Example MPC5646C Standby Wakeup To SRAM CW210
This example enters the MCU into STANDBY0 low power mode and wakes up to backup SRAM.
The WKPU6 (PE[0]pin) is used to wake up the MCU.
Petr
* Detailed Description:
* On the EVB use KEY2 to enter Standby.
* Use KEY1 to wake up from Standby to a code in backup SRAM.
* In RUN mode the LED1 blinks very fast, second core toggels LED3
* In STANDBY all LEDs are off.
* The wakeup code blinks LED1 and LED2 slowly.
* The macro WKP_CORE is used to select which core is used after MCU wakes up.
* When z4 core is selected, it is also necessary to set the MMU otherwise exception
* is generated when uncovered memory area is accessed.
* This is not needed for z0 core due to lack of the MMU.
* Test HW:  XPC56xxMB2 + XPC564xB/C, SPC5646C 0N32E silicon
* Target :  internal_FLASH
* Fsys:     120 MHz PLL0
Comments
Hello,I am using MPC5646C board, but I have a problem that I can not communicate using FlexRay protocol. In other words. would you like to help me to  supply FlexRay program in MPC5646C board. I have been always doing this work recently, but haven't any progress and  I am in a hurry ! So would you like to help me? Hope to your response!
HI,I am using the board MPC5646c.I am facing  a  big  problem  that  I  want  to  achieve  the  filter  of  ID  in  CAN  protocol.For example,I want to receive the  frame of ID=5  ,at  the  same  time  ,I  also  want to receive  the  ID=6,So, the   other  ID should be  masked.IF  I  want   to  achieve  this goal,what should I  do??Please  help  me ,hope  your  resoponse.!
I  have   the  same  question!!!!
%3CLINGO-SUB%20id%3D%22lingo-sub-1114701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5646C%20Standby%20Wakeup%20To%20SRAM%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20example%20enters%20the%20MCU%20into%20STANDBY0%20low%20power%20mode%20and%20wakes%20up%20to%20backup%20SRAM.%3C%2FP%3E%3CP%3EThe%20WKPU6%20(PE%5B0%5Dpin)%20is%20used%20to%20wake%20up%20the%20MCU.%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3ERegards%2C%3C%2FP%3E%3CP%3EPetr%3C%2FP%3E%3CP%20style%3D%22min-%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20On%20the%20EVB%20use%20KEY2%20to%20enter%20Standby.%3C%2FP%3E%3CP%3E*%20Use%20KEY1%20to%20wake%20up%20from%20Standby%20to%20a%20code%20in%20backup%20SRAM.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20In%20RUN%20mode%20the%20LED1%20blinks%20very%20fast%2C%20second%20core%20toggels%20LED3%3C%2FP%3E%3CP%3E*%20In%20STANDBY%20all%20LEDs%20are%20off.%3C%2FP%3E%3CP%3E*%20The%20wakeup%20code%20blinks%20LED1%20and%20LED2%20slowly.%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20The%20macro%20WKP_CORE%20is%20used%20to%20select%20which%20core%20is%20used%20after%20MCU%20wakes%20up.%3C%2FP%3E%3CP%3E*%20When%20z4%20core%20is%20selected%2C%20it%20is%20also%20necessary%20to%20set%20the%20MMU%20otherwise%20exception%3C%2FP%3E%3CP%3E*%20is%20generated%20when%20uncovered%20memory%20area%20is%20accessed.%3C%2FP%3E%3CP%3E*%20This%20is%20not%20needed%20for%20z0%20core%20due%20to%20lack%20of%20the%20MMU.%26nbsp%3B%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%20XPC56xxMB2%20%2B%20XPC564xB%2FC%2C%20SPC5646C%200N32E%20silicon%3C%2FP%3E%3CP%3E*%20Target%20%3A%26nbsp%3B%20internal_FLASH%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20120%20MHz%20PLL0%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1114701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5646C%20Standby%20Wakeup%20To%20SRAM%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114704%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%26nbsp%3B%20have%26nbsp%3B%26nbsp%3B%20the%26nbsp%3B%20same%26nbsp%3B%20question!!!!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5646C%20Standby%20Wakeup%20To%20SRAM%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114703%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%2CI%20am%20using%20the%20board%20MPC5646c.I%20am%20facing%26nbsp%3B%20a%26nbsp%3B%20big%26nbsp%3B%20problem%26nbsp%3B%20that%26nbsp%3B%20I%26nbsp%3B%20want%26nbsp%3B%20to%26nbsp%3B%20achieve%26nbsp%3B%20the%26nbsp%3B%20filter%26nbsp%3B%20of%26nbsp%3B%20ID%26nbsp%3B%20in%26nbsp%3B%20CAN%26nbsp%3B%20%3CSPAN%20style%3D%22color%3A%20%2351626f%3B%20font-family%3A%20arial%2C%20helvetica%2C%20'helvetica%20neue'%2C%20verdana%2C%20sans-serif%3B%22%3Eprotocol.For%20example%2CI%20want%20to%20receive%20the%26nbsp%3B%20frame%20of%20ID%3D5%26nbsp%3B%20%2Cat%26nbsp%3B%20the%26nbsp%3B%20same%26nbsp%3B%20time%26nbsp%3B%20%2CI%26nbsp%3B%20also%26nbsp%3B%20want%20to%20receive%26nbsp%3B%20the%26nbsp%3B%20ID%3D6%2CSo%2C%20the%26nbsp%3B%26nbsp%3B%20other%26nbsp%3B%20ID%20should%20be%26nbsp%3B%20masked.IF%26nbsp%3B%20I%26nbsp%3B%20want%26nbsp%3B%26nbsp%3B%20to%26nbsp%3B%20achieve%26nbsp%3B%20this%20goal%2Cwhat%20should%20I%26nbsp%3B%20do%3F%3FPlease%26nbsp%3B%20help%26nbsp%3B%20me%20%2Chope%26nbsp%3B%20your%26nbsp%3B%20resoponse.!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1114702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5646C%20Standby%20Wakeup%20To%20SRAM%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1114702%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2CI%20am%20using%20MPC5646C%20board%2C%20but%20I%20have%20a%20problem%20that%20I%20can%20not%20communicate%20using%20FlexRay%20protocol.%20In%20other%20words.%20would%20you%20like%20to%20help%20me%20to%26nbsp%3B%20supply%20FlexRay%20program%20in%20MPC5646C%20board.%20I%20have%20been%20always%20doing%20this%20work%20recently%2C%20but%20haven't%20any%20progress%20and%26nbsp%3B%20I%20am%20in%20a%20hurry%20!%20So%20would%20you%20like%20to%20help%20me%3F%20Hope%20to%20your%20response!%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎07-17-2014 04:27 AM
Updated by:
