VREFH range in MCX-C24x
Jiri_n
I would like to use an external VREFH reference voltage, however the MCX-C24x datasheet does not contain the VREFH acceptable voltage range. Interesting that KL27, MCX-C04x or MCX-C44x datasheets declare the VREFH range as 1.13V up to VDDA, but C24x one is missing it. (rev4/2025)
Is it safe to assume the C24x is the same case and range 1.17V - VDDA can be applied?
Labels (2)
Hi @Jiri_n
Thanks for your patience.
After confirming internally, we can use the reference voltage range of the MCXC44X for the MCXC24X.
Thank you.
Alice
Hello @Jiri_n
Thanks for your reply. I will confirm this internally and get back to you as soon as possible. I apologize for the inconvenience caused.
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2328299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EVREFH%20range%20in%20MCX-C24x%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20would%20like%20to%20use%20an%20external%20VREFH%20reference%20voltage%2C%20however%20the%20MCX-C24x%20datasheet%20does%20not%20contain%20the%20VREFH%20acceptable%20voltage%20range.%20Interesting%20that%20KL27%2C%20MCX-C04x%20or%20MCX-C44x%20datasheets%20declare%20the%20VREFH%20range%20as%201.13V%20up%20to%20VDDA%2C%20but%20C24x%20one%20is%20missing%20it.%20(rev4%2F2025)%3C%2FP%3E%3CP%3EIs%20it%20safe%20to%20assume%20the%20C24x%20is%20the%20same%20case%20and%20range%201.17V%20-%20VDDA%20can%20be%20applied%3F%3C%2FP%3E%3CP%3EThanks%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2328299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EAnalog(ADC%7CCMP%7CDAC%7COpAmps)%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VREFH%20range%20in%20MCX-C24x%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260507%22%20target%3D%22_blank%22%3E%40Jiri_n%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CDIV%3EThanks%20for%20your%20reply.%20I%20will%20confirm%20this%20internally%20and%20get%20back%20to%20you%20as%20soon%20as%20possible.%20I%20apologize%20for%20the%20inconvenience%20caused.%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2330183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20VREFH%20range%20in%20MCX-C24x%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2330183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F260507%22%20target%3D%22_blank%22%3E%40Jiri_n%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20patience.%26nbsp%3B%26nbsp%3B%3C%2FP%3E%0A%3CDIV%3EAfter%20confirming%20internally%2C%20we%20can%20use%20the%20reference%20voltage%20range%20of%20the%20MCXC44X%20for%20the%20MCXC24X.%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EThank%20you.%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EBR%3C%2FDIV%3E%0A%3CDIV%3EAlice%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
