Writing QSPI Flash on MCXN947 board.
8,854件の閲覧回数
takagi_y
The other day I asked a question about writing flash to FRDM-MCXN947.
Thanks to your answer, I am now able to write to FRDM-MCXN947.
Thank you.
This time I would like to ask a question about writing flash to another board using MCXN947.
I tried to write to this board using the writing method for FRDM-MCXN947 as a reference, but an error occurred.
Below is the content of the console at that time.
NXP: MCXN947
DAP stride is 1024 bytes (256 words)
Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MCXN9xx_SFDP_FlexSPI.cfx
Image 'MCXN9xx_SFDP_FlexSPI Sep 19 2024 18:18:31'
Opening flash driver MCXN9xx_SFDP_FlexSPI.cfx
VECTRESET requested, but not supported on ARMv8-M CPUs. Using SOFTRESET instead.
Using SOFT reset to run the flash driver
Driver V.2 dynamic startup failed - driver Init provided no flash parameters
driver describes no sectors starting at 0x80000000
Flash Driver V.2 startup failed - rc Ef(58): Flash Driver describes no sectors at its base address
chip initialization failed - Ef(58): Flash Driver describes no sectors at its base address
failed to initialize flash driver MCXN9xx_SFDP_FlexSPI.cfx
Is there any setting or anything I need to do?
I would appreciate your reply.
7,784件の閲覧回数
Harry_Zhang
Hi @takagi_y
You can write from the SEC tool, this proves that the FCB produced by SEC is correct.
So i think you can flash the correct FCB to 0x80000400.
And then delete mcxn_flexspi_nor_config.c and mcxn_flexspi_nor_config.h in MCUXpresso.
Because they generate the NEW FCB and flash in 0x80000400.
And you can debug it.
I tested, i generate the FCB.bin through the SEC tool. and flash it into 0x80000400.
And i can debug it successfully.
To summarize, put the correct FCB into 0x80000400, and put the correct application into 0x80001000.
Harry
23 返答(返信)
8,137件の閲覧回数
Harry_Zhang
HI @takagi_y
"I tried to write to this board using the writing method for FRDM-MCXN947 as a reference, but an error occurred."
You change to another board.
Did you try the same method but not succeed?
Harry
8,119件の閲覧回数
takagi_y
Thank you for your reply.
I modified the project with reference to the demo program of FRDM-MCXN947 and confirmed writing from IDE.
The procedure is as written yesterday under "As additional information...".
My board uses MX25L3233F for Flash, so I built an example of CMSIS-DAP Flash Drivers and checked it.
First, I used the one I built without any modifications and wrote it from the IDE. (CONFIG_OPTION0=0xC0000001)
As a result, the following was displayed on the console and writing was not performed.
MCUXpresso IDE RedlinkMulti Driver v24.9 (Sep 19 2024 19:34:05 - crt_emu_cm_redlink build 802)
Found chip XML file in C:/WorkSpace/MCUX/MCUXpressoIDE_24.9.25/NX-N947/frdmmcxn947_hello_world_qspi_xip/Debug\MCXN947.xml
( 5) Remote configuration complete
Reconnected to existing LinkServer process.
Probe Firmware: MCU-LINK (r0FF) CMSIS-DAP V3.153 (NXP Semiconductors)
Serial Number: VUDADS0NIE0ZM
VID:PID: 1FC9:0143
USB Path: 0001:0008:00
Using memory from core 0 after searching for a good core
processor is in secure mode
debug interface type = CoreSight DP (DAP DP ID 6BA02477) over SWD TAP 0
processor type = Cortex-M33 (CPU ID 00000D21) on DAP AP 0
number of h/w breakpoints = 8
number of flash patches = 0
number of h/w watchpoints = 4
Probe(0): Connected&Reset. DpID: 6BA02477. CpuID: 00000D21. Info: <None>
Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled.
Content of CoreSight Debug ROM(s):
RBASE E00FE000: CID B105100D PID 0000095000 ROM (type 0x1)
ROM 1 E00FF000: CID B105100D PID 04000BB4C9 ROM (type 0x1)
ROM 2 E000E000: CID B105900D PID 04000BBD21 CSt ARM ARMv8-M type 0x0 Misc - Undefined
ROM 2 E0001000: CID B105900D PID 04000BBD21 CSt ARM DWTv2 type 0x0 Misc - Undefined
ROM 2 E0002000: CID B105900D PID 04000BBD21 CSt ARM FPBv2 type 0x0 Misc - Undefined
ROM 2 E0000000: CID B105900D PID 04000BBD21 CSt ARM ITMv2 type 0x43 Trace Source - Bus
ROM 2 E0041000: CID B105900D PID 04002BBD21 CSt ARM ETMv4.0 type 0x13 Trace Source - Core
ROM 2 E0042000: CID B105900D PID 04000BBD21 CSt ARM CTIv2 type 0x14 Debug Control - Trigger, e.g. ECT
ROM 1 E0040000: CID B105900D PID 04000BBD21 CSt type 0x11 Trace Sink - TPIU
ROM 1 E0044000: CID B105900D PID 04003BB908 CSt CSTF type 0x12 Trace Link - Trace funnel/router
ROM 1 E0045000: CID B105900D PID 04001BB961 CSt type 0x21 Trace Sink - ETB
NXP: MCXN947
Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MCXN9xx_SFDP_FlexSPI_.cfx
Image 'MCXN9xx_SFDP_FlexSPI Mar 6 2025 17:01:24'
Opening flash driver MCXN9xx_SFDP_FlexSPI_.cfx
Flash variant 'JEDEC_FlexSPI_Device' detected (0B = at 0x80000000)
failed to initialize flash driver MCXN9xx_SFDP_FlexSPI_.cfx
Flash variant 'JEDEC_FlexSPI_Device' detected (4MB = 64*64K at 0x80000000)
Closing flash driver MCXN9xx_SFDP_FlexSPI_.cfx
Next, I changed the setting value used in the SEC tool (CONFIG_OPTION0=0xC0000405) and checked, but writing was not performed here either.
(You can write with the SEC tool.)
The following is the console display at that time.
Found chip XML file in C:/WorkSpace/MCUX/MCUXpressoIDE_24.9.25/NX-N947/NX-N947_ledblinky/frdmmcxn947_led_blinky/Debug_NoRAM\MCXN947.xml
VID:PID: 1FC9:0143
( 30) Emulator Connected
NXP: MCXN947
Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx
Image 'MCXN9xx_SFDP_FlexSPI Mar 6 2025 18:26:01'
Opening flash driver MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx
failed to initialize flash driver MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx
Is it necessary to change anything other than CONFIG_OPTION0 for MX25L3233F?
8,101件の閲覧回数
Harry_Zhang
Hi @takagi_y
On FRDM-MCXN947, the Qflash is W25Q64JVSSIQ.
On your customer board, the qflash is MX25L3233F.
So you need to change the Flash burning algorithm.
Such as MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx
And in the mcxn_flexspi_nor_config.c
Change the LUT
Harry
8,039件の閲覧回数
takagi_y
I compared the data sheets for W25Q64JVSSIQ and MX25L3233F and confirmed that the LUT contents are the same.
Does the above mean that you need to change the code other than CONFIG_OPTION0 and CONFIG_OPTION1 in MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx?
Or does it mean that there are other files that need to be modified besides MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx?
If other files need to be modified, could you please let me know the files?
7,917件の閲覧回数
Harry_Zhang
Hi @takagi_y
Apart from MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx and mcxn_flexspi_nor_config.c, there are no other files that need to be modified.
"I compared the data sheets for W25Q64JVSSIQ and MX25L3233F and confirmed that the LUT contents are the same."
No, they are different.
You can refer to the flexspi_polling example, it includes the LUT of W25Q64JVSSIQ and MX25L3233F.
#if EXAMPLE_FLASH_TYPE == FLASH_W25Q64
/* W25Q64JVSSIQ */
const uint32_t customLUTOctalMode[CUSTOM_LUT_LENGTH] = {
    /* Read data */
    [4 * NOR_CMD_LUT_SEQ_IDX_READ] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0xEB, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_4PAD, 0x18),
    [4 * NOR_CMD_LUT_SEQ_IDX_READ + 1] = FLEXSPI_LUT_SEQ(
        kFLEXSPI_Command_MODE8_SDR, kFLEXSPI_4PAD, 0xF0, kFLEXSPI_Command_DUMMY_SDR, kFLEXSPI_4PAD, 0x04),
    [4 * NOR_CMD_LUT_SEQ_IDX_READ + 2] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_READ_SDR, kFLEXSPI_4PAD, 0x00, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /* Read status register */
    [4 * NOR_CMD_LUT_SEQ_IDX_READSTATUS] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x05, kFLEXSPI_Command_READ_SDR, kFLEXSPI_1PAD, 0x00),
    /* Write enable */
    [4 * NOR_CMD_LUT_SEQ_IDX_WRITEENABLE] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x06, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /* Write enable */
    [4 * NOR_CMD_LUT_SEQ_IDX_WRITEENABLE_OPI] =
    /* Read ID */
    [4 * NOR_CMD_LUT_SEQ_IDX_READID_OPI] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x9F, kFLEXSPI_Command_READ_SDR, kFLEXSPI_1PAD, 0x00),
    /* Sector erase */
    [4 * NOR_CMD_LUT_SEQ_IDX_ERASESECTOR] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x20, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
    /* Chip erase */
    [4 * NOR_CMD_LUT_SEQ_IDX_CHIPERASE] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x60, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /* Page program */
    [4 * NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x32, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
    [4 * NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM + 1] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_WRITE_SDR, kFLEXSPI_4PAD, 0x00, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /* Enter Quad mode */
    [4 * NOR_CMD_LUT_SEQ_IDX_ENTEROPI] =
    /*  Dummy write, do nothing when AHB write command is triggered. */
    [4 * NOR_CMD_LUT_SEQ_IDX_WRITE] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x0, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x0),
    /*  Read status register using Quad mode */
    [4 * NOR_CMD_LUT_SEQ_IDX_READSTATUS_OPI] =
#endif
#if EXAMPLE_FLASH_TYPE == FLASH_MT35XU512
/* MT35XU512ABA1G12 */
    /*  OPI DDR read */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0xCC, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0xCC),
        kFLEXSPI_Command_RADDR_DDR, kFLEXSPI_8PAD, 0x20, kFLEXSPI_Command_DUMMY_DDR, kFLEXSPI_8PAD, 0x0D),
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_READ_DDR, kFLEXSPI_8PAD, 0x00, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /* Write Enable */
    /* Read ID under octal mode */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x9F, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x9F),
    [4 * NOR_CMD_LUT_SEQ_IDX_READID_OPI + 1] = FLEXSPI_LUT_SEQ(
        kFLEXSPI_Command_DUMMY_DDR, kFLEXSPI_8PAD, 0x10, kFLEXSPI_Command_READ_DDR, kFLEXSPI_8PAD, 0x00),
    /*  Write Enable */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x06, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x06),
    /*  Erase Sector */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x20, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x20),
    [4 * NOR_CMD_LUT_SEQ_IDX_ERASESECTOR + 1] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_RADDR_DDR, kFLEXSPI_8PAD, 0x20, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /*  Erase Chip */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x60, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x60),
    /*  Program */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x8E, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x8E),
    [4 * NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM + 1] = FLEXSPI_LUT_SEQ(
        kFLEXSPI_Command_RADDR_DDR, kFLEXSPI_8PAD, 0x20, kFLEXSPI_Command_WRITE_DDR, kFLEXSPI_8PAD, 0x00),
    /* Enter OPI mode */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR, kFLEXSPI_1PAD, 0x81, kFLEXSPI_Command_RADDR_SDR, kFLEXSPI_1PAD, 0x18),
    [4 * NOR_CMD_LUT_SEQ_IDX_ENTEROPI + 1] =
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_WRITE_SDR, kFLEXSPI_1PAD, 0x00, kFLEXSPI_Command_STOP, kFLEXSPI_1PAD, 0x00),
    /*  Read status register using Octal DDR read */
        FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x05, kFLEXSPI_Command_DDR, kFLEXSPI_8PAD, 0x05),
    [4 * NOR_CMD_LUT_SEQ_IDX_READSTATUS_OPI + 1] = FLEXSPI_LUT_SEQ(
#endif
Harry
7,789件の閲覧回数
takagi_y
I have checked the example you provided.
The Flash I want to use is MX25L3233F.
The example you provided is for MT35XU512ABA, which is a different model number.
The following is an excerpt of the MX25L3233F command, which is the same as the MT35XU512ABA command.
It is MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx, but do I need to make any changes other than to FlashConfig.h?
7,730件の閲覧回数
Harry_Zhang
Hi @takagi_y
Apart from MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx and  FlashConfig.h, there are no other files that need to be modified.
Harry
7,629件の閲覧回数
takagi_y
I have only modified the two files you mentioned, but the error still occurs.
I will upload the files I am using and the error message.
I cannot identify the reason why the Flash Driver V2 fails to start, so please give me some advice.
In this file, the value of sflashA1Size has been changed from 8M to 4M.
* Copyright 2018-2022 NXP
* All rights reserved.
* SPDX-License-Identifier: BSD-3-Clause
#include "mcxn_flexspi_nor_config.h"
/* Component ID definition, used by tools. */
#ifndef FSL_COMPONENT_ID
#define FSL_COMPONENT_ID "platform.drivers.xip_board"
#endif
* Code
#if defined(__CC_ARM) || defined(__ARMCC_VERSION) || defined(__GNUC__)
__attribute__((section(".flexspi_fcb"), used))
#elif defined(__ICCARM__)
#pragma location = ".flexspi_fcb"
#endif
#ifndef FLEXSPI_USE_CUSTOM_FCB
#define FLEXSPI_USE_CUSTOM_FCB (0)
#endif
#if FLEXSPI_USE_CUSTOM_FCB
/* FCB for W25Q64 */
const uint8_t CUSTOM_FCB[] = {
0x46, 0x43, 0x46, 0x42, 0x00, 0x04, 0x01, 0x56, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x03, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x01, 0x04, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xeb, 0x04, 0x18, 0x0a, 0x06,
0x32, 0x04, 0x26, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x04, 0x04, 0x24, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20,
0x04, 0x18, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xd8, 0x04, 0x18, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x04, 0x18, 0x08, 0x04, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x60, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00,
0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
#else
const flexspi_nor_config_t qspiflash_config = {
.memConfig =
.tag = FLEXSPI_CFG_BLK_TAG,
.version = FLEXSPI_CFG_BLK_VERSION,
.readSampleClksrc=kFlexSPIReadSampleClk_LoopbackFromDqsPad,
.csHoldTime = 3u,
.csSetupTime = 3u,
// Enable DDR mode, Wordaddassable, Safe configuration, Differential clock
.controllerMiscOption = (1u << kFlexSpiMiscOffset_SafeConfigFreqEnable),
.deviceType = kFlexSpiDeviceType_SerialNOR,
.sflashPadType = kSerialFlash_4Pads,
.serialClkFreq = kFlexSpiSerialClk_75MHz,
.sflashA1Size = 4u * 1024u * 1024u,
.lookupTable =
// Read LUTs
[0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xEB, RADDR_SDR, FLEXSPI_4PAD, 0x18),
[1] = FLEXSPI_LUT_SEQ(DUMMY_SDR, FLEXSPI_4PAD, 0x06, READ_SDR, FLEXSPI_4PAD, 0x04),
// Read Status LUTs
[4 * 1 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x05, READ_SDR, FLEXSPI_1PAD, 0x04),
// Write Enable LUTs
[4 * 3 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x06, STOP, FLEXSPI_1PAD, 0x0),
// Erase Sector LUTs
[4 * 5 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x20, RADDR_SDR, FLEXSPI_1PAD, 0x18),
// Erase Block LUTs
[4 * 8 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0xD8, RADDR_SDR, FLEXSPI_1PAD, 0x18),
// Pape Program LUTs
[4 * 9 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x02, RADDR_SDR, FLEXSPI_1PAD, 0x18),
[4 * 9 + 1] = FLEXSPI_LUT_SEQ(WRITE_SDR, FLEXSPI_1PAD, 0x04, STOP, FLEXSPI_1PAD, 0x0),
// Erase Chip LUTs
[4 * 11 + 0] = FLEXSPI_LUT_SEQ(CMD_SDR, FLEXSPI_1PAD, 0x60, STOP, FLEXSPI_1PAD, 0x0),
.pageSize = 256u,
.sectorSize = 4u * 1024u,
.ipcmdSerialClkFreq = 1u,
.blockSize = 64u * 1024u,
.isUniformBlockSize = false,
#endif
FlashConfig.h
I created four different versions of this file with different values ​​for CONFIG_OPTION0. (0xC0000001, 0xC0000405, 0xC0000401, 0xC0000101)
I have used each one to check.
// FlashConfig.h
// MCUXpresso IDE Flash driver
// Config file for MCXN9xx FlexSPI driver
// Copyright 2022-2024 NXP
// SPDX-License-Identifier: BSD-3-Clause
#ifndef FLASHCONFIG_H_
#define FLASHCONFIG_H_
#include "fsl_flexspi_nor_flash.h"
extern flexspi_nor_config_t flashConfig;
#if defined (DEBUG)
#define MCXN9xx_SFDP_FlexSPI
#endif
// MCX N1xNxxx Reference Manual - 15.4.2 FlexSPI NOR Configuration Option Block
#if defined (MCXN9xx_SFDP_FlexSPI) || defined (MCXN9xx_SFDP_FlexSPI_S)
* 0xC : tag
* 0 : option_size (0 = option1 not specified)
* 0 : device_type (0 = Read SFDP for SDR commands)
* 0 : query_pads (0 = 1 data pad during query)
* 0 : cmd_pads (0 = 1 data pad during flash access)
* 0 : quad_mode_setting (0 = not configured)
* 0 : misc_mode
* 1 : max_freq (0 = Don't change FlexSPI clock setting)
#define CONFIG_OPTION0 0xC0000001
//#define CONFIG_OPTION0 0xC0000405
//#define CONFIG_OPTION0 0xC0000401
//#define CONFIG_OPTION0 0xC0000101
* 0x0 : Single Flash connected to Port A
#define CONFIG_OPTION1 0x00000000
#endif
// Flash Base Address Information
#if defined (MCXN9xx_SFDP_FlexSPI_S)
#define USE_SECURE_FLASHADDR
#define FLASH_BASE_ADDR 0x90000000
#else
#define FLASH_BASE_ADDR 0x80000000
#endif
#endif /* FLASHCONFIG_H_ */
When 0xC0000001 is used for CONFIG_OPTION0, the following Console A is displayed on the Console, and when not, Console B is displayed.
Console A
VID:PID: 1FC9:0143
USB Path: 0001:0003:00
NXP: MCXN947
Inspected v.2 External Flash Device on SPI using SFDP JEDEC ID MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx
Image 'MCXN9xx_SFDP_FlexSPI Mar 21 2025 14:26:16'
Opening flash driver MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx
failed to initialize flash driver MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx
Closing flash driver MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx
Console B
VID:PID: 1FC9:0143
NXP: MCXN947
7,559件の閲覧回数
Harry_Zhang
Hi @takagi_y
Have we considered hardware connectivity issues?
Are you a custom board?
If you are a custom board, can you connect this flash to FRDM-MXN947?
And try again.
If the flash still cannot work when connected to FRDM-MXN947.
I will buy this flash and test it.
Harry
7,520件の閲覧回数
takagi_y
As you suggested, I replaced the Flash of FRDM-MXN947 with MX25L3233 and checked.
I was able to write when I used the same mcxn_flexspi_nor_config.c as the one I uploaded the other day and FlashConfig.h with CONFIG_OPTION0 set to 0xC0000101.
However, I cannot write on my board even when I use the same file.
On my board, I use port A in INDIVIDUAL mode, so SS0_b is connected to MX25L3233 and SS1_b is connected to PSRAM, but I wonder if PSRAM is affecting it.
I have attached a circuit diagram showing the connection of Flash and PSRAM.
If you have any comments, please give me some advice.
Also, I have set the Memory configuration editor as follows.
The flash size is set to 0xffff000, but since I'm using a 4MByte product, I think 0x3ff000 is correct.
Will this size setting affect flash writing?
タグ(1)
7,460件の閲覧回数
takagi_y
We have confirmed the following regarding this issue and would like to inform you of the issue.
We suspected that the PSRAM may be affecting the circuit, so we opened JP1 in the circuit diagram uploaded yesterday and checked with the PSRAM electrically disconnected, but we were unable to write to the Flash.
If you have any advice, including about yesterday's post, we would appreciate it.
7,380件の閲覧回数
Harry_Zhang
Hi @takagi_y
"As you suggested, I replaced the Flash of FRDM-MXN947 with MX25L3233 and checked.
I was able to write when I used the same mcxn_flexspi_nor_config.c as the one I uploaded the other day and FlashConfig.h with CONFIG_OPTION0 set to 0xC0000101."
This proves that your software configuration is fine.
So I think it's still a hardware issue.
Can you try connecting to Nor Flash only?
Disconnect the PSRAM related electrically(including DATA CLOCK CS).
Harry
7,370件の閲覧回数
takagi_y
Since the CEn of the PSRAM is fixed at the H level, I believe that the DATA and CLOCK of the PSRAM do not affect the QSPI Flash.
Are there any other possible causes?
7,310件の閲覧回数
takagi_y
I have an additional question.
The PSRAM is electrically isolated, and in this state, writing can be done from the SEC tool.
If writing is done from the IDE in the same state, it fails.
If the PSRAM is affecting it, I think writing cannot be done with the SEC tool either.
What do you think?
7,212件の閲覧回数
Harry_Zhang
Hi @takagi_y
Yes, your analysis is correct.
If writing can be done from the SEC tool.
This proves that there is no issue with the hardware.
Previously, you verified that your software had no issues with FRDM mcxn947, and now you have verified that your hardware has no issues with SEC tool,
so can you work now?
Harry
7,190件の閲覧回数
takagi_y
I can write from the SEC tool, but I cannot write from MCUXpresso IDE.
I think there is some reason why I cannot write from MCUXpresso IDE, but I don't know what it is.
Could you give me some advice?
タグ(1)
7,785件の閲覧回数
Harry_Zhang
Hi @takagi_y
Harry
6,645件の閲覧回数
takagi_y
In this thread, I have asked a question about not being able to write using write_image_win.bat, but this has not yet been resolved.
I would like to summarize the current situation.
- When writing to a brand new board using a bat file, the process that should say "Erase memory before writing image" is displayed as "failed."
- Boards that have already been written to using the SEC tool can be written to using the bat file.
The following are the questions I would like to ask.
1. Why can't I write to a brand new board using a bat file?
2. Is there anything I need to do to write to a brand new board using a bat file?
3. Is there a difference between a board that has already been written to using the SEC tool and a brand new board?
Please answer.
6,623件の閲覧回数
Harry_Zhang
Hi @takagi_y
We have already resolved the previous issue. For this question, I suggest you create a new one in the community.
We will do our best to support you. Thank you for your understanding.
Harry
6,543件の閲覧回数
takagi_y
Understood.
I have posted the question below, so please reply there.
https://community.nxp.com/t5/MCX-Microcontrollers/Writing-to-the-QSPI-Flash-of-MCXN947-using-write-i...
%3CLINGO-SUB%20id%3D%22lingo-sub-2055980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQSPI%20Flash%E3%82%92MCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2055980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%85%88%E6%97%A5%E3%80%81FRDM-MCXN947%E3%81%B8%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%B3%AA%E5%95%8F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%8A%E3%81%8B%E3%81%92%E3%81%95%E3%81%BE%E3%81%A7FRDM-MCXN947%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%8A%E5%9B%9E%E3%81%AF%E3%80%81MCXN947%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E4%BB%96%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABFlash%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%8A%E4%BC%BA%E3%81%84%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFRDM-MCXN947%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%96%B9%E6%B3%95%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E5%9F%BA%E6%9D%BF%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%82%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%81%9D%E3%81%AE%E6%99%82%E3%81%AE%E6%9C%AC%E4%BD%93%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3ENXP%E3%81%AE%3AMCXN947%3CBR%20%2F%3EDAP%20%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AF%201024%20%E3%83%90%E3%82%A4%E3%83%88%20(256%20%E3%83%AF%E3%83%BC%E3%83%89)%3CBR%20%2F%3ESFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI.cfx%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%20v.2%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E6%9F%BB%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%3A%20%E3%80%8CMCXN9xx_SFDP_FlexSPI%202024%E5%B9%B49%E6%9C%8819%E6%97%A5%2018%3A18%3A31%E3%80%8D%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%20MCXN9xx_SFDP_FlexSPI.cfx%3CBR%20%2F%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20V.2%20%E3%81%AE%E5%8B%95%E7%9A%84%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Edriver%20%E3%81%AF%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%89%E3%81%AA%E3%81%84%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%970x80000000%3CBR%20%2F%3EFlash%20Driver%20V.2%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20rc%20Ef(58)%3A%20Flash%20Driver%20%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Ef(58)%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20MCXN9xx_SFDP_FlexSPI.cfx%3CBR%20%2F%3ESFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI.cfx%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%20v.2%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E6%9F%BB%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%3A%20%E3%80%8CMCXN9xx_SFDP_FlexSPI%202024%E5%B9%B49%E6%9C%8819%E6%97%A5%2018%3A18%3A31%E3%80%8D%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%20MCXN9xx_SFDP_FlexSPI.cfx%3CBR%20%2F%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20V.2%20%E3%81%AE%E5%8B%95%E7%9A%84%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Edriver%20%E3%81%AF%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%89%E3%81%AA%E3%81%84%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%970x80000000%3CBR%20%2F%3EFlash%20Driver%20V.2%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20rc%20Ef(58)%3A%20Flash%20Driver%20%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Ef(58)%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20MCXN9xx_SFDP_FlexSPI.cfx%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%95%E3%81%8B%E8%A8%AD%E5%AE%9A%E3%82%84%E3%82%84%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%93%E3%81%A8%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2055980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCXN%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2083516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2083516%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%90%86%E8%A7%A3%E3%80%82%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AB%E8%B3%AA%E5%95%8F%E3%82%92%E6%8E%B2%E8%BC%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%9D%E3%81%A1%E3%82%89%E3%81%A7%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCX-Microcontrollers%2FWriting-to-the-QSPI-Flash-of-MCXN947-using-write-image-win-bat%2Fm-p%2F2083513%23M2906%22%20target%3D%22_self%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCX-Microcontrollers%2FWriting-to-the-QSPI-Flash-of-MCXN947-using-write-image-win-bat%2Fm-p%2F2083513%23M2906%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2083212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2083212%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E5%89%8D%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%99%E3%81%A7%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%E3%81%AB%E6%96%B0%E3%81%97%E3%81%84%E3%82%82%E3%81%AE%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%A8%E5%8A%9B%E3%81%A7%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%94%E7%90%86%E8%A7%A3%E3%81%AE%E3%81%BB%E3%81%A9%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2083050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2083050%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81write_image_win.bat%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E6%9B%B8%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%A8%E3%81%84%E3%81%86%E8%B3%AA%E5%95%8F%E3%82%92%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E3%81%BE%E3%81%A0%E8%A7%A3%E6%B1%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%8F%BE%E7%8A%B6%E3%82%92%E3%81%BE%E3%81%A8%E3%82%81%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20bat%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%A8%E3%80%81%E3%80%8C%E7%94%BB%E5%83%8F%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E5%89%8D%E3%81%AB%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%99%E3%82%8B%E3%80%8D%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%AE%E5%87%A6%E7%90%86%E3%81%8C%E3%80%8C%E5%A4%B1%E6%95%97%E3%80%8D%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20SEC%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%99%E3%81%A7%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81bat%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E7%A7%81%E3%81%8C%E5%B0%8B%E3%81%AD%E3%81%9F%E3%81%84%E8%B3%AA%E5%95%8F%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%20bat%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E5%93%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E2.%20bat%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%96%B0%E3%81%97%E3%81%84%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%95%E3%81%8B%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E3.%20SEC%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%99%E3%81%A7%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%80%81%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E6%96%B0%E3%81%97%E3%81%84%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%81%AE%E9%96%93%E3%81%AB%E9%81%95%E3%81%84%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2078117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2078117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E6%96%B9%E6%B3%95%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%80%81IDE%E3%81%8B%E3%82%89%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%9F%BA%E6%9D%BF%E3%81%AE%E8%A3%BD%E9%80%A0%E5%B7%A5%E7%A8%8B%E3%81%A7%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%ABwrite_image_win.bat%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81IDE%E3%81%8B%E3%82%89%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92SEC%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AEwrite_image_win.bat%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%86%E3%82%B9%E3%83%88%E3%81%A7%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%9F%E3%82%82%E3%81%AE%E3%81%AE%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%82%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%A4%E3%83%AC%E3%83%BC%E3%82%B9%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81i.MX%20RT1021%20%E3%81%8A%E3%82%88%E3%81%B3%20i.MX%20RT1062%20%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%9F%E3%82%81%E3%81%AB%20write_image_win.bat%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%20MCXN947%20%E3%81%A8%E5%90%8C%E6%A7%98%E3%81%AB%E6%B6%88%E5%8E%BB%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%90%84%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E9%96%93%E3%81%AB%E5%BE%85%E6%A9%9F%E6%99%82%E9%96%93%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AA%E3%81%A9%E3%81%AE%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3EMCXN947%E3%81%AB%E6%9B%B8%E3%81%84%E3%81%9F%E6%99%82%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%23%23%23%20Parse%20input%20arguments%20%23%23%23%3CBR%20%2F%3E%23%23%23%20Check%20connection%20%23%23%23%3CBR%20%2F%3Eblhost%20-t%202000%20-u%200x1FC9%2C0x014F%20-j%20--%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%201%200%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%22%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%22%3A%20%22%E5%8F%96%E5%BE%97%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%22%2C%3CBR%20%2F%3E%22%E3%83%AC%E3%82%B9%E3%83%9D%E3%83%B3%E3%82%B9%22%3A%20%5B%3CBR%20%2F%3E1258488320%3CBR%20%2F%3E%5D%2C%3CBR%20%2F%3E%22%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%22%3A%20%7B%3CBR%20%2F%3E%22description%22%3A%20%220%20(0x0)%20%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%22%E5%80%A4%22%3A0%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eblhost%20%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%23%23%23%20Configure%20FlexSPI%20NOR%20using%20FCB%20on%20address%200x20020000%20%23%23%23%3CBR%20%2F%3Eblhost%20-t%205000%20-u%200x1FC9%2C0x014F%20-j%20--%20write-memory%200x20020000%20%22C%3A%5CWorkSpace%5CMCUX%5CMCUXpressoSecureProvisioningv10%5CNX-N947_20250410%5Csource_images%5Cfrdmmcxn947_led_blinky.fcb.bin%22%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%22%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%22%3A%20%22%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%83%A1%E3%83%A2%E3%83%AA%22%2C%3CBR%20%2F%3E%22%E3%83%AC%E3%82%B9%E3%83%9D%E3%83%B3%E3%82%B9%22%3A%20%5B%3CBR%20%2F%3E512%3CBR%20%2F%3E%5D%2C%3CBR%20%2F%3E%22%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%22%3A%20%7B%3CBR%20%2F%3E%22description%22%3A%20%220%20(0x0)%20%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%22%E5%80%A4%22%3A0%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eblhost%20%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3Eblhost%20-t%205000%20-u%200x1FC9%2C0x014F%20-j%20--%20configure-memory%209%200x20020000%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%22%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%22%3A%20%22configure-memory%22%2C%3CBR%20%2F%3E%22%E5%BF%9C%E7%AD%94%22%3A%20%5B%5D%2C%3CBR%20%2F%3E%22%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%22%3A%20%7B%3CBR%20%2F%3E%22description%22%3A%20%220%20(0x0)%20%E6%88%90%E5%8A%9F%E3%80%82%3CBR%20%2F%3E%22%E5%80%A4%22%3A0%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eblhost%20%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%23%23%23%20Erase%20flash%20%23%23%23%3CBR%20%2F%3Eblhost%20-t%2050091%20-u%200x1FC9%2C0x014F%20-j%20--%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%B6%88%E5%8E%BB%E9%A0%98%E5%9F%9F%200x80000000%209132%200%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%22%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%22%3A%20%22flash-erase-region%22%2C%3CBR%20%2F%3E%22%E5%BF%9C%E7%AD%94%22%3A%20%5B%5D%2C%3CBR%20%2F%3E%22%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%22%3A%20%7B%3CBR%20%2F%3E%22description%22%3A%20%2220106%20(0x4e8a)%20FlexSPINOR%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%A4%B1%E6%95%97%E3%80%82%22%2C%3CBR%20%2F%3E%22%E5%80%A4%22%3A%2020106%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eblhost%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2077049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2077049%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ESEC%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81SEC%E3%81%8C%E4%BD%9C%E6%88%90%E3%81%97%E3%81%9FFCB%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E8%A8%BC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84FCB%E3%82%920x80000400%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81MCUXpresso%E3%81%A7mcxn_flexspi_nor_config.c%E3%81%A8mcxn_flexspi_nor_config.h%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%AA%E3%81%9C%E3%81%AA%E3%82%89%E3%80%81%E5%BD%BC%E3%82%89%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84FCB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%810x80000400%E3%81%A7%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%99%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AFSEC%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E9%80%9A%E3%81%97%E3%81%A6FCB.bin%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%97%E3%81%A6%E3%81%9D%E3%82%8C%E3%82%920x80000400%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%92%E3%81%86%E3%81%BE%E3%81%8F%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1744193877363.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1744193877363.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F332272iC5E03CEE11937E36%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1744193877363.png%22%20alt%3D%22Harry_Zhang_0-1744193877363.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%A6%81%E7%B4%84%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84FCB%E3%82%920x80000400%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%97%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%920x80001000%E3%81%AB%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2075539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075539%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESEC%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E3%81%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81MCUXpresso%20IDE%E3%81%8B%E3%82%89%E3%81%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3EMCUXpresso%20IDE%E3%81%8B%E3%82%89%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AB%E3%81%AF%E4%BD%95%E3%81%8B%E7%90%86%E7%94%B1%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E4%BD%95%E3%81%AA%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2075076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2075076%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%88%86%E6%9E%90%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8CSEC%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E8%A8%BC%E6%98%8E%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BB%A5%E5%89%8D%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%20FRDM%20mcxn947%20%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BB%8A%E5%9B%9E%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%20SEC%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A7%E3%81%AF%E3%80%81%E4%BB%8A%E3%81%99%E3%81%90%E5%83%8D%E3%81%91%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2073529%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2073529%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%95%E3%82%89%E3%81%AB%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPSRAM%E3%81%AF%E9%9B%BB%E6%B0%97%E7%9A%84%E3%81%AB%E7%B5%B6%E7%B8%81%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%A7%E3%81%AFSEC%E3%83%84%E3%83%BC%E3%83%AB%E3%81%8B%E3%82%89%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%90%8C%E3%81%98%E7%8A%B6%E6%85%8B%E3%81%A7IDE%E3%81%8B%E3%82%89%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AF%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3EPSRAM%E3%81%8C%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81SEC%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E3%82%82%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%A9%E3%81%86%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2070798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2070798%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPSRAM%20%E3%81%AE%20CEn%20%E3%81%AF%20H%20%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A7%E5%9B%BA%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81PSRAM%20%E3%81%AE%20DATA%20%E3%81%8A%E3%82%88%E3%81%B3%20CLOCK%20%E3%81%AF%20QSPI%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%81%AA%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AB%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E5%8E%9F%E5%9B%A0%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2070746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2070746%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%80%8C%3CSPAN%3E%E3%81%94%E6%8F%90%E6%A1%88%E3%81%AE%E9%80%9A%E3%82%8A%E3%80%81FRDM-MXN947%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92MX25L3233%E3%81%AB%E4%BA%A4%E6%8F%9B%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%85%88%E6%97%A5%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98mcxn_flexspi_nor_config.c%E3%81%A8%E3%80%81FlashConfig.h%E3%82%92CONFIG_OPTION0%200xC0000101%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%9F%E6%99%82%E3%81%AB%E6%9B%B8%E3%81%8F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%22%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E6%A7%8B%E6%88%90%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E8%A8%BC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A7%E3%81%99%E3%81%8B%E3%82%89%E3%80%81%E3%81%BE%E3%81%A0%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ENor%20Flash%E3%81%AE%E3%81%BF%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%81%BF%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E9%9B%BB%E6%B0%97%E7%9A%84%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%3CSPAN%3EPSRAM%20%3C%2FSPAN%3E%3CSPAN%3E%20(DATA%20CLOCK%20CS%E3%82%92%E5%90%AB%E3%82%80)%3C%2FSPAN%3E%E3%82%92%E5%88%87%E6%96%AD%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068142%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%AC%E4%BB%B6%E3%81%AB%E3%81%A4%E3%81%8D%E3%81%BE%E3%81%97%E3%81%A6%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E9%80%9A%E3%82%8A%E3%81%94%E7%A2%BA%E8%AA%8D%E3%82%92%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EPSRAM%E3%81%8C%E5%9B%9E%E8%B7%AF%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%8B%E3%81%A8%E7%96%91%E3%81%A3%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81%E6%98%A8%E6%97%A5%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%81%AEJP1%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81PSRAM%E3%81%8C%E9%9B%BB%E6%B0%97%E7%9A%84%E3%81%AB%E5%88%87%E6%96%AD%E3%81%95%E3%82%8C%E3%81%9F%E7%8A%B6%E6%85%8B%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81Flash%E3%81%B8%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%A8%E6%97%A5%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%92%E5%90%AB%E3%82%81%E3%80%81%E4%BD%95%E3%81%8B%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067631%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E6%8F%90%E6%A1%88%E3%81%AE%E9%80%9A%E3%82%8A%E3%80%81FRDM-MXN947%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92MX25L3233%E3%81%AB%E4%BA%A4%E6%8F%9B%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E5%85%88%E6%97%A5%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A8%E5%90%8C%E3%81%98mcxn_flexspi_nor_config.c%E3%81%A8FlashConfig.h%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%9F%E3%82%89%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%97%E3%81%9FCONFIG_OPTION0%20%E3%82%92%200xC0000101%20%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%82%82%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81%E3%83%9D%E3%83%BC%E3%83%88A%E3%82%92INDIVIDUAL%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81SS0_b%E3%81%AFMX25L3233%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%80%81SS1_b%E3%81%AFPSRAM%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81PSRAM%E3%81%8C%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%81%AA%E3%80%82%3CBR%20%2F%3EFlash%E3%81%A8PSRAM%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A4%BA%E3%81%99%E5%9B%9E%E8%B7%AF%E5%9B%B3%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E4%BD%95%E3%81%8B%E3%82%B3%E3%83%A1%E3%83%B3%E3%83%88%E3%81%8C%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22N947-FlexSPI.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22N947-FlexSPI.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F329590i0027E8D352A7CF05%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22N947-FlexSPI.png%22%20alt%3D%22N947-FlexSPI.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E6%A7%8B%E6%88%90%E3%82%A8%E3%83%87%E3%82%A3%E3%82%BF%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%AF0xffff000%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF4MByte%E3%81%AE%E8%A3%BD%E5%93%81%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%810x3ff000%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%B5%E3%82%A4%E3%82%BA%E8%A8%AD%E5%AE%9A%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22memory_config.bmp%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22memory_config.bmp%22%20style%3D%22width%3A%20554px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F329591i1A0F66904D29EE85%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22memory_config.bmp%22%20alt%3D%22memory_config.bmp%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067611%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%92%E6%A4%9C%E8%A8%8E%E3%81%95%E3%81%9B%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AFFLEXSPI0_A_SS0_b%20MX25L3233%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81FLEXSPI0_A_SS1_b%E3%81%AFPSRAM%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2%E3%81%A4%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E3%81%86%E3%81%A1FLEXSPI0_A_SCLK%E3%81%A8FLEXSPI0_A_DATA0-3%E3%81%AB%E3%81%AF%E5%90%8C%E3%81%98%E7%AB%AF%E5%AD%90%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AB%E5%BD%B1%E9%9F%BF%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067024%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%8E%A5%E7%B6%9A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%80%83%E6%85%AE%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E3%81%93%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92FRDM-MXN947%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E3%82%84%E3%82%8A%E7%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3EFRDM-MXN947%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%A6%E3%82%82%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%8C%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E8%B3%BC%E5%85%A5%E3%81%97%E3%81%A6%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2066272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2066272%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F2%E3%81%A4%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A0%E3%81%91%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%BE%E3%81%A0%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFlash%20Driver%20V2%E3%81%8C%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%AE%E3%81%A7%E3%80%81%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Emcxn_flexspi_nor_config.c%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AF%E3%80%81sflashA1Size%20%E3%81%AE%E5%80%A4%E3%81%8C%208M%20%E3%81%8B%E3%82%89%204M%20%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%3CP%3E%2F*%3CBR%20%2F%3E*%E8%91%97%E4%BD%9C%E6%A8%A92018-2022%20NXP%E3%81%AE%3CBR%20%2F%3E*%E5%85%A8%E8%91%97%E4%BD%9C%E6%A8%A9%E6%89%80%E6%9C%89%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20SPDX-License-Identifier%3A%20BSD-3-Clause%20(%E8%8B%B1%E8%AA%9E)%3CBR%20%2F%3E*%2F%3C%2FP%3E%3CP%3E%23include%E3%80%8Cmcxn_flexspi_nor_config.h%E3%80%8D%3C%2FP%3E%3CP%3E%2F*%20%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%20ID%20%E5%AE%9A%E7%BE%A9%E3%80%82*%2F%3CBR%20%2F%3E%23ifndef%20FSL_COMPONENT_ID%3CBR%20%2F%3E%23define%20FSL_COMPONENT_ID%E3%80%8Cplatform.drivers.xip_board%E3%80%8D%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3E%2F*******************************************************************************%3CBR%20%2F%3E*%20Code%3CBR%20%2F%3E******************************************************************************%2F%3C%2FP%3E%3CP%3E%23if%20%E5%AE%9A%E7%BE%A9(__CC_ARM)%20%7C%7C%E5%AE%9A%E7%BE%A9%E6%B8%88%E3%81%BF(__ARMCC_VERSION)%20%7C%7C%E5%AE%9A%E7%BE%A9%E6%B8%88%E3%81%BF(__GNUC__)%3CBR%20%2F%3E__attribute__((section(%22.flexspi_fcb%22)%2C%20used))%3CBR%20%2F%3E%23elif%20%E5%AE%9A%E7%BE%A9(__ICCARM__)%3CBR%20%2F%3E%23pragma%20%E5%A0%B4%E6%89%80%20%3D%20%22.flexspi_fcb%22%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3E%23ifndef%20FLEXSPI_USE_CUSTOM_FCB%3CBR%20%2F%3E%23define%20FLEXSPI_USE_CUSTOM_FCB%20(0)%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3E%23if%20FLEXSPI_USE_CUSTOM_FCB%3CBR%20%2F%3E%2F*%20FCB%20for%20W25Q64%20*%2F%3CBR%20%2F%3Econst%20uint8_t%20CUSTOM_FCB%5B%5D%20%3D%20%7B%3CBR%20%2F%3E0x46%2C%200x43%2C%200x46%2C%200x42%2C%200x00%2C%200x04%2C%200x01%2C%200x56%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x01%2C%200x03%2C%200x03%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x10%2C%200x00%2C%200x00%2C%200x00%2C%200x01%2C%200x04%2C%200x01%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x80%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200xeb%2C%200x04%2C%200x18%2C%200x0a%2C%200x06%2C%3CBR%20%2F%3E0x32%2C%200x04%2C%200x26%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x05%2C%200x04%2C%200x04%2C%200x24%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x06%2C%200x04%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x20%2C%3CBR%20%2F%3E0x04%2C%200x18%2C%200x08%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200xd8%2C%200x04%2C%200x18%2C%200x08%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x02%2C%200x04%2C%200x18%2C%200x08%2C%200x04%2C%200x20%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x60%2C%200x04%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x01%2C%200x00%2C%200x00%2C%200x00%2C%200x10%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x01%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x01%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%3CBR%20%2F%3E0x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%2C%200x00%7D%3B%3CBR%20%2F%3E%23else%3C%2FP%3E%3CP%3E%2F*%20W25Q64%20%E3%81%AE%20FCB%20*%2F%3CBR%20%2F%3E%E5%AE%9A%E6%95%B0%20flexspi_nor_config_t%20qspiflash_config%20%3D%20%7B%3CBR%20%2F%3E.memConfig%E3%81%AE%3D%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%E3%80%82%E3%82%BF%E3%82%B0%3D%20FLEXSPI_CFG_BLK_TAG%E3%80%81%3CBR%20%2F%3E%E3%80%82%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3D%20FLEXSPI_CFG_BLK_VERSION%E3%80%81%3CBR%20%2F%3E.readSampleClksrc%3DkFlexSPIReadSampleClk_LoopbackFromDqsPad%E3%80%81%3CBR%20%2F%3E.cs%E3%83%9B%E3%83%BC%E3%83%AB%E3%83%89%E3%82%BF%E3%82%A4%E3%83%A0%3D%203u%E3%80%81%3CBR%20%2F%3E.cs%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E6%99%82%E9%96%93%3D%203u%E3%80%81%3CBR%20%2F%3EDDR%E3%83%A2%E3%83%BC%E3%83%89%E3%80%81Wordaddassable%E3%80%81Safe%E6%A7%8B%E6%88%90%E3%80%81%E5%B7%AE%E5%8B%95%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E.controllerMisc%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3D%20(1U%20%26lt%3B%26lt%3B%20kFlexSpiMiscOffset_SafeConfigFreqEnable)%E3%80%81%3CBR%20%2F%3E.deviceType%20(%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%97)%3D%20kFlexSpiDeviceType_SerialNOR%E3%80%81%3CBR%20%2F%3E.sflashPadType%20(%E8%8B%B1%E8%AA%9E)%3D%20kSerialFlash_4Pads%E3%80%81%3CBR%20%2F%3E.serialClkFreq%3D%20kFlexSpiSerialClk_75MHz%E3%80%81%3CBR%20%2F%3E.sflashA1%E3%82%B5%E3%82%A4%E3%82%BA%3D%204U%20*%201024U%20*%201024U%E3%80%81%3CBR%20%2F%3E.lookup%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3D%3CBR%20%2F%3E%7B%3CBR%20%2F%3ELUT%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%3CBR%20%2F%3E%5B0%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200xEB%2C%20RADDR_SDR%2C%20FLEXSPI_4PAD%2C%200x18)%2C%3CBR%20%2F%3E%5B1%5D%20%3D%20FLEXSPI_LUT_SEQ(DUMMY_SDR%2C%20FLEXSPI_4PAD%2C%200x06%2C%20READ_SDR%2C%20FLEXSPI_4PAD%2C%200x04)%2C%3C%2FP%3E%3CP%3E%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9LUT%3CBR%20%2F%3E%5B4%20*%201%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x05%2C%20READ_SDR%2C%20FLEXSPI_1PAD%2C%200x04)%2C%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A4%E3%83%8D%E3%83%BC%E3%83%96%E3%83%AB%20LUT%3CBR%20%2F%3E%5B4%20*%203%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x06%2C%20STOP%2C%20FLEXSPI_1PAD%2C%200x0)%2C%3C%2FP%3E%3CP%3E%E3%82%BB%E3%82%AF%E3%82%BFLUT%E3%81%AE%E6%B6%88%E5%8E%BB%3CBR%20%2F%3E%5B4%20*%205%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x20%2C%20RADDR_SDR%2C%20FLEXSPI_1PAD%2C%200x18)%2C%3C%2FP%3E%3CP%3E%E3%83%96%E3%83%AD%E3%83%83%E3%82%AFLUT%E3%81%AE%E6%B6%88%E5%8E%BB%3CBR%20%2F%3E%5B4%20*%208%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200xD8%2C%20RADDR_SDR%2C%20FLEXSPI_1PAD%2C%200x18)%2C%3C%2FP%3E%3CP%3EPape%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AE%20LUT%3CBR%20%2F%3E%5B4%20*%209%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x02%2C%20RADDR_SDR%2C%20FLEXSPI_1PAD%2C%200x18)%2C%3CBR%20%2F%3E%5B4%20*%209%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(WRITE_SDR%2C%20FLEXSPI_1PAD%2C%200x04%2C%20STOP%2C%20FLEXSPI_1PAD%2C%200x0)%2C%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%83%E3%83%97LUT%E3%81%AE%E6%B6%88%E5%8E%BB%3CBR%20%2F%3E%5B4%20*%2011%20%2B%200%5D%20%3D%20FLEXSPI_LUT_SEQ(CMD_SDR%2C%20FLEXSPI_1PAD%2C%200x60%2C%20STOP%2C%20FLEXSPI_1PAD%2C%200x0)%2C%3CBR%20%2F%3E%7D%2C%3CBR%20%2F%3E%7D%2C%3CBR%20%2F%3E.pageSize(%E3%83%9A%E3%83%BC%E3%82%B8%E3%82%B5%E3%82%A4%E3%82%BA)%3D%20256u%E3%80%81%3CBR%20%2F%3E.sectorSize%20(%E8%8B%B1%E8%AA%9E)%3D%204U%20*%201024U%E3%80%81%3CBR%20%2F%3E.ipcmdSerialClkFreq%3D%201u%E3%80%81%3CBR%20%2F%3E.blockSize(%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA)%3D%2064U%20*%201024U%E3%80%81%3CBR%20%2F%3E.isUniformBlockSize%3D%20false%E3%80%81%3CBR%20%2F%3E%7D%3B%3CBR%20%2F%3E%23endif%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3EFlashConfig.h%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%204%20%E3%81%A4%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81CONFIG_OPTION0%20%E3%81%AB%E7%95%B0%E3%81%AA%E3%82%8B%E5%80%A4%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82(0xC0000001%E3%80%810xC0000405%E3%80%810xC0000401%E3%80%810xC0000101)%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%3CP%3E%2F%2F*****************************************************************************%3CBR%20%2F%3EFlashConfig.h%3CBR%20%2F%3EMCUXpresso%20IDE%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3EMCXN9xx%20FlexSPI%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%B0%E3%83%BB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CBR%20%2F%3E%2F%2F*****************************************************************************%3CBR%20%2F%3E%2F%2F%3CBR%20%2F%3E%E8%91%97%E4%BD%9C%E6%A8%A9%202022-2024%20NXP%3CBR%20%2F%3E%2F%2F%3CBR%20%2F%3ESPDX-%E3%83%A9%E3%82%A4%E3%82%BB%E3%83%B3%E3%82%B9%E8%AD%98%E5%88%A5%E5%AD%90%3A%20BSD-3-Clause%3CBR%20%2F%3E%2F%2F*****************************************************************************%3C%2FP%3E%3CP%3E%23ifndef%20FLASHCONFIG_H_%3CBR%20%2F%3E%23define%20FLASHCONFIG_H_%3C%2FP%3E%3CP%3E%23include%E3%80%8Cfsl_flexspi_nor_flash.h%E3%80%8D%3C%2FP%3E%3CP%3Eextern%20flexspi_nor_config_t%20flashConfig%3B%3C%2FP%3E%3CP%3E%23if%20defined%20(DEBUG)%3CBR%20%2F%3E%23define%20MCXN9xx_SFDP_FlexSPI%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3E%3CBR%20%2F%3EMCX%20N1xNxxx%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%20%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%20-%2015.4.2FlexSPI%20NOR%20%E8%A8%AD%E5%AE%9A%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3C%2FP%3E%3CP%3E%23if%20%E5%AE%9A%E7%BE%A9%20(MCXN9xx_SFDP_FlexSPI)%20%7C%7C%E5%AE%9A%E7%BE%A9%E6%B8%88%E3%81%BF%20(MCXN9xx_SFDP_FlexSPI_S)%3CBR%20%2F%3E%2F*%3CBR%20%2F%3E*%200xC%20%3A%20%E3%82%BF%E3%82%B0%3CBR%20%2F%3E*%200%20%3A%20option_size%20(0%20%3D%20option1%20%E6%9C%AA%E6%8C%87%E5%AE%9A)%3CBR%20%2F%3E*%200%20%3A%20device_type%20(0%20%3D%20SDR%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%20SFDP%20%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A)%3CBR%20%2F%3E*%200%20%3A%20query_pads%20(%E3%82%AF%E3%82%A8%E3%83%AA%E4%B8%AD%E3%81%AE%200%20%3D%201%20%E3%83%87%E3%83%BC%E3%82%BF%20%E3%83%91%E3%83%83%E3%83%89)%3CBR%20%2F%3E*%200%20%3A%20cmd_pads%20(%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E6%99%82%E3%81%AF0%20%3D%201%E3%83%87%E3%83%BC%E3%82%BF%E3%83%91%E3%83%83%E3%83%89)%3CBR%20%2F%3E*%200%20%3A%20quad_mode_setting%20(0%20%3D%20%E6%9C%AA%E8%A8%AD%E5%AE%9A)%3CBR%20%2F%3E%E2%80%BB0%3Amisc_mode%3CBR%20%2F%3E*%201%20%3A%20max_freq%20(0%20%3D%20FlexSPI%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%AA%E3%81%84)%3CBR%20%2F%3E*%2F%3CBR%20%2F%3E%23define%20CONFIG_OPTION0%200xC0000001%3CBR%20%2F%3E%23define%20CONFIG_OPTION0%200xC0000405%3CBR%20%2F%3E%23define%20CONFIG_OPTION0%200xC0000401%3CBR%20%2F%3E%23define%20CONFIG_OPTION0%200xC0000101%3C%2FP%3E%3CP%3E%2F*%3CBR%20%2F%3E*%200x0%3A%E3%83%9D%E3%83%BC%E3%83%88A%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B7%E3%83%B3%E3%82%B0%E3%83%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3CBR%20%2F%3E*%2F%3CBR%20%2F%3E%23define%20CONFIG_OPTION1%200x00000000%3C%2FP%3E%3CP%3E%23endif%3C%2FP%3E%3CP%3E%2F%2F%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3EFlash%20Base%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E6%83%85%E5%A0%B1%3CBR%20%2F%3E%2F%2F%20%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%23if%20%E5%AE%9A%E7%BE%A9%20(MCXN9xx_SFDP_FlexSPI_S)%3CBR%20%2F%3E%23define%20USE_SECURE_FLASHADDR%3CBR%20%2F%3E%23define%20FLASH_BASE_ADDR%200x90000000%3CBR%20%2F%3E%23else%3CBR%20%2F%3E%23define%20FLASH_BASE_ADDR%200x80000000%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3E%23endif%20%2F*%20FLASHCONFIG_H_%20*%2F%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3ECONFIG_OPTION0%E3%81%AB0xC0000001%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%ABA%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%ABB%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%20A%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3EMCUXpresso%20IDE%20RedlinkMulti%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20v24.9%20(2024%20%E5%B9%B4%209%20%E6%9C%88%2019%20%E6%97%A5%2019%3A34%3A05%20-%20crt_emu_cm_redlink%20%E3%83%93%E3%83%AB%E3%83%89%20802)%3CBR%20%2F%3EC%3A%2FWorkSpace%2FMCUX%2FMCUXpressoIDE_24.9.25%2FNX-N947%2FNX-N947_ledblinky%2Ffrdmmcxn947_led_blinky%2FDebug_NoRAM%5CMCXN947.xml%20%E3%81%AB%E3%83%81%E3%83%83%E3%83%97XML%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E(%205)%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%E6%97%A2%E5%AD%98%E3%81%AE%20LinkServer%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3AMCU-LINK(r0FF)CMSIS-DAP%20V3.153(NXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%BA)%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%8A%E3%83%B3%E3%83%90%E3%83%BC%3AVUDADS0NIE0ZM%3CBR%20%2F%3E%E3%83%93%E3%83%87%E3%82%AA%3APID%3A1FC9%3A0143%3CBR%20%2F%3EUSB%E3%83%91%E3%82%B9%3A0001%3A0003%3A00%3CBR%20%2F%3E%E8%89%AF%E3%81%84%E3%82%B3%E3%82%A2%E3%82%92%E6%8E%A2%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%3CBR%20%2F%3Edebug%20interface%20type%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%200%20(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20CoreSight%20DP%20ID%2C%206BA02477)%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20Cortex-M33%20(CPU%20ID%2000000D21)%20on%20DAP%20AP%200%3CBR%20%2F%3EH%2FW%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%208%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%95%B0%20%3D%200%3CBR%20%2F%3EH%2FW%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%204%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96(0)%3A%E6%8E%A5%E7%B6%9A%26amp%3B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%80%82DPID%3A6BA02477%E3%80%82CPUID%3A00000D21%E3%80%82%E6%83%85%E5%A0%B1%3A%3CNONE%3E%3CBR%20%2F%3E%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3A%20SWD%E3%80%82RTCK%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%3CBR%20%2F%3ECoreSight%E3%83%87%E3%83%90%E3%83%83%E3%82%B0ROM%E3%81%AE%E5%86%85%E5%AE%B9%3A%3CBR%20%2F%3ERBASE%20E00FE000%3A%20CID%20B105100D%20PID%200000095000%20ROM%20(%E3%82%BF%E3%82%A4%E3%83%97%200x1)%3CBR%20%2F%3EROM%201%20E00FF000%3A%20CID%20B105100D%20PID%2004000BB4C9%20ROM%20(%E3%82%BF%E3%82%A4%E3%83%97%200x1)%3CBR%20%2F%3EROM%202%20E000E000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20type%200x0%20Misc%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3CBR%20%2F%3EROM%202%20E0001000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x0%20%E3%81%9D%E3%81%AE%E4%BB%96%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3CBR%20%2F%3EROM%202%20E0002000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20type%200x0%20Misc%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3CBR%20%2F%3EROM%202%20E0000000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x43%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%BD%E3%83%BC%E3%82%B9%20-%20%E3%83%90%E3%82%B9%3CBR%20%2F%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20type%200x13%20Trace%20Source%20-%20Core%3CBR%20%2F%3EROM%202%20E0042000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x14%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E5%88%B6%E5%BE%A1%20-%20%E3%83%88%E3%83%AA%E3%82%AC%E9%9B%BB%E6%B0%97%20%E3%82%B7%E3%83%A7%E3%83%83%E3%82%AF%20%E7%99%82%E6%B3%95%3CBR%20%2F%3EROM%201%20E0040000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20%E3%82%BF%E3%82%A4%E3%83%97%200x11%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%B7%E3%83%B3%E3%82%AF%20-%20TPIU%3CBR%20%2F%3EROM%201%20E0044000%3A%20CID%20B105900D%20PID%2004003BB908%20CSt%20CSTF%20%E3%82%BF%E3%82%A4%E3%83%97%200x12%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%AA%E3%83%B3%E3%82%AF%20-%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%95%E3%82%A1%E3%83%B3%E3%83%8D%E3%83%AB%2F%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3CBR%20%2F%3EROM%201%20E0045000%3A%20CID%20B105900D%20PID%2004001BB961%20CSt%20%E3%82%BF%E3%82%A4%E3%83%97%200x21%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%B7%E3%83%B3%E3%82%AF%20-%20ETB%3CBR%20%2F%3ENXP%E3%81%AE%3AMCXN947%3CBR%20%2F%3EDAP%20%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AF%201024%20%E3%83%90%E3%82%A4%E3%83%88%20(256%20%E3%83%AF%E3%83%BC%E3%83%89)%3CBR%20%2F%3ESFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%20v.2%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E6%9F%BB%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%3A%20'MCXN9xx_SFDP_FlexSPI%20Mar%2021%2C%202025%2014%3A26%3A16'%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%3CBR%20%2F%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%80%8CJEDEC_FlexSPI_Device%E3%80%8D%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F(0B%20%3D%200x80000000%E6%99%82)%3CBR%20%2F%3Edriver%20%E3%81%AF%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%89%E3%81%AA%E3%81%84%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%970x80000000%3CBR%20%2F%3EFlash%20Driver%20V.2%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20rc%20Ef(58)%3A%20Flash%20Driver%20%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Ef(58)%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%3CBR%20%2F%3ESFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%20v.2%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E6%9F%BB%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%3A%20'MCXN9xx_SFDP_FlexSPI%20Mar%2021%2C%202025%2014%3A26%3A16'%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%3CBR%20%2F%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%80%8CJEDEC_FlexSPI_Device%E3%80%8D%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F(0x80000000%E3%81%A74MB%20%3D%2064%20*%2064K)%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%89%E3%81%98%E3%82%8B%20MCXN9xx_SFDP_FlexSPI_0xC0000001.cfx%3C%2FNONE%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%ABB%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3EMCUXpresso%20IDE%20RedlinkMulti%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20v24.9%20(2024%20%E5%B9%B4%209%20%E6%9C%88%2019%20%E6%97%A5%2019%3A34%3A05%20-%20crt_emu_cm_redlink%20%E3%83%93%E3%83%AB%E3%83%89%20802)%3CBR%20%2F%3EC%3A%2FWorkSpace%2FMCUX%2FMCUXpressoIDE_24.9.25%2FNX-N947%2FNX-N947_ledblinky%2Ffrdmmcxn947_led_blinky%2FDebug_NoRAM%5CMCXN947.xml%20%E3%81%AB%E3%83%81%E3%83%83%E3%83%97XML%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E(%205)%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%E6%97%A2%E5%AD%98%E3%81%AE%20LinkServer%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3AMCU-LINK(r0FF)CMSIS-DAP%20V3.153(NXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%BA)%3CBR%20%2F%3E%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%E3%83%8A%E3%83%B3%E3%83%90%E3%83%BC%3AVUDADS0NIE0ZM%3CBR%20%2F%3E%E3%83%93%E3%83%87%E3%82%AA%3APID%3A1FC9%3A0143%3CBR%20%2F%3EUSB%E3%83%91%E3%82%B9%3A0001%3A0003%3A00%3CBR%20%2F%3E%E8%89%AF%E3%81%84%E3%82%B3%E3%82%A2%E3%82%92%E6%8E%A2%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%3CBR%20%2F%3Edebug%20interface%20type%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%200%20(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20CoreSight%20DP%20ID%2C%206BA02477)%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20Cortex-M33%20(CPU%20ID%2000000D21)%20on%20DAP%20AP%200%3CBR%20%2F%3EH%2FW%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%208%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%95%B0%20%3D%200%3CBR%20%2F%3EH%2FW%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%204%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96(0)%3A%E6%8E%A5%E7%B6%9A%26amp%3B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%80%82DPID%3A6BA02477%E3%80%82CPUID%3A00000D21%E3%80%82%E6%83%85%E5%A0%B1%3A%3CNONE%3E%3CBR%20%2F%3E%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3A%20SWD%E3%80%82RTCK%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%3CBR%20%2F%3ECoreSight%E3%83%87%E3%83%90%E3%83%83%E3%82%B0ROM%E3%81%AE%E5%86%85%E5%AE%B9%3A%3CBR%20%2F%3ERBASE%20E00FE000%3A%20CID%20B105100D%20PID%200000095000%20ROM%20(%E3%82%BF%E3%82%A4%E3%83%97%200x1)%3CBR%20%2F%3EROM%201%20E00FF000%3A%20CID%20B105100D%20PID%2004000BB4C9%20ROM%20(%E3%82%BF%E3%82%A4%E3%83%97%200x1)%3CBR%20%2F%3EROM%202%20E000E000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20type%200x0%20Misc%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3CBR%20%2F%3EROM%202%20E0001000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x0%20%E3%81%9D%E3%81%AE%E4%BB%96%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3CBR%20%2F%3EROM%202%20E0002000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20type%200x0%20Misc%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3CBR%20%2F%3EROM%202%20E0000000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x43%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%BD%E3%83%BC%E3%82%B9%20-%20%E3%83%90%E3%82%B9%3CBR%20%2F%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20type%200x13%20Trace%20Source%20-%20Core%3CBR%20%2F%3EROM%202%20E0042000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x14%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E5%88%B6%E5%BE%A1%20-%20%E3%83%88%E3%83%AA%E3%82%AC%E9%9B%BB%E6%B0%97%20%E3%82%B7%E3%83%A7%E3%83%83%E3%82%AF%20%E7%99%82%E6%B3%95%3CBR%20%2F%3EROM%201%20E0040000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20%E3%82%BF%E3%82%A4%E3%83%97%200x11%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%B7%E3%83%B3%E3%82%AF%20-%20TPIU%3CBR%20%2F%3EROM%201%20E0044000%3A%20CID%20B105900D%20PID%2004003BB908%20CSt%20CSTF%20%E3%82%BF%E3%82%A4%E3%83%97%200x12%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%AA%E3%83%B3%E3%82%AF%20-%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%95%E3%82%A1%E3%83%B3%E3%83%8D%E3%83%AB%2F%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3CBR%20%2F%3EROM%201%20E0045000%3A%20CID%20B105900D%20PID%2004001BB961%20CSt%20%E3%82%BF%E3%82%A4%E3%83%97%200x21%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%B7%E3%83%B3%E3%82%AF%20-%20ETB%3CBR%20%2F%3ENXP%E3%81%AE%3AMCXN947%3CBR%20%2F%3EDAP%20%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AF%201024%20%E3%83%90%E3%82%A4%E3%83%88%20(256%20%E3%83%AF%E3%83%BC%E3%83%89)%3CBR%20%2F%3ESFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%20v.2%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E6%9F%BB%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%20'MCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%886%E6%97%A5%2018%3A26%3A01'%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3CBR%20%2F%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20V.2%20%E3%81%AE%E5%8B%95%E7%9A%84%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Edriver%20%E3%81%AF%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%89%E3%81%AA%E3%81%84%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%970x80000000%3CBR%20%2F%3EFlash%20Driver%20V.2%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20rc%20Ef(58)%3A%20Flash%20Driver%20%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Ef(58)%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx)%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3ESFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%20v.2%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E6%9F%BB%3CBR%20%2F%3E%E7%94%BB%E5%83%8F%20'MCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%886%E6%97%A5%2018%3A26%3A01'%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3CBR%20%2F%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3CBR%20%2F%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20V.2%20%E3%81%AE%E5%8B%95%E7%9A%84%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Edriver%20%E3%81%AF%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%89%E3%81%AA%E3%81%84%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%970x80000000%3CBR%20%2F%3EFlash%20Driver%20V.2%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20rc%20Ef(58)%3A%20Flash%20Driver%20%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Ef(58)%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx)%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FNONE%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2063601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EMCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E3%81%A8%20%3CSPAN%3E%20FlashConfig.h%3C%2FSPAN%3E%20%E3%81%AE%E4%BB%96%E3%81%AB%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E4%BB%96%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2062597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2062597%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9F%E4%BE%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%81%84Flash%E3%81%AFMX25L3233F%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%9F%E4%BE%8B%E3%81%AF%E3%80%81%E3%83%A2%E3%83%87%E3%83%AB%E7%95%AA%E5%8F%B7%E3%81%8C%E7%95%B0%E3%81%AA%E3%82%8B%20MT35XU512ABA%20%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81MT35XU512ABA%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A8%E5%90%8C%E3%81%98MX25L3233F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E6%8A%9C%E7%B2%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F328327i94C86C7AF2FA589B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F328328i698FE86060F7501C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F328329iD674305B2D9D8BB1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81FlashConfig.h%20%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2062145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2062145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FSPAN%3E%20%E3%81%A8%20%3CSPAN%3Emcxn_flexspi_nor_config.c%3C%2FSPAN%3E%20%E4%BB%A5%E5%A4%96%E3%81%AB%E3%80%81%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%80%8C%3CSPAN%3EW25Q64JVSSIQ%E3%81%A8MX25L3233F%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%80%81LUT%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%22%3C%2FP%3E%0A%3CP%3E%E3%81%84%E3%81%84%E3%81%88%E3%80%81%E9%81%95%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Eflexspi_polling%E3%81%AE%E4%BE%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AFW25Q64JVSSIQ%E3%81%A8MX25L3233F%3C%2FSPAN%3E%E3%81%AELUT%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23if%20EXAMPLE_FLASH_TYPE%20%3D%3D%20FLASH_W25Q64%0A%2F*%20W25Q64JVSSIQ%20*%2F%0Aconst%20uint32_t%20customLUTOctalMode%5BCUSTOM_LUT_LENGTH%5D%20%3D%20%7B%0A%20%20%20%20%2F*%20Read%20data%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200xEB%2C%20kFLEXSPI_Command_RADDR_SDR%2C%20kFLEXSPI_4PAD%2C%200x18)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(%0A%20%20%20%20%20%20%20%20kFLEXSPI_Command_MODE8_SDR%2C%20kFLEXSPI_4PAD%2C%200xF0%2C%20kFLEXSPI_Command_DUMMY_SDR%2C%20kFLEXSPI_4PAD%2C%200x04)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%20%2B%202%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_4PAD%2C%200x00%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Read%20status%20register%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READSTATUS%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x05%2C%20kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Write%20enable%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITEENABLE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x06%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Write%20enable%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITEENABLE_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x06%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Read%20ID%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READID_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x9F%2C%20kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Sector%20erase%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ERASESECTOR%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x20%2C%20kFLEXSPI_Command_RADDR_SDR%2C%20kFLEXSPI_1PAD%2C%200x18)%2C%0A%0A%20%20%20%20%2F*%20Chip%20erase%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_CHIPERASE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x60%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Page%20program%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x32%2C%20kFLEXSPI_Command_RADDR_SDR%2C%20kFLEXSPI_1PAD%2C%200x18)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM%20%2B%201%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_WRITE_SDR%2C%20kFLEXSPI_4PAD%2C%200x00%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Enter%20Quad%20mode%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ENTEROPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x05%2C%20kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20%20Dummy%20write%2C%20do%20nothing%20when%20AHB%20write%20command%20is%20triggered.%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x0%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x0)%2C%0A%0A%20%20%20%20%2F*%20%20Read%20status%20register%20using%20Quad%20mode%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READSTATUS_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x05%2C%20kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%7D%3B%0A%23endif%0A%0A%23if%20EXAMPLE_FLASH_TYPE%20%3D%3D%20FLASH_MT35XU512%0A%2F*%20MT35XU512ABA1G12%20*%2F%0Aconst%20uint32_t%20customLUTOctalMode%5BCUSTOM_LUT_LENGTH%5D%20%3D%20%7B%0A%0A%20%20%20%20%2F*%20%20OPI%20DDR%20read%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200xCC%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200xCC)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(%0A%20%20%20%20%20%20%20%20kFLEXSPI_Command_RADDR_DDR%2C%20kFLEXSPI_8PAD%2C%200x20%2C%20kFLEXSPI_Command_DUMMY_DDR%2C%20kFLEXSPI_8PAD%2C%200x0D)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READ%20%2B%202%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_READ_DDR%2C%20kFLEXSPI_8PAD%2C%200x00%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Read%20status%20register%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READSTATUS%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x05%2C%20kFLEXSPI_Command_READ_SDR%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Write%20Enable%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITEENABLE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x06%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Read%20ID%20under%20octal%20mode%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READID_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x9F%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x9F)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READID_OPI%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(%0A%20%20%20%20%20%20%20%20kFLEXSPI_Command_DUMMY_DDR%2C%20kFLEXSPI_8PAD%2C%200x10%2C%20kFLEXSPI_Command_READ_DDR%2C%20kFLEXSPI_8PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20%20Write%20Enable%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITEENABLE_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x06%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x06)%2C%0A%0A%20%20%20%20%2F*%20%20Erase%20Sector%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ERASESECTOR%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x20%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x20)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ERASESECTOR%20%2B%201%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_RADDR_DDR%2C%20kFLEXSPI_8PAD%2C%200x20%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20%20Erase%20Chip%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_CHIPERASE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x60%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x60)%2C%0A%0A%20%20%20%20%2F*%20%20Program%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x8E%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x8E)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_PAGEPROGRAM%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(%0A%20%20%20%20%20%20%20%20kFLEXSPI_Command_RADDR_DDR%2C%20kFLEXSPI_8PAD%2C%200x20%2C%20kFLEXSPI_Command_WRITE_DDR%2C%20kFLEXSPI_8PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20Enter%20OPI%20mode%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ENTEROPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_SDR%2C%20kFLEXSPI_1PAD%2C%200x81%2C%20kFLEXSPI_Command_RADDR_SDR%2C%20kFLEXSPI_1PAD%2C%200x18)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_ENTEROPI%20%2B%201%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_WRITE_SDR%2C%20kFLEXSPI_1PAD%2C%200x00%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x00)%2C%0A%0A%20%20%20%20%2F*%20%20Dummy%20write%2C%20do%20nothing%20when%20AHB%20write%20command%20is%20triggered.%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_WRITE%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x0%2C%20kFLEXSPI_Command_STOP%2C%20kFLEXSPI_1PAD%2C%200x0)%2C%0A%0A%20%20%20%20%2F*%20%20Read%20status%20register%20using%20Octal%20DDR%20read%20*%2F%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READSTATUS_OPI%5D%20%3D%0A%20%20%20%20%20%20%20%20FLEXSPI_LUT_SEQ(kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x05%2C%20kFLEXSPI_Command_DDR%2C%20kFLEXSPI_8PAD%2C%200x05)%2C%0A%20%20%20%20%5B4%20*%20NOR_CMD_LUT_SEQ_IDX_READSTATUS_OPI%20%2B%201%5D%20%3D%20FLEXSPI_LUT_SEQ(%0A%20%20%20%20%20%20%20%20kFLEXSPI_Command_DUMMY_DDR%2C%20kFLEXSPI_8PAD%2C%200x10%2C%20kFLEXSPI_Command_READ_DDR%2C%20kFLEXSPI_8PAD%2C%200x00)%2C%0A%7D%3B%0A%23endif%0A%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2058562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2058562%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EW25Q64JVSSIQ%E3%81%A8MX25L3233F%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%82%92%E6%AF%94%E8%BC%83%E3%81%97%E3%80%81LUT%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%8C%E5%90%8C%E3%81%98%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%26gt%3B%20%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81Flash%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26gt%3B%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E3%81%AA%E3%81%A9%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AF%E3%80%81MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E3%81%AE%20CONFIG_OPTION0%20%E3%81%A8%20CONFIG_OPTION1%20%E4%BB%A5%E5%A4%96%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E4%BB%A5%E5%A4%96%E3%81%AB%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2057744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2057744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EFRDM-MCXN947%20%E3%81%A7%E3%81%AF%E3%80%81Qflash%20%E3%81%AF%20W25Q64JVSSIQ%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%9E%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E3%80%81qflash%E3%81%8CMX25L3233F%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81Flash%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EMCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E3%81%AA%E3%81%A9%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%81%9D%E3%81%97%E3%81%A6mcxn_flexspi_nor_config.c%E3%81%A7%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ELUT%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2025-03-07_18-01-29.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2025-03-07_18-01-29.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F327151i410610CB2C63825B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snipaste_2025-03-07_18-01-29.png%22%20alt%3D%22Snipaste_2025-03-07_18-01-29.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFRDM-MCXN947%E3%81%AE%E3%83%87%E3%83%A2%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%80%81IDE%E3%81%8B%E3%82%89%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E6%89%8B%E9%A0%86%E3%81%AF%E3%80%81%E6%98%A8%E6%97%A5%E3%81%AE%E3%80%8C%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%E3%81%A8%E3%81%97%E3%81%A6...%22.%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%ABMX25L3233F%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81CMSIS-DAP%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E4%BE%8B%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E8%87%AA%E5%88%86%E3%81%A7%E4%BD%9C%E3%81%A3%E3%81%9F%E3%82%82%E3%81%AE%E3%82%92%E3%81%9D%E3%81%AE%E3%81%BE%E3%81%BE%E4%BD%BF%E3%81%A3%E3%81%A6%E3%80%81IDE%E3%81%8B%E3%82%89%E6%9B%B8%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82(CONFIG_OPTION0%3D0xC0000001)%3CBR%20%2F%3E%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%3CP%3EMCUXpresso%20IDE%20RedlinkMulti%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20v24.9%20(2024%20%E5%B9%B4%209%20%E6%9C%88%2019%20%E6%97%A5%2019%3A34%3A05%20-%20crt_emu_cm_redlink%20%E3%83%93%E3%83%AB%E3%83%89%20802)%3C%2FP%3E%3CP%3EC%3A%2FWorkSpace%2FMCUX%2FMCUXpressoIDE_24.9.25%2FNX-N947%2Ffrdmmcxn947_hello_world_qspi_xip%2FDebug%5CMCXN947.xml%E3%81%AB%E3%83%81%E3%83%83%E3%83%97XML%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E(%205)%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3E%E6%97%A2%E5%AD%98%E3%81%AE%20LinkServer%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3AMCU-LINK(r0FF)CMSIS-DAP%20V3.153(NXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%BA)%3C%2FP%3E%3CP%3ESerial%20Number%3A%20VUDADS0NIE0ZM%3C%2FP%3E%3CP%3EVID%3APID%3A%201FC9%3A0143%3C%2FP%3E%3CP%3EUSB%E3%83%91%E3%82%B9%3A0001%3A0008%3A00%3C%2FP%3E%3CP%3E%E8%89%AF%E3%81%84%E3%82%B3%E3%82%A2%E3%82%92%E6%8E%A2%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Edebug%20interface%20type%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%200%20(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20CoreSight%20DP%20ID%2C%206BA02477)%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20Cortex-M33%20(CPU%20ID%2000000D21)%20on%20DAP%20AP%200%3C%2FP%3E%3CP%3EH%2FW%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%208%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%95%B0%20%3D%200%3C%2FP%3E%3CP%3EH%2FW%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%204%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96(0)%3A%E6%8E%A5%E7%B6%9A%26amp%3B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%80%82DPID%3A6BA02477%E3%80%82CPUID%3A00000D21%E3%80%82%E6%83%85%E5%A0%B1%3A%3CNONE%3E%3C%2FNONE%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3A%20SWD%E3%80%82RTCK%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%3C%2FP%3E%3CP%3ECoreSight%E3%83%87%E3%83%90%E3%83%83%E3%82%B0ROM%E3%81%AE%E5%86%85%E5%AE%B9%3A%3C%2FP%3E%3CP%3ERBASE%20E00FE000%3A%20CID%20B105100D%20PID%200000095000%20ROM%20(%E3%82%BF%E3%82%A4%E3%83%97%200x1)%3C%2FP%3E%3CP%3EROM%201%20E00FF000%3A%20CID%20B105100D%20PID%2004000BB4C9%20ROM%20(%E3%82%BF%E3%82%A4%E3%83%97%200x1)%3C%2FP%3E%3CP%3EROM%202%20E000E000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20type%200x0%20Misc%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3EROM%202%20E0001000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x0%20%E3%81%9D%E3%81%AE%E4%BB%96%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3EROM%202%20E0002000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20type%200x0%20Misc%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3EROM%202%20E0000000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x43%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%BD%E3%83%BC%E3%82%B9%20-%20%E3%83%90%E3%82%B9%3C%2FP%3E%3CP%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20type%200x13%20Trace%20Source%20-%20Core%3C%2FP%3E%3CP%3EROM%202%20E0042000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x14%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E5%88%B6%E5%BE%A1%20-%20%E3%83%88%E3%83%AA%E3%82%AC%E9%9B%BB%E6%B0%97%20%E3%82%B7%E3%83%A7%E3%83%83%E3%82%AF%20%E7%99%82%E6%B3%95%3C%2FP%3E%3CP%3EROM%201%20E0040000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20%E3%82%BF%E3%82%A4%E3%83%97%200x11%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%B7%E3%83%B3%E3%82%AF%20-%20TPIU%3C%2FP%3E%3CP%3EROM%201%20E0044000%3A%20CID%20B105900D%20PID%2004003BB908%20CSt%20CSTF%20%E3%82%BF%E3%82%A4%E3%83%97%200x12%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%AA%E3%83%B3%E3%82%AF%20-%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%95%E3%82%A1%E3%83%B3%E3%83%8D%E3%83%AB%2F%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3CP%3EROM%201%20E0045000%3A%20CID%20B105900D%20PID%2004001BB961%20CSt%20%E3%82%BF%E3%82%A4%E3%83%97%200x21%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%B7%E3%83%B3%E3%82%AF%20-%20ETB%3C%2FP%3E%3CP%3ENXP%E3%81%AE%3AMCXN947%3C%2FP%3E%3CP%3EDAP%20%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AF%201024%20%E3%83%90%E3%82%A4%E3%83%88%20(256%20%E3%83%AF%E3%83%BC%E3%83%89)%3C%2FP%3E%3CP%3ESFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_.cfx%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%20v.2%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E6%9F%BB%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%20'MCXN9xx_SFDP_FlexSPI%20Mar%206%2C%202025%2017%3A01%3A24'%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%20MCXN9xx_SFDP_FlexSPI_.cfx%3C%2FP%3E%3CP%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%80%8CJEDEC_FlexSPI_Device%E3%80%8D%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F(0B%20%3D%200x80000000%E6%99%82)%3C%2FP%3E%3CP%3Edriver%20%E3%81%AF%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%89%E3%81%AA%E3%81%84%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%970x80000000%3C%2FP%3E%3CP%3EFlash%20Driver%20V.2%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20rc%20Ef(58)%3A%20Flash%20Driver%20%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Ef(58)%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20MCXN9xx_SFDP_FlexSPI_.cfx%3C%2FP%3E%3CP%3ESFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_.cfx%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%20v.2%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E6%9F%BB%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%20'MCXN9xx_SFDP_FlexSPI%20Mar%206%2C%202025%2017%3A01%3A24'%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%20MCXN9xx_SFDP_FlexSPI_.cfx%3C%2FP%3E%3CP%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%E3%80%8CJEDEC_FlexSPI_Device%E3%80%8D%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F(0x80000000%E3%81%A74MB%20%3D%2064%20*%2064K)%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%89%E3%81%98%E3%82%8B%20MCXN9xx_SFDP_FlexSPI_.cfx%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CBR%20%2F%3E%E6%AC%A1%E3%81%AB%E3%80%81SEC%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E8%A8%AD%E5%AE%9A%E5%80%A4(CONFIG_OPTION0%3D0xC0000405)%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%82%82%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AF%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E(SEC%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%81%9D%E3%81%AE%E6%99%82%E3%81%AE%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E8%A1%A8%E7%A4%BA%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CTABLE%20border%3D%221%22%20width%3D%22100%25%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20width%3D%22100%25%22%3E%3CP%3EMCUXpresso%20IDE%20RedlinkMulti%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20v24.9%20(2024%20%E5%B9%B4%209%20%E6%9C%88%2019%20%E6%97%A5%2019%3A34%3A05%20-%20crt_emu_cm_redlink%20%E3%83%93%E3%83%AB%E3%83%89%20802)%3C%2FP%3E%3CP%3EC%3A%2FWorkSpace%2FMCUX%2FMCUXpressoIDE_24.9.25%2FNX-N947%2FNX-N947_ledblinky%2Ffrdmmcxn947_led_blinky%2FDebug_NoRAM%5CMCXN947.xml%20%E3%81%AB%E3%83%81%E3%83%83%E3%83%97XML%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E(%205)%20%E3%83%AA%E3%83%A2%E3%83%BC%E3%83%88%E8%A8%AD%E5%AE%9A%E5%AE%8C%E4%BA%86%3C%2FP%3E%3CP%3E%E6%97%A2%E5%AD%98%E3%81%AE%20LinkServer%20%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AB%E5%86%8D%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3AMCU-LINK(r0FF)CMSIS-DAP%20V3.153(NXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%BA)%3C%2FP%3E%3CP%3ESerial%20Number%3A%20VUDADS0NIE0ZM%3C%2FP%3E%3CP%3EVID%3APID%3A%201FC9%3A0143%3C%2FP%3E%3CP%3EUSB%E3%83%91%E3%82%B9%3A0001%3A0008%3A00%3C%2FP%3E%3CP%3E%E8%89%AF%E3%81%84%E3%82%B3%E3%82%A2%E3%82%92%E6%8E%A2%E3%81%97%E3%81%9F%E5%BE%8C%E3%81%AB%E3%82%B3%E3%82%A20%E3%81%AE%E3%83%A1%E3%83%A2%E3%83%AA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E(%2030%20)%20%E3%82%A8%E3%83%9F%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E6%8E%A5%E7%B6%9A%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%8C%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3Edebug%20interface%20type%20%3D%20CoreSight%20DP%20(DAP%20DP%20ID%206BA02477)%20over%20SWD%20TAP%200%20(%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20CoreSight%20DP%20ID%2C%206BA02477)%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%E3%82%BF%E3%82%A4%E3%83%97%20%3D%20Cortex-M33%20(CPU%20ID%2000000D21)%20on%20DAP%20AP%200%3C%2FP%3E%3CP%3EH%2FW%20%E3%83%96%E3%83%AC%E3%83%BC%E3%82%AF%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%208%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%BB%E3%83%91%E3%83%83%E3%83%81%E3%81%AE%E6%95%B0%20%3D%200%3C%2FP%3E%3CP%3EH%2FW%20%E3%82%A6%E3%82%A9%E3%83%83%E3%83%81%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E6%95%B0%20%3D%204%3C%2FP%3E%3CP%3E%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96(0)%3A%E6%8E%A5%E7%B6%9A%26amp%3B%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%80%82DPID%3A6BA02477%E3%80%82CPUID%3A00000D21%E3%80%82%E6%83%85%E5%A0%B1%3A%3CNONE%3E%3C%2FNONE%3E%3C%2FP%3E%3CP%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%3A%20SWD%E3%80%82RTCK%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%20%E3%82%AD%E3%83%A3%E3%83%83%E3%83%81%3A%20%E7%84%A1%E5%8A%B9%E3%80%82%3C%2FP%3E%3CP%3ECoreSight%E3%83%87%E3%83%90%E3%83%83%E3%82%B0ROM%E3%81%AE%E5%86%85%E5%AE%B9%3A%3C%2FP%3E%3CP%3ERBASE%20E00FE000%3A%20CID%20B105100D%20PID%200000095000%20ROM%20(%E3%82%BF%E3%82%A4%E3%83%97%200x1)%3C%2FP%3E%3CP%3EROM%201%20E00FF000%3A%20CID%20B105100D%20PID%2004000BB4C9%20ROM%20(%E3%82%BF%E3%82%A4%E3%83%97%200x1)%3C%2FP%3E%3CP%3EROM%202%20E000E000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ARMv8-M%20type%200x0%20Misc%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3EROM%202%20E0001000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20DWTv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x0%20%E3%81%9D%E3%81%AE%E4%BB%96%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3EROM%202%20E0002000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20FPBv2%20type%200x0%20Misc%20-%20%E6%9C%AA%E5%AE%9A%E7%BE%A9%3C%2FP%3E%3CP%3EROM%202%20E0000000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20ITMv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x43%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%BD%E3%83%BC%E3%82%B9%20-%20%E3%83%90%E3%82%B9%3C%2FP%3E%3CP%3EROM%202%20E0041000%3A%20CID%20B105900D%20PID%2004002BBD21%20CSt%20ARM%20ETMv4.0%20type%200x13%20Trace%20Source%20-%20Core%3C%2FP%3E%3CP%3EROM%202%20E0042000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20ARM%20CTIv2%20%E3%82%BF%E3%82%A4%E3%83%97%200x14%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E5%88%B6%E5%BE%A1%20-%20%E3%83%88%E3%83%AA%E3%82%AC%E9%9B%BB%E6%B0%97%20%E3%82%B7%E3%83%A7%E3%83%83%E3%82%AF%20%E7%99%82%E6%B3%95%3C%2FP%3E%3CP%3EROM%201%20E0040000%3A%20CID%20B105900D%20PID%2004000BBD21%20CSt%20%E3%82%BF%E3%82%A4%E3%83%97%200x11%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%B7%E3%83%B3%E3%82%AF%20-%20TPIU%3C%2FP%3E%3CP%3EROM%201%20E0044000%3A%20CID%20B105900D%20PID%2004003BB908%20CSt%20CSTF%20%E3%82%BF%E3%82%A4%E3%83%97%200x12%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%AA%E3%83%B3%E3%82%AF%20-%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%83%95%E3%82%A1%E3%83%B3%E3%83%8D%E3%83%AB%2F%E3%83%AB%E3%83%BC%E3%82%BF%E3%83%BC%3C%2FP%3E%3CP%3EROM%201%20E0045000%3A%20CID%20B105900D%20PID%2004001BB961%20CSt%20%E3%82%BF%E3%82%A4%E3%83%97%200x21%20%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B9%20%E3%82%B7%E3%83%B3%E3%82%AF%20-%20ETB%3C%2FP%3E%3CP%3ENXP%E3%81%AE%3AMCXN947%3C%2FP%3E%3CP%3EDAP%20%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%89%E3%81%AF%201024%20%E3%83%90%E3%82%A4%E3%83%88%20(256%20%E3%83%AF%E3%83%BC%E3%83%89)%3C%2FP%3E%3CP%3ESFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%20v.2%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E6%9F%BB%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%20'MCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%886%E6%97%A5%2018%3A26%3A01'%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FP%3E%3CP%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20V.2%20%E3%81%AE%E5%8B%95%E7%9A%84%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Edriver%20%E3%81%AF%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%89%E3%81%AA%E3%81%84%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%970x80000000%3C%2FP%3E%3CP%3EFlash%20Driver%20V.2%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20rc%20Ef(58)%3A%20Flash%20Driver%20%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Ef(58)%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx)%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ESFDP%20JEDEC%20ID%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20SPI%20%E4%B8%8A%E3%81%AE%20v.2%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%A4%9C%E6%9F%BB%3C%2FP%3E%3CP%3E%E7%94%BB%E5%83%8F%20'MCXN9xx_SFDP_FlexSPI%202025%E5%B9%B43%E6%9C%886%E6%97%A5%2018%3A26%3A01'%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%20MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx%3C%2FP%3E%3CP%3EVECTRESET%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81ARMv8-M%20CPU%20%E3%81%A7%E3%81%AF%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20SOFTRESET%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESOFT%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20V.2%20%E3%81%AE%E5%8B%95%E7%9A%84%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3Edriver%20%E3%81%AF%20%E3%81%8B%E3%82%89%E5%A7%8B%E3%81%BE%E3%82%89%E3%81%AA%E3%81%84%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%970x80000000%3C%2FP%3E%3CP%3EFlash%20Driver%20V.2%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20rc%20Ef(58)%3A%20Flash%20Driver%20%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20Ef(58)%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%99%E3%83%BC%E3%82%B9%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%AB%E3%82%BB%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%92%E8%A8%98%E8%BF%B0%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20(MCXN9xx_SFDP_FlexSPI_0xC0000405.cfx)%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3CBR%20%2F%3EMX25L3233F%E3%81%AECONFIG_OPTION0%E4%BB%A5%E5%A4%96%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F247126%22%20target%3D%22_blank%22%3E%40takagi_y%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%80%8CFRDM-MCXN947%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%96%B9%E6%B3%95%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%82%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%22%3C%2FP%3E%0A%3CP%3E%E5%88%A5%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%90%8C%E3%81%98%E6%96%B9%E6%B3%95%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2056203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AMCXN947%E3%83%9C%E3%83%BC%E3%83%89%E3%81%ABQSPI%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2056203%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E6%83%85%E5%A0%B1%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E3%81%8A%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%84%E3%81%9F%E3%83%87%E3%83%A2%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8B%E3%82%89%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%BE%E3%81%A7%E3%80%81XIP%E5%87%A6%E7%90%86%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%A1%8C%E3%81%A3%E3%81%9F%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20%E6%AC%A1%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%26nbsp%3B%E3%82%BD%E3%83%BC%E3%82%B9%5Cmcxn_flexspi_nor_config.c%3CBR%20%2F%3E%26nbsp%3B%E3%82%BD%E3%83%BC%E3%82%B9%5Cmcxn_flexspi_nor_config.h%3CBR%20%2F%3E%26nbsp%3B%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%5Crodata.ldt%3CBR%20%2F%3E%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%5Ctext.ldt%3C%2FP%3E%3CP%3E-%20blhost%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%8Cbootfromflexspi.bin%E3%80%8D%E3%81%AB%E6%9B%B8%E3%81%8D%E6%8F%9B%E3%81%88%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-%20%E3%83%A1%E3%83%A2%E3%83%AA%E6%A7%8B%E6%88%90%E3%82%A8%E3%83%87%E3%82%A3%E3%82%BF%E3%83%BC%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F326825iB59CC573151030E9%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%80%81%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
