Example MPC5644A TSENS Temperature calculation CW210
* Detailed Description:
* Example shows MCU's temperature measurement with the help of TSENS.
* Calibration constants for TSENS are read from TSENS registers and
* eQADC is set to measure Vbg and TSENS outputs. eQADC calibration is also done.
* Calculated internal temperature can be displayed on the Terminal.
* See results on PC terminal (19200, 8N1, None). You should see following text
* (with different values for sure)
*    fsys = 150MHz
*    TSENS temperature calculation
*    Calibration constants read from TSENS registers
*    T_LOW = 25
*    T_HIGH = 145
*    TSENS_CODE_T_LOW = 5441
*    TSENS_CODE_T_HIGH = 7305
*    VBG_CODE_T_LOW = 4010
*                 (TSENS_CODE_T*beta - TSENS_CODE_T_LOW)*(T_HIGH - T_LOW)
*    T = T_LOW - --------------------------------------------------------- [degC]
*                       (TSENS_CODE_T_HIGH - TSENS_CODE_T_LOW)
*    VBG_CODE_T (ch45)  = 3959 => beta = 1.01288
*    TSENS_CODE_T (ch128) = 5608
*    Temp = 31.80 degC
* Test HW:        XPC564AKIT208S and XPC564AKIT324S
* MCU:            SPC5644AMMG1,0M14X and SPC5644AMVZ1,0M14X
* Fsys:           150/132/120/12 MHz
* Debugger:       Lauterbach Trace32
*                 PeMicro USB-ML-PPCNEXUS
* Target:         RAM, internal_FLASH
* Terminal:       19200-8-no parity-1 stop bit-no flow control on eSCI_A
* EVB connection: default
添付
コメント
ok!!!!!!!!!!!!!!!!!!!!!!!
%3CLINGO-SUB%20id%3D%22lingo-sub-1109898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8BMPC5644A%20TSENS%E6%B8%A9%E5%BA%A6%E8%A8%88%E7%AE%97CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1109898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E*%20%E4%BE%8B%E3%81%AF%E3%80%81TSENS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FMCU%E3%81%AE%E6%B8%A9%E5%BA%A6%E6%B8%AC%E5%AE%9A%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%20TSENS%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%AE%9A%E6%95%B0%E3%81%AF%E3%80%81TSENS%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%80%81%3C%2FP%3E%3CP%3E*%20eQADC%E3%81%AF%E3%80%81Vbg%E3%81%8A%E3%82%88%E3%81%B3TSENS%E5%87%BA%E5%8A%9B%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82eQADC%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%82%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BB%E8%A8%88%E7%AE%97%E3%81%97%E3%81%9F%E5%86%85%E9%83%A8%E6%B8%A9%E5%BA%A6%E3%82%92%E7%AB%AF%E6%9C%AB%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E%E2%80%BBPC%E7%AB%AF%E6%9C%AB(19200%E3%80%818N1%E3%80%81%E3%81%AA%E3%81%97)%E3%81%A7%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%AC%A1%E3%81%AE%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*(%E7%A2%BA%E3%81%8B%E3%81%AB%E5%80%A4%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20fsys%20%3D%20150MHz%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20TSENS%E6%B8%A9%E5%BA%A6%E8%A8%88%E7%AE%97%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20TSENS%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%AE%9A%E6%95%B0%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20T_LOW%20%3D%2025%3C%2FP%3E%3CP%3E*%20T_HIGH%20%3D%20145%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T_LOW%20%3D%205441%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T_HIGH%20%3D%207305%3C%2FP%3E%3CP%3E*%20VBG_CODE_T_LOW%20%3D%204010%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*(TSENS_CODE_T*%E3%83%99%E3%83%BC%E3%82%BF-TSENS_CODE_T_LOW)*(T_HIGH-T_LOW)%3C%2FP%3E%3CP%3E*%20T%20%3D%20T_LOW%20-%20---------------------------------------------------------%20%5B%C2%B0C%5D%3C%2FP%3E%3CP%3E*(TSENS_CODE_T_HIGH%E3%80%9CTSENS_CODE_T_LOW)%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20VBG_CODE_T%20(CH45)%20%3D%203959%20%3D%20%26gt%3B%E3%83%99%E3%83%BC%E3%82%BF%20%3D%201.01288%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T%20(CH128)%20%3D%205608%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E6%B8%A9%E5%BA%A6%20%3D%2031.80%C2%B0C%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AXPC564AKIT208S%E3%81%8A%E3%82%88%E3%81%B3XPC564AKIT324S%3C%2FP%3E%3CP%3E*%20MCU%3ASPC5644AMMG1%2C0M14X%E3%81%8A%E3%82%88%E3%81%B3SPC5644AMVZ1%2C0M14X%3C%2FP%3E%3CP%3E*%20Fsys%3A150%2F132%2F120%2F12%20MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%E5%AF%BE%E8%B1%A1%3ARAM%E3%80%81internal_FLASH%3C%2FP%3E%3CP%3E*%E7%AB%AF%E6%9C%AB%3A19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-eSCI_A%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1109898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E*%20%E4%BE%8B%E3%81%AF%E3%80%81TSENS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FMCU%E3%81%AE%E6%B8%A9%E5%BA%A6%E6%B8%AC%E5%AE%9A%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%20TSENS%E3%81%AE%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%AE%9A%E6%95%B0%E3%81%AF%E3%80%81TSENS%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%80%81%3C%2FP%3E%3CP%3E*%20eQADC%E3%81%AF%E3%80%81Vbg%E3%81%8A%E3%82%88%E3%81%B3TSENS%E5%87%BA%E5%8A%9B%E3%82%92%E6%B8%AC%E5%AE%9A%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82eQADC%20%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%82%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BB%E8%A8%88%E7%AE%97%E3%81%97%E3%81%9F%E5%86%85%E9%83%A8%E6%B8%A9%E5%BA%A6%E3%82%92%E7%AB%AF%E6%9C%AB%E3%81%AB%E8%A1%A8%E7%A4%BA%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E%E2%80%BBPC%E7%AB%AF%E6%9C%AB(19200%E3%80%818N1%E3%80%81%E3%81%AA%E3%81%97)%E3%81%A7%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E6%AC%A1%E3%81%AE%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*(%E7%A2%BA%E3%81%8B%E3%81%AB%E5%80%A4%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99)%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20fsys%20%3D%20150MHz%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20TSENS%E6%B8%A9%E5%BA%A6%E8%A8%88%E7%AE%97%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20TSENS%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%8B%E3%82%89%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F%E3%82%AD%E3%83%A3%E3%83%AA%E3%83%96%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%AE%9A%E6%95%B0%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20T_LOW%20%3D%2025%3C%2FP%3E%3CP%3E*%20T_HIGH%20%3D%20145%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T_LOW%20%3D%205441%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T_HIGH%20%3D%207305%3C%2FP%3E%3CP%3E*%20VBG_CODE_T_LOW%20%3D%204010%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*(TSENS_CODE_T*%E3%83%99%E3%83%BC%E3%82%BF-TSENS_CODE_T_LOW)*(T_HIGH-T_LOW)%3C%2FP%3E%3CP%3E*%20T%20%3D%20T_LOW%20-%20---------------------------------------------------------%20%5B%C2%B0C%5D%3C%2FP%3E%3CP%3E*(TSENS_CODE_T_HIGH%E3%80%9CTSENS_CODE_T_LOW)%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20VBG_CODE_T%20(CH45)%20%3D%203959%20%3D%20%26gt%3B%E3%83%99%E3%83%BC%E3%82%BF%20%3D%201.01288%3C%2FP%3E%3CP%3E*%20TSENS_CODE_T%20(CH128)%20%3D%205608%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E6%B8%A9%E5%BA%A6%20%3D%2031.80%C2%B0C%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AXPC564AKIT208S%E3%81%8A%E3%82%88%E3%81%B3XPC564AKIT324S%3C%2FP%3E%3CP%3E*%20MCU%3ASPC5644AMMG1%2C0M14X%E3%81%8A%E3%82%88%E3%81%B3SPC5644AMVZ1%2C0M14X%3C%2FP%3E%3CP%3E*%20Fsys%3A150%2F132%2F120%2F12%20MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%E5%AF%BE%E8%B1%A1%3ARAM%E3%80%81internal_FLASH%3C%2FP%3E%3CP%3E*%E7%AB%AF%E6%9C%AB%3A19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-eSCI_A%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1109898%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
評価なし
バージョン履歴
最終更新日:
‎04-22-2015 01:57 AM
更新者:
