Example MPC5606S-STOP_mode_implementation CW210
Detailed Description:
* This example shows, how to configure Mode entry module and enable required
* peripherals only. RTC module is configured to create interrupt every 50ms.
* Microcontroller is in in STOP mode most of the time and it is waken-up using RTC
* interrupt.
* Test HW:         XPC560S 144LQFP, XPC56XX EVB MOTHEBOARD Rev.C
* MCU:             PPC5606S 0M25V
* Terminal:
* Fsys:            16MHz IRC
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          RAM, internal_FLASH
* EVB connection:  Default
%3CLINGO-SUB%20id%3D%22lingo-sub-1115098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5606S-STOP_mode_implementation%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1115098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDetailed%20Description%3A%3CBR%20%2F%3E*%20This%20example%20shows%2C%20how%20to%20configure%20Mode%20entry%20module%20and%20enable%20required%20%3CBR%20%2F%3E*%20peripherals%20only.%20RTC%20module%20is%20configured%20to%20create%20interrupt%20every%2050ms.%3CBR%20%2F%3E*%20Microcontroller%20is%20in%26nbsp%3Bin%20STOP%20mode%20most%20of%20the%20time%20and%20it%20is%20waken-up%20using%20RTC%3CBR%20%2F%3E*%20interrupt.%20%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20XPC560S%20144LQFP%2C%20XPC56XX%20EVB%20MOTHEBOARD%20Rev.C%3CBR%20%2F%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5606S%200M25V%3CBR%20%2F%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2016MHz%20IRC%3CBR%20%2F%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3CBR%20%2F%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3CBR%20%2F%3E*%20EVB%20connection%3A%26nbsp%3B%20Default%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1115098%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDetailed%20Description%3A%3CBR%20%2F%3E*%20This%20example%20shows%2C%20how%20to%20configure%20Mode%20entry%20module%20and%20enable%20required%20%3CBR%20%2F%3E*%20peripherals%20only.%20RTC%20module%20is%20configured%20to%20create%20interrupt%20every%2050ms.%3CBR%20%2F%3E*%20Microcontroller%20is%20in%26nbsp%3Bin%20STOP%20mode%20most%20of%20the%20time%20and%20it%20is%20waken-up%20using%20RTC%3CBR%20%2F%3E*%20interrupt.%20%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20XPC560S%20144LQFP%2C%20XPC56XX%20EVB%20MOTHEBOARD%20Rev.C%3CBR%20%2F%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5606S%200M25V%3CBR%20%2F%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%3CBR%20%2F%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2016MHz%20IRC%3CBR%20%2F%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3CBR%20%2F%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3CBR%20%2F%3E*%20EVB%20connection%3A%26nbsp%3B%20Default%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E
No ratings
Version history
Last update:
‎04-27-2017 11:45 PM
Updated by:
