how to install MCUXpresso Installer on ubuntu
694 次查看
sukhwan
I followed description at https://github.com/nxp-mcuxpresso/vscode-for-mcux/wiki/Dependency-Installation. Downloaded MCUXpressoInstaller.deb.bin for Ubuntu. I ran following commands to install it. But I had fails. how to install it on Ubuntu?
<1st command>
./SSD2TB_LINK/projects/tools/nxp/MCUXpressoInstaller.deb.bin
Verifying archive integrity... 100% All good.
Uncompressing MCUXpresso Installer 100%
Please run as root!
<2nd command>
sudo ./SSD2TB_LINK/projects/tools/nxp/MCUXpressoInstaller.deb.bin
Unpackaging...
INFO: Installation directory: /home/sukhwan.y/MCUXpressoInstaller
INFO: To start the installer, please run /home/sukhwan.y/MCUXpressoInstaller/MCUXpressoInstaller
chown: invalid group: ‘sukhwan.y:sukhwan.y’
<3rd command>
$ ~/MCUXpressoInstaller/MCUXpressoInstaller
TypeError: Cannot read properties of undefined (reading 'toString')
at w (/home/sukhwan.y/MCUXpressoInstaller/resources/app/main.js:2:1187313)
at C (/home/sukhwan.y/MCUXpressoInstaller/resources/app/main.js:2:1188037)
at S (/home/sukhwan.y/MCUXpressoInstaller/resources/app/main.js:2:1187998)
at Object.error (/home/sukhwan.y/MCUXpressoInstaller/resources/app/main.js:2:1188208)
at process.<anonymous> (/home/sukhwan.y/MCUXpressoInstaller/resources/app/main.js:2:1274420)
at process.emit (node:events:518:28)
at emitUnhandledRejection (node:internal/process/promises:252:13)
at warnWithErrorCodeUnhandledRejectionsMode (node:internal/process/promises:407:19)
at processPromiseRejections (node:internal/process/promises:475:17)
at process.processTicksAndRejections (node:internal/process/task_queues:106:32)
error: Uncaught rejection with reason: Error: EACCES: permission denied, mkdir '/home/sukhwan.y/MCUXpressoInstaller/logs' {"errno":-13,"code":"EACCES","syscall":"mkdir","path":"/home/sukhwan.y/MCUXpressoInstaller/logs"}
<4th command>
~ sudo ~/MCUXpressoInstaller/MCUXpressoInstaller
[0729/181424.604549:FATAL:electron/shell/app/electron_main_delegate.cc:288] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
Trace/breakpoint trap
标签 (1)
标记 (1)
3 回复数
658 次查看
sukhwan
I have a question about the end of the response for "sudo ./SSD2TB_LINK/projects/tools/nxp/MCUXpressoInstaller.deb.bin" , which is "chown: invalid group: ‘sukhwan.y:sukhwan.y’"
My account is in the group of "ab02_sra_allusers". It looks it matters user group, doesn't it?
Unpackaging...
$ ll ~/MCUXpressoInstaller
total 228180
drwxr-xr-x 9 root root 4096 Jun 30 01:35 ./
drwxr-x--- 47 sukhwan.y ab02_sra_allusers 4096 Jul 31 14:01 ../
-rw-r--r-- 1 root root 9 Jun 30 01:35 buildnumber.txt
-rw-r--r-- 1 root root 0 Jun 30 01:35 .changelog
 Thanks.
622 次查看
Harry_Zhang
Hi @sukhwan
Yes, you're exactly right — the error message:
means the installer tried to set the ownership of a file or directory using a user:group pair (sukhwan.y:sukhwan.y), but the group sukhwan.y does not exist on your system.
I think it doesn't block the installer from working — it just means ownership wasn’t set correctly.
You can fix it by manually running chown with your real group.
Harry
670 次查看
Harry_Zhang
Hi @sukhwan
I tested it just now.
I downloaded the MCUXpressoInstaller.deb.bin.
zhangh@tic-public:~/software$ ./MCUXpressoInstaller.deb.bin
Please run as root!
zhangh@tic-public:~/software$ sudo ./MCUXpressoInstaller.deb.bin
Unpackaging...
INFO: Installation directory: /home/zhangh/MCUXpressoInstaller
INFO: To start the installer, please run /home/zhangh/MCUXpressoInstaller/MCUXpressoInstaller
And i try to run /home/zhangh/MCUXpressoInstaller/MCUXpressoInstaller
It can work.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2143739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%9C%A8%20ubuntu%20%E4%B8%8A%E5%AE%89%E8%A3%85%20MCUXpresso%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%9C%A8%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fvscode-for-mcux%2Fwiki%2FDependency-Installation%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-mcuxpresso%2Fvscode-for-mcux%2Fwiki%2FDependency-Installation%3C%2FA%3E%20%E4%B8%8A%E7%9C%8B%E5%88%B0%E4%BA%86%E7%9B%B8%E5%85%B3%E8%AF%B4%E6%98%8E%E3%80%82%E4%B8%BA%20Ubuntu%20%E4%B8%8B%E8%BD%BD%20MCUXpressoInstaller.deb.bin%E3%80%82%E6%88%91%E8%BF%90%E8%A1%8C%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E8%BF%9B%E8%A1%8C%E5%AE%89%E8%A3%85%E3%80%82%E4%BD%86%E6%88%91%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%E5%A6%82%E4%BD%95%E5%9C%A8%20Ubuntu%20%E4%B8%8A%E5%AE%89%E8%A3%85%EF%BC%9F%3C%2FP%3E%3CP%3E%26lt%3B1st%20command%26gt%3B%3C%2FP%3E%3CP%3E.%2FSSD2TB_LINK%2Fprojects%2Ftools%2Fnxp%2FMCUXpressoInstaller.deb.bin%3CBR%20%2F%3E%E9%AA%8C%E8%AF%81%E5%AD%98%E6%A1%A3%E5%AE%8C%E6%95%B4%E6%80%A7...100%25%20%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%E8%A7%A3%E5%8E%8B%E7%BC%A9%20MCUXpresso%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%20100%25%3CBR%20%2F%3E%20%E8%AF%B7%E4%BB%A5%E6%A0%B9%E7%94%A8%E6%88%B7%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%EF%BC%81%3C%2FP%3E%3CP%3E%26lt%3B2nd%20command%26gt%3B%3C%2FP%3E%3CP%3Esudo%20.%2FSSD2TB_LINK%2Fprojects%2Ftools%2Fnxp%2FMCUXpressoInstaller.deb.bin%3CBR%20%2F%3E%E9%AA%8C%E8%AF%81%E5%AD%98%E6%A1%A3%E5%AE%8C%E6%95%B4%E6%80%A7...100%25%20%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%E8%A7%A3%E5%8E%8B%E7%BC%A9%20MCUXpresso%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%20100%25%3CBR%20%2F%3E%20%E8%A7%A3%E5%8E%8B%E7%BC%A9...%3CBR%20%2F%3EINFO%EF%BC%9A%E5%AE%89%E8%A3%85%E7%9B%AE%E5%BD%95%EF%BC%9A%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%3CBR%20%2F%3EINFO%EF%BC%9A%E8%A6%81%E5%90%AF%E5%8A%A8%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%AF%B7%E8%BF%90%E8%A1%8C%20%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%2FMCUXpressoInstaller%3CBR%20%2F%3Echown%3A%20%E6%97%A0%E6%95%88%E7%BB%84%EF%BC%9A'sukhwan.y%3Asukhwan.y'%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26lt%3B3rd%20command%26gt%3B%3C%2FP%3E%3CP%3E%24%20~%2FMCUXpressoInstaller%2FMCUXpressoInstaller%3CBR%20%2F%3ETypeError%EF%BC%9A%E6%97%A0%E6%B3%95%E8%AF%BB%E5%8F%96%E6%9C%AA%E5%AE%9A%E4%B9%89%E7%9A%84%E5%B1%9E%E6%80%A7%EF%BC%88%E8%AF%BB%E5%8F%96'toString'%EF%BC%89%3CBR%20%2F%3Eat%20w%20(%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%2Fresources%2Fapp%2Fmain.js%3A2%3A1187313)%3CBR%20%2F%3Eat%20C%20(%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%2Fresources%2Fapp%2Fmain.js%3A2%3A1188037)%3CBR%20%2F%3Eat%20S%20(%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%2Fresources%2Fapp%2Fmain.js%3A2%3A1187998)%3CBR%20%2F%3Eat%20Object.error%20(%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%2Fresources%2Fapp%2Fmain.js%3A2%3A1188208)%3CBR%20%2F%3Eat%20process.%3CANONYMOUS%3E%20(%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%2Fresources%2Fapp%2Fmain.js%3A2%3A1274420)%3CBR%20%2F%3Eat%20process.emit%20(node%3Aevents%3A518%3A28)%3CBR%20%2F%3Eat%20emitUnhandledRejection%20(node%3Ainternal%2Fprocess%2Fpromises%3A252%3A13)%3CBR%20%2F%3Eat%20warnWithErrorCodeUnhandledRejectionsMode%20(node%3Ainternal%2Fprocess%2Fpromises%3A407%3A19)%3CBR%20%2F%3Eat%20processPromiseRejections%20(node%3Ainternal%2Fprocess%2Fpromises%3A475%3A17)%3CBR%20%2F%3Eat%20process.processTicksAndRejections%20(node%3Ainternal%2Fprocess%2Ftask_queues%3A106%3A32)%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E6%9C%AA%E6%8D%95%E8%8E%B7%E7%9A%84%E6%8B%92%E7%BB%9D%EF%BC%8C%E5%8E%9F%E5%9B%A0%E6%98%AF%EF%BC%9AError%EF%BC%9AEACCES%3A%20permission%20denied%2C%20mkdir%20'%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%2Flogs'.%7B%22errno%22%3A-13%2C%22code%22%3A%22EACCES%22%2C%22syscall%22%3A%22mkdir%22%2C%22path%22%3A%22%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%2Flogs%22%7D%3C%2FANONYMOUS%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%26lt%3B4th%20command%26gt%3B%3C%2FP%3E%3CP%3E~%20sudo%20~%2FMCUXpressoInstaller%2FMCUXpressoInstaller%3CBR%20%2F%3E%5B0729%2F181424.604549%3AFATAL%3Aelectron%2Fshell%2Fapp%2Felectron_main_delegate.cc%3A288%5D%E4%B8%8D%E6%94%AF%E6%8C%81%E4%B8%8D%E5%B8%A6%20--no-sandbox%20%E7%9A%84%20root%20%E8%BF%90%E8%A1%8C%E3%80%82%E8%A7%81%3CA%20href%3D%22https%3A%2F%2Fcrbug.com%2F638180%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fcrbug.com%2F638180%E3%80%82%3C%2FA%3E%3CBR%20%2F%3E%E8%B7%9F%E8%B8%AA%2F%E6%96%AD%E7%82%B9%E9%99%B7%E9%98%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2143739%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCXC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146089%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20install%20MCUXpresso%20Installer%20on%20ubuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146089%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252274%22%20target%3D%22_blank%22%3E%40sukhwan%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E8%AF%B4%E5%BE%97%E5%BE%88%E5%AF%B9%EF%BC%8C%E5%B0%B1%E6%98%AF%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%0A%3CP%3Echown%3A%20%E6%97%A0%E6%95%88%E7%BB%84%EF%BC%9A'sukhwan.y%3Asukhwan.y'%3C%2FP%3E%0A%3CP%3E%E8%A1%A8%E7%A4%BA%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E7%94%A8%E6%88%B7%EF%BC%9A%E7%BB%84%E5%AF%B9%EF%BC%88sukhwan.y%3Asukhwan.y%EF%BC%89%E8%AE%BE%E7%BD%AE%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%E7%9A%84%E6%89%80%E6%9C%89%E6%9D%83%E3%80%81%E4%BD%86%E6%98%AF%EF%BC%8Csukhwan.y%20%E5%B0%8F%E7%BB%84%E5%9C%A8%E6%82%A8%E7%9A%84%E7%B3%BB%E7%BB%9F%E4%B8%AD%E4%B8%8D%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E5%B9%B6%E4%B8%8D%E4%BC%9A%E9%98%BB%E6%AD%A2%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%E5%B7%A5%E4%BD%9C%EF%BC%8C%E8%80%8C%E5%8F%AA%E6%98%AF%E6%84%8F%E5%91%B3%E7%9D%80%E6%89%80%E6%9C%89%E6%9D%83%E8%AE%BE%E7%BD%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E7%9C%9F%E5%AE%9E%E7%BB%84%E6%89%8B%E5%8A%A8%E8%BF%90%E8%A1%8C%20chown%20%E6%9D%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20install%20MCUXpresso%20Installer%20on%20ubuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144750%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%AF%B9%22%20sudo%3CEM%3E.%2FSSD2TB_LINK%2Fprojects%2Ftools%2Fnxp%2FMCUXpressoInstaller.deb.bin%20%E7%9A%84%3C%2FEM%3E%E5%93%8D%E5%BA%94%E7%BB%93%E5%B0%BE%E6%9C%89%E7%96%91%E9%97%AE%22%E6%98%AF%22%3CSTRONG%3E%3CEM%3Echown%3A%20%E6%97%A0%E6%95%88%20group%3A%20'sukhwan.y%3Asukhwan.y'%22%3C%2FEM%3E%20%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E8%B4%A6%E6%88%B7%E5%B1%9E%E4%BA%8E%22%3CEM%3Eab02_sra_allusers%22%3C%2FEM%3E%E7%BB%84%E3%80%82%E5%AE%83%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%BE%88%E9%87%8D%E8%A6%81%E7%9A%84%E7%94%A8%E6%88%B7%E7%BB%84%EF%BC%8C%E4%B8%8D%E6%98%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBLOCKQUOTE%3E%3CBR%20%2F%3E%3CP%3E%3CBR%20%2F%3E%3CEM%3Esudo%20.%2FSSD2TB_LINK%2Fprojects%2Ftools%2Fnxp%2FMCUXpressoInstaller.deb.bin%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E9%AA%8C%E8%AF%81%E5%AD%98%E6%A1%A3%E5%AE%8C%E6%95%B4%E6%80%A7...100%25%20%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E8%A7%A3%E5%8E%8B%E7%BC%A9%20MCUXpresso%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%20100%25%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%E8%A7%A3%E5%8E%8B...%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EINFO%EF%BC%9A%E5%AE%89%E8%A3%85%E7%9B%AE%E5%BD%95%EF%BC%9A%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3EINFO%EF%BC%9A%E8%A6%81%E5%90%AF%E5%8A%A8%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%AF%B7%E8%BF%90%E8%A1%8C%20%2Fhome%2Fsukhwan.y%2FMCUXpressoInstaller%2FMCUXpressoInstaller%3C%2FEM%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CEM%3Echown%3A%20%E6%97%A0%E6%95%88%E7%BB%84%EF%BC%9A'sukhwan.y%3Asukhwan.y'%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3CEM%3E%24%20ll%20~%2FMCUXpressoInstaller%3C%2FEM%3E%3CSTRONG%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3CEM%3E%E6%80%BB%E8%AE%A1%20228180%3C%2FEM%3E%3CEM%3E%3CBR%20%2F%3Edrwxr-xr-x%209%20root%20root%204096%20Jun%2030%2001%3A35%20.%2F%3CBR%20%2F%3Edrwxr-x---%2047%20sukhwan.y%20ab02_sra_allusers%204096%20Jul%2031%2014%3A01%20.%2F%3CBR%20%2F%3E-rw-r--r--%201%20root%20root%209%20Jun%2030%2001%3A35%20buildnumber.txt%3CBR%20%2F%3E%3C%2FEM%3E%3CEM%3E-rw-r--r--%201%20root%20root%200%20Jun%2030%2001%3A35%20.changelog%3C%2FEM%3E%3CSTRONG%3E%3CEM%3E%3CBR%20%2F%3E%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20how%20to%20install%20MCUXpresso%20Installer%20on%20ubuntu%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144069%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F252274%22%20target%3D%22_blank%22%3E%40sukhwan%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%88%9A%E6%89%8D%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%B8%8B%E8%BD%BD%E4%BA%86%20MCUXpressoInstaller.deb.bin%E3%80%82%3C%2FP%3E%0A%3CP%3Ezhangh%40tic-public%3A~%2Fsoftware%24%20.%2FMCUXpressoInstaller.deb.bin%3CBR%20%2F%3E%E9%AA%8C%E8%AF%81%E5%AD%98%E6%A1%A3%E5%AE%8C%E6%95%B4%E6%80%A7...100%25%20%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%E8%A7%A3%E5%8E%8B%E7%BC%A9%20MCUXpresso%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%20100%25%3CBR%20%2F%3E%20%E8%AF%B7%E4%BB%A5%E6%A0%B9%E7%94%A8%E6%88%B7%E8%BA%AB%E4%BB%BD%E8%BF%90%E8%A1%8C%EF%BC%81%3CBR%20%2F%3Ezhangh%40tic-public%3A~%2Fsoftware%24%20sudo%20.%2FMCUXpressoInstaller.deb.bin%3CBR%20%2F%3E%E9%AA%8C%E8%AF%81%E5%AD%98%E6%A1%A3%E5%AE%8C%E6%95%B4%E6%80%A7...100%25%20%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%3CBR%20%2F%3E%E8%A7%A3%E5%8E%8B%E7%BC%A9%20MCUXpresso%20%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%20100%25%3CBR%20%2F%3E%20%E8%A7%A3%E5%8E%8B%E7%BC%A9...%3CBR%20%2F%3EINFO%EF%BC%9A%E5%AE%89%E8%A3%85%E7%9B%AE%E5%BD%95%EF%BC%9A%2Fhome%2Fzhangh%2FMCUXpressoInstaller%3CBR%20%2F%3EINFO%EF%BC%9A%E8%A6%81%E5%90%AF%E5%8A%A8%E5%AE%89%E8%A3%85%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%AF%B7%E8%BF%90%E8%A1%8C%20%2Fhome%2Fzhangh%2FMCUXpressoInstaller%2FMCUXpressoInstaller%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%20%2Fhome%2Fzhangh%2FMCUXpressoInstaller%2FMCUXpressoInstaller%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1753930349632.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1753930349632.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350361i94841C2D3C616C73%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1753930349632.png%22%20alt%3D%22Harry_Zhang_0-1753930349632.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%AE%83%E8%83%BD%E5%8F%91%E6%8C%A5%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
