97%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%20IVOR1%20%E4%BE%8B%E5%A4%96%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E3%83%9E%E3%83%AB%E3%83%81%E3%83%93%E3%83%83%E3%83%88ECC%E3%82%A8%E3%83%A9%E3%83%BC(IVOR1%E4%BE%8B%E5%A4%96%E7%99%BA%E7%94%9F)%E3%81%8A%E3%82%88%E3%81%B3FCCU_Alarm_Interrupt%3CBR%20%2F%3E*%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%81%AF%E3%80%81%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%93%E3%83%83%E3%83%88ECC%E3%82%A8%E3%83%A9%E3%83%BC(FCCU%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E7%99%BA%E7%94%9F)%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AB%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%82MEMU%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E3%81%93%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81%E7%AB%AF%E6%9C%AB%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6(%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BFJ19%E3%81%8C%E3%82%AA%E3%83%B3)%E3%81%AB%E9%80%9A%E7%9F%A5%E3%82%92%E8%A1%A8%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%20MPC57xx_Motherboard)(19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-eSCI_A)%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97)%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E4%BB%96%E3%81%AE%E5%A4%96%E9%83%A8%E6%8E%A5%E7%B6%9A%E3%81%AF%E4%B8%8D%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC57xx_Motherboard%20%2B%20MPC5744P-144DC%3CBR%20%2F%3E%E2%80%BBMCU%3APPC5744PFMLQ8%2C0N15P%2CQQAA1515N%2C%20Rev2.1B%3CBR%20%2F%3E*%20Fsys%3A200MHz%20PLL%E3%80%8140MHz%E6%B0%B4%E6%99%B6%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%3CBR%20%2F%3E*%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%3ALauterbach%20Trace32%3CBR%20%2F%3E*%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH%E3%80%81RAM%3CBR%20%2F%3E*%E7%AB%AF%E6%9C%AB%3A19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%3CBR%20%2F%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1112575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3A%E4%BE%8BMPC5744P%201b%2B2b_PERRAM_ECC_error_injection%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1112575%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%81%93%E3%81%A8%E3%81%8C%E7%90%86%E8%A7%A3%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8B%E3%81%AA%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E6%AD%A3%E7%A2%BA%E3%81%AB%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E6%84%9F%E8%AC%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎02-20-2021 06:37 AM
更新者:
