Example MPC5674F eQADC+eDMA-Single+Differential+GAIN CW210
* Detailed Description:
* Initializes eQADC module for differnential single scan mode (with choosen GAIN
* factor), converts specified command queue and displays results into terminal
* window when EOQ is reached.
* Differential analog input DAN0+:DAN0- needs to be connect externally between
* pins ANA_0 and ANA_1 to see some valid numbers.
* EVB potentiomenters can be used for the purpose.
* As differential mode has been used, eQADC does not required to be calibrated.
* Test HW:         XPC567XKIT516 - MPC5674ADAT516 Rev.C, MPC567XEVBFXMB Rev.B
* MCU:             PPC5674FMVYA264
* Terminal:        19200-8-no parity-1 stop bit-no flow control on eSCI_A
* Fsys:            264/200/150/60 MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          RAM, internal_FLASH
* EVB connection:  Potentiometers     --> ADC inputs
*                  USER_DEV_RV2(J4-7) --> ANA_0 (J18-3) DAN0+
*                  USER_DEV_RV3(J4-8) --> ANA_1 (J18-4) DAN0-
*                    Buttons            --> ADC triggers
*                    USER_DEV_1D(J4-2)  --> TPU_A0 (J22-1)
%3CLINGO-SUB%20id%3D%22lingo-sub-1103238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5674F%20eQADC%2BeDMA-Single%2BDifferential%2BGAIN%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1103238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20Initializes%20eQADC%20module%20for%20differnential%20single%20scan%20mode%20(with%20choosen%20GAIN%3CBR%20%2F%3E*%20factor)%2C%20converts%20specified%20command%20queue%20and%20displays%20results%20into%20terminal%20%3CBR%20%2F%3E*%20window%20when%20EOQ%20is%20reached.%20%3CBR%20%2F%3E*%20Differential%20analog%20input%20DAN0%2B%3ADAN0-%20needs%20to%20be%20connect%20externally%20between%3CBR%20%2F%3E*%20pins%20ANA_0%20and%20ANA_1%20to%20see%20some%20valid%20numbers.%20%3CBR%20%2F%3E*%20EVB%20potentiomenters%20can%20be%20used%20for%20the%20purpose.%3CBR%20%2F%3E*%20As%20differential%20mode%20has%20been%20used%2C%20eQADC%20does%20not%20required%20to%20be%20calibrated.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E*%20%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20XPC567XKIT516%20-%20MPC5674ADAT516%20Rev.C%2C%20MPC567XEVBFXMB%20Rev.B%3CBR%20%2F%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5674FMVYA264%3CBR%20%2F%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3CBR%20%2F%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264%2F200%2F150%2F60%20MHz%3CBR%20%2F%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3CBR%20%2F%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3CBR%20%2F%3E*%20EVB%20connection%3A%26nbsp%3B%20Potentiometers%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20--%26gt%3B%20ADC%20inputs%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20USER_DEV_RV2(J4-7)%20--%26gt%3B%20ANA_0%20(J18-3)%20DAN0%2B%20%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20USER_DEV_RV3(J4-8)%20--%26gt%3B%20ANA_1%20(J18-4)%20DAN0-%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Buttons%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20--%26gt%3B%20ADC%20triggers%3CBR%20%2F%3E*%20%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20USER_DEV_1D(J4-2)%26nbsp%3B%20--%26gt%3B%20TPU_A0%20(J22-1)%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1103238%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20Initializes%20eQADC%20module%20for%20differnential%20single%20scan%20mode%20(with%20choosen%20GAIN%3CBR%20%2F%3E*%20factor)%2C%20converts%20specified%20command%20queue%20and%20displays%20results%20into%20terminal%20%3CBR%20%2F%3E*%20window%20when%20EOQ%20is%20reached.%20%3CBR%20%2F%3E*%20Differential%20analog%20input%20DAN0%2B%3ADAN0-%20needs%20to%20be%20connect%20externally%20between%3CBR%20%2F%3E*%20pins%20ANA_0%20and%20ANA_1%20to%20see%20some%20valid%20numbers.%20%3CBR%20%2F%3E*%20EVB%20potentiomenters%20can%20be%20used%20for%20the%20purpose.%3CBR%20%2F%3E*%20As%20differential%20mode%20has%20been%20used%2C%20eQADC%20does%20not%20required%20to%20be%20calibrated.%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E*%20%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20XPC567XKIT516%20-%20MPC5674ADAT516%20Rev.C%2C%20MPC567XEVBFXMB%20Rev.B%3CBR%20%2F%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5674FMVYA264%3CBR%20%2F%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3CBR%20%2F%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20264%2F200%2F150%2F60%20MHz%3CBR%20%2F%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3CBR%20%2F%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3CBR%20%2F%3E*%20EVB%20connection%3A%26nbsp%3B%20Potentiometers%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20--%26gt%3B%20ADC%20inputs%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20USER_DEV_RV2(J4-7)%20--%26gt%3B%20ANA_0%20(J18-3)%20DAN0%2B%20%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20USER_DEV_RV3(J4-8)%20--%26gt%3B%20ANA_1%20(J18-4)%20DAN0-%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Buttons%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20--%26gt%3B%20ADC%20triggers%3CBR%20%2F%3E*%20%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20USER_DEV_1D(J4-2)%26nbsp%3B%20--%26gt%3B%20TPU_A0%20(J22-1)%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎10-04-2017 04:56 AM
Updated by:
