SCTIMER Interupt Usage on FRDM-MCXN947 board
Kevin_Pang
Dear NXP community,
Currently, I am developing a program using the on board SCTIMER peripheral. I am trying to start the CTIMER0 peripheral in the third state of my state implementation with the SCTIMER to produce a PWM signal. This PWM signal is routed to a GPIO pin. To realize this, I will need to implement an interupt in my third state to start the CTIMER0 in that state specifically. However, I have some trouble with programming such interupt as i am not very experienced. Could you help me out?
The code I am currently working on is specified below:
void SCT0_IRQHandler(void)
SCTIMER_EventHandleIRQ(SCT0_PERIPHERAL);
// Start CTIMER only when SCTIMER reaches state 2
CTIMER_StartTimer(CTIMER0_PERIPHERAL);
PRINTF("CTIMER started from SCTIMER state 2 event.\r\n");
static void SCT0_init(void) {
CTIMER0_init();
SCTIMER_Init(SCT0_PERIPHERAL, &SCT0_initConfig);
/* Enable interrupt SCT0_IRQN request in the NVIC */
/* Initialization of state 0 */
SCTIMER_SetupPwm(SCT0_PERIPHERAL, &SCT0_pwmSignalsConfig[0], kSCTIMER_EdgeAlignedPwm, 100U, SCT0_CLOCK_FREQ, &SCT0_pwmEvent[0]);
SCTIMER_SetupPwm(SCT0_PERIPHERAL, &SCT0_pwmSignalsConfig[2], kSCTIMER_EdgeAlignedPwm, 100U, SCT0_CLOCK_FREQ, &SCT0_pwmEvent[2]);
SCTIMER_CreateAndScheduleEvent(SCT0_PERIPHERAL, kSCTIMER_OutputRiseEvent, 0, kSCTIMER_Out_0, kSCTIMER_Counter_U, &SCT0_event[0]);
SCTIMER_SetupNextStateAction(SCT0_PERIPHERAL, 1, SCT0_event[0]);
SCTIMER_IncreaseState(SCT0_PERIPHERAL);
/* Initialization of state 1 */
/* Schedule the period event for the PWM */
SCTIMER_ScheduleEvent(SCT0, SCT0_pwmEvent[0]);
/* Schedule the pulse event for the PWM */
SCTIMER_ScheduleEvent(SCT0, SCT0_pwmEvent[0] + 1);
SCTIMER_SetupPwm(SCT0_PERIPHERAL, &SCT0_pwmSignalsConfig[1], kSCTIMER_EdgeAlignedPwm, 100U, SCT0_CLOCK_FREQ, &SCT0_pwmEvent[1]);
SCTIMER_CreateAndScheduleEvent(SCT0_PERIPHERAL, kSCTIMER_OutputRiseEvent, 0, kSCTIMER_Out_0, kSCTIMER_Counter_U, &SCT0_event[1]);
SCTIMER_SetupNextStateAction(SCT0_PERIPHERAL, 2, SCT0_event[1]);
/* Initialization of state 2 */
SCTIMER_SetupPwm(SCT0_PERIPHERAL, &SCT0_pwmSignalsConfig[3], kSCTIMER_EdgeAlignedPwm, 100U, SCT0_CLOCK_FREQ, &SCT0_pwmEvent[3]);
SCTIMER_CreateAndScheduleEvent(SCT0_PERIPHERAL, kSCTIMER_OutputRiseEvent, 0, kSCTIMER_Out_0, kSCTIMER_Counter_U, &SCT0_event_startCTimer);
SCTIMER_SetCallback(SCT0_PERIPHERAL, SCT0_IRQHandler, SCT0_event_startCTimer);
EnableIRQ(SCT0_IRQn);
The picture below shows the wave form at the start. The goal is to start the blue PWM signal at the fourth rising edge of the yellow PWM signal.
Labels (3)
Kevin_Pang
PROBLEM SOLVED:
I have already found out the solution to program the interupt correctly. The code implementation is shown below (CTIMER init not shown):
void Start_CTIMER(void)
const sctimer_config_t SCT0_initConfig = {
.enableCounterUnify = true,
.clockMode = kSCTIMER_System_ClockMode,
.clockSelect = kSCTIMER_Clock_On_Rise_Input_0,
.enableBidirection_l = false,
.enableBidirection_h = false,
.prescale_l = 0U,
.prescale_h = 0U,
.outInitState = 0U,
.inputsync = 0U
const sctimer_pwm_signal_param_t SCT0_pwmSignalsConfig[4] = {
.output = kSCTIMER_Out_0,
.level = kSCTIMER_HighTrue,
.dutyCyclePercent = 50U
.output = kSCTIMER_Out_1,
.dutyCyclePercent = 100U
.dutyCyclePercent = 0U
uint32_t SCT0_pwmEvent[4];
uint32_t SCT0_event[4];
uint32_t SCT0_event_startCTimer;
SCTIMER_SetCallback(SCT0_PERIPHERAL, Start_CTIMER, SCT0_event_startCTimer);
SCTIMER_EnableInterrupts(SCT0, (1U << SCT0_event_startCTimer));
Habib_MS
Hello @Kevin_Pang,
I am glad your issue is solved. Please let me know if there is anything that I can do for you.
Habib
Kevin_Pang
Dear Habib,
Thank you for reaching out.
I now have a problem with the development board. It consequently raises an exception "Unable to open probe index 1" with the error "Probe not open" when trying to debug my project. Afterwards, it fails to connect with the core. This happened suddenly without any change in my setup. Can you help me solve this issue?
Kind regards,
Kevin Pang
Habib_MS
Hello @Kevin_Pang,
Could you try running one of the SDK examples, such as "hello_world," to determine whether the exception is caused by your code or is specific to your board?
Habib
Kevin_Pang
Dear Habib,
I have tried to run a basic sdk example and I still encounter the same error.
Kind regards,
Kevin
Habib_MS
Hello @Kevin_Pang,
It looks like the issue you are experiencing is discussed in the next thread. I recommend following the suggestions provided by ZhangJennie to see if they help resolve the problem.
Habib
%3CLINGO-SUB%20id%3D%22lingo-sub-2131736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESCTIMER%20Interupt%20Usage%20on%20FRDM-MCXN947%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2131736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP%20community%2C%3C%2FP%3E%3CP%3ECurrently%2C%20I%20am%20developing%20a%20program%20using%20the%20on%20board%20SCTIMER%20peripheral.%20I%20am%20trying%20to%20start%20the%20CTIMER0%20peripheral%20in%20the%20third%20state%20of%20my%20state%20implementation%20with%20the%20SCTIMER%20to%20produce%20a%20PWM%20signal.%20This%20PWM%20signal%20is%20routed%20to%20a%20GPIO%20pin.%20To%20realize%20this%2C%20I%20will%20need%20to%20implement%20an%20interupt%20in%20my%20third%20state%20to%20start%20the%20CTIMER0%20in%20that%20state%20specifically.%20However%2C%20I%20have%20some%20trouble%20with%20programming%20such%20interupt%20as%20i%20am%20not%20very%20experienced.%20Could%20you%20help%20me%20out%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20code%20I%20am%20currently%20working%20on%20is%20specified%20below%3A%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESCT0_IRQHandler%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_EventHandleIRQ(SCT0_PERIPHERAL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F%2F%20Start%20CTIMER%20only%20when%20SCTIMER%20reaches%20state%202%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECTIMER_StartTimer(CTIMER0_PERIPHERAL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPRINTF(%3C%2FSPAN%3E%3CSPAN%3E%22CTIMER%20started%20from%20SCTIMER%20state%202%20event.%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3Estatic%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESCT0_init%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECTIMER0_init()%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_Init(SCT0_PERIPHERAL%2C%20%26amp%3BSCT0_initConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Enable%20interrupt%20SCT0_IRQN%20request%20in%20the%20NVIC%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Initialization%20of%20state%200%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupPwm(SCT0_PERIPHERAL%2C%20%26amp%3BSCT0_pwmSignalsConfig%5B0%5D%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_EdgeAlignedPwm%3C%2FSPAN%3E%3CSPAN%3E%2C%20100U%2C%20SCT0_CLOCK_FREQ%2C%20%26amp%3BSCT0_pwmEvent%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupPwm(SCT0_PERIPHERAL%2C%20%26amp%3BSCT0_pwmSignalsConfig%5B2%5D%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_EdgeAlignedPwm%3C%2FSPAN%3E%3CSPAN%3E%2C%20100U%2C%20SCT0_CLOCK_FREQ%2C%20%26amp%3BSCT0_pwmEvent%5B2%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_CreateAndScheduleEvent(SCT0_PERIPHERAL%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_OutputRiseEvent%3C%2FSPAN%3E%3CSPAN%3E%2C%200%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Out_0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Counter_U%3C%2FSPAN%3E%3CSPAN%3E%2C%20%26amp%3BSCT0_event%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupNextStateAction(SCT0_PERIPHERAL%2C%201%2C%20SCT0_event%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_IncreaseState(SCT0_PERIPHERAL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Initialization%20of%20state%201%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Schedule%20the%20period%20event%20for%20the%20PWM%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_ScheduleEvent(SCT0%2C%20SCT0_pwmEvent%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Schedule%20the%20pulse%20event%20for%20the%20PWM%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_ScheduleEvent(SCT0%2C%20SCT0_pwmEvent%5B0%5D%20%2B%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupPwm(SCT0_PERIPHERAL%2C%20%26amp%3BSCT0_pwmSignalsConfig%5B1%5D%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_EdgeAlignedPwm%3C%2FSPAN%3E%3CSPAN%3E%2C%20100U%2C%20SCT0_CLOCK_FREQ%2C%20%26amp%3BSCT0_pwmEvent%5B1%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_CreateAndScheduleEvent(SCT0_PERIPHERAL%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_OutputRiseEvent%3C%2FSPAN%3E%3CSPAN%3E%2C%200%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Out_0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Counter_U%3C%2FSPAN%3E%3CSPAN%3E%2C%20%26amp%3BSCT0_event%5B1%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupNextStateAction(SCT0_PERIPHERAL%2C%202%2C%20SCT0_event%5B1%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_IncreaseState(SCT0_PERIPHERAL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Initialization%20of%20state%202%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Schedule%20the%20period%20event%20for%20the%20PWM%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_ScheduleEvent(SCT0%2C%20SCT0_pwmEvent%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Schedule%20the%20pulse%20event%20for%20the%20PWM%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_ScheduleEvent(SCT0%2C%20SCT0_pwmEvent%5B0%5D%20%2B%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupPwm(SCT0_PERIPHERAL%2C%20%26amp%3BSCT0_pwmSignalsConfig%5B3%5D%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_EdgeAlignedPwm%3C%2FSPAN%3E%3CSPAN%3E%2C%20100U%2C%20SCT0_CLOCK_FREQ%2C%20%26amp%3BSCT0_pwmEvent%5B3%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ESCTIMER_CreateAndScheduleEvent(SCT0_PERIPHERAL%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_OutputRiseEvent%3C%2FSPAN%3E%3CSPAN%3E%2C%200%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Out_0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Counter_U%3C%2FSPAN%3E%3CSPAN%3E%2C%20%26amp%3BSCT0_event_startCTimer)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetCallback(SCT0_PERIPHERAL%2C%20SCT0_IRQHandler%2C%20SCT0_event_startCTimer)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EEnableIRQ(%3C%2FSPAN%3E%3CSPAN%3ESCT0_IRQn%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20picture%20below%20shows%20the%20wave%20form%20at%20the%20start.%20The%20goal%20is%20to%20start%20the%20blue%20PWM%20signal%20at%20the%20fourth%20rising%20edge%20of%20the%20yellow%20PWM%20signal.%3CBR%20%2F%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Starting_Process_SCT_CT.png%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Starting_Process_SCT_CT.png%22%20style%3D%22width%3A%20800px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F346999i89A84FD24221CDF5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22Starting_Process_SCT_CT.png%22%20alt%3D%22Starting_Process_SCT_CT.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EStarting_Process_SCT_CT.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2131736%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EClock%7CTimers%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EDevelopment%20Board%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXN%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2137590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SCTIMER%20Interupt%20Usage%20on%20FRDM-MCXN947%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2137590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251209%22%20target%3D%22_blank%22%3E%40Kevin_Pang%3C%2FA%3E%2C%3CBR%20%2F%3E%3CBR%20%2F%3EIt%20looks%20like%20the%20issue%20you%20are%20experiencing%20is%20discussed%20in%20the%20next%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMCUXpresso-IDE%2FUnable-to-open-probe-index-1%2Ftd-p%2F1964345%22%20target%3D%22_self%22%3Ethread%3C%2FA%3E.%20I%20recommend%20following%20the%20suggestions%20provided%20by%20ZhangJennie%20to%20see%20if%20they%20help%20resolve%20the%20problem.%3C%2FP%3E%0A%3CP%3EBR%3CBR%20%2F%3EHabib%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SCTIMER%20Interupt%20Usage%20on%20FRDM-MCXN947%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Habib%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI%20have%20tried%20to%20run%20a%20basic%20sdk%20example%20and%20I%20still%20encounter%20the%20same%20error.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3C%2FP%3E%3CP%3EKevin%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SCTIMER%20Interupt%20Usage%20on%20FRDM-MCXN947%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135968%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251209%22%20target%3D%22_blank%22%3E%40Kevin_Pang%3C%2FA%3E%2C%3CBR%20%2F%3E%3CBR%20%2F%3ECould%20you%20try%20running%20one%20of%20the%20SDK%20examples%2C%20such%20as%20%22hello_world%2C%22%20to%20determine%20whether%20the%20exception%20is%20caused%20by%20your%20code%20or%20is%20specific%20to%20your%20board%3F%3CBR%20%2F%3EBR%3CBR%20%2F%3EHabib%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SCTIMER%20Interupt%20Usage%20on%20FRDM-MCXN947%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20Habib%2C%3C%2FP%3E%3CP%3EThank%20you%20for%20reaching%20out.%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3EI%20now%20have%20a%20problem%20with%20the%20development%20board.%20It%20consequently%20raises%20an%20exception%20%22Unable%20to%20open%20probe%20index%201%22%20with%20the%20error%20%22Probe%20not%20open%22%20when%20trying%20to%20debug%20my%20project.%20Afterwards%2C%20it%20fails%20to%20connect%20with%20the%20core.%20This%20happened%20suddenly%20without%20any%20change%20in%20my%20setup.%20Can%20you%20help%20me%20solve%20this%20issue%3F%3CBR%20%2F%3E%3CBR%20%2F%3EKind%20regards%2C%3CBR%20%2F%3EKevin%20Pang%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SCTIMER%20Interupt%20Usage%20on%20FRDM-MCXN947%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133496%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251209%22%20target%3D%22_blank%22%3E%40Kevin_Pang%3C%2FA%3E%2C%3CBR%20%2F%3EI%20am%20glad%20your%20issue%20is%20solved.%20Please%20let%20me%20know%20if%20there%20is%20anything%20that%20I%20can%20do%20for%20you.%3CBR%20%2F%3EBR%3CBR%20%2F%3EHabib%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2133331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SCTIMER%20Interupt%20Usage%20on%20FRDM-MCXN947%20board%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2133331%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EPROBLEM%20SOLVED%3A%3C%2FP%3E%3CP%3EI%20have%20already%20found%20out%20the%20solution%20to%20program%20the%20interupt%20correctly.%20The%20code%20implementation%20is%20shown%20below%20(CTIMER%20init%20not%20shown)%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CDIV%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESCT0_IRQHandler%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_EventHandleIRQ(SCT0_PERIPHERAL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3EStart_CTIMER%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F%2F%20Start%20CTIMER%20only%20when%20SCTIMER%20reaches%20state%202%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECTIMER_StartTimer(CTIMER0_PERIPHERAL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPRINTF(%3C%2FSPAN%3E%3CSPAN%3E%22CTIMER%20started%20from%20SCTIMER%20state%202%20event.%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Esctimer_config_t%3C%2FSPAN%3E%3CSPAN%3E%20SCT0_initConfig%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.enableCounterUnify%20%3D%20true%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.clockMode%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_System_ClockMode%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.clockSelect%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Clock_On_Rise_Input_0%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.enableBidirection_l%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.enableBidirection_h%20%3D%20false%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.prescale_l%20%3D%200U%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.prescale_h%20%3D%200U%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.outInitState%20%3D%200U%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.inputsync%20%3D%200U%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Esctimer_pwm_signal_param_t%3C%2FSPAN%3E%3CSPAN%3E%20SCT0_pwmSignalsConfig%5B4%5D%20%3D%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.output%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Out_0%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.level%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_HighTrue%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.dutyCyclePercent%20%3D%2050U%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.output%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Out_1%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.level%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_HighTrue%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.dutyCyclePercent%20%3D%20100U%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.output%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Out_1%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.level%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_HighTrue%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.dutyCyclePercent%20%3D%200U%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.output%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Out_1%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.level%20%3D%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_HighTrue%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E.dutyCyclePercent%20%3D%200U%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20SCT0_pwmEvent%5B4%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20SCT0_event%5B4%5D%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20SCT0_event_startCTimer%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Estatic%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESCT0_init%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3Evoid%3C%2FSPAN%3E%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ESCTIMER_Init(SCT0_PERIPHERAL%2C%20%26amp%3BSCT0_initConfig)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Enable%20interrupt%20SCT0_IRQN%20request%20in%20the%20NVIC%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Initialization%20of%20state%200%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupPwm(SCT0_PERIPHERAL%2C%20%26amp%3BSCT0_pwmSignalsConfig%5B0%5D%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_EdgeAlignedPwm%3C%2FSPAN%3E%3CSPAN%3E%2C%20100U%2C%20SCT0_CLOCK_FREQ%2C%20%26amp%3BSCT0_pwmEvent%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupPwm(SCT0_PERIPHERAL%2C%20%26amp%3BSCT0_pwmSignalsConfig%5B2%5D%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_EdgeAlignedPwm%3C%2FSPAN%3E%3CSPAN%3E%2C%20100U%2C%20SCT0_CLOCK_FREQ%2C%20%26amp%3BSCT0_pwmEvent%5B2%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_CreateAndScheduleEvent%3C%2FSPAN%3E%3CSPAN%3E(SCT0_PERIPHERAL%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_OutputRiseEvent%3C%2FSPAN%3E%3CSPAN%3E%2C%200%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Out_0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Counter_U%3C%2FSPAN%3E%3CSPAN%3E%2C%20%26amp%3BSCT0_event%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupNextStateAction(SCT0_PERIPHERAL%2C%201%2C%20SCT0_event%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_IncreaseState(SCT0_PERIPHERAL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Initialization%20of%20state%201%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Schedule%20the%20period%20event%20for%20the%20PWM%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_ScheduleEvent(SCT0%2C%20SCT0_pwmEvent%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Schedule%20the%20pulse%20event%20for%20the%20PWM%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_ScheduleEvent(SCT0%2C%20SCT0_pwmEvent%5B0%5D%20%2B%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupPwm(SCT0_PERIPHERAL%2C%20%26amp%3BSCT0_pwmSignalsConfig%5B1%5D%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_EdgeAlignedPwm%3C%2FSPAN%3E%3CSPAN%3E%2C%20100U%2C%20SCT0_CLOCK_FREQ%2C%20%26amp%3BSCT0_pwmEvent%5B1%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_CreateAndScheduleEvent%3C%2FSPAN%3E%3CSPAN%3E(SCT0_PERIPHERAL%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_OutputRiseEvent%3C%2FSPAN%3E%3CSPAN%3E%2C%200%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Out_0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Counter_U%3C%2FSPAN%3E%3CSPAN%3E%2C%20%26amp%3BSCT0_event%5B1%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupNextStateAction(SCT0_PERIPHERAL%2C%202%2C%20SCT0_event%5B1%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_IncreaseState(SCT0_PERIPHERAL)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Initialization%20of%20state%202%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Schedule%20the%20period%20event%20for%20the%20PWM%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_ScheduleEvent(SCT0%2C%20SCT0_pwmEvent%5B0%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%2F*%20Schedule%20the%20pulse%20event%20for%20the%20PWM%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_ScheduleEvent(SCT0%2C%20SCT0_pwmEvent%5B0%5D%20%2B%201)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ESCTIMER_SetupPwm(SCT0_PERIPHERAL%2C%20%26amp%3BSCT0_pwmSignalsConfig%5B3%5D%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_EdgeAlignedPwm%3C%2FSPAN%3E%3CSPAN%3E%2C%20100U%2C%20SCT0_CLOCK_FREQ%2C%20%26amp%3BSCT0_pwmEvent%5B3%5D)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3ESCTIMER_CreateAndScheduleEvent%3C%2FSPAN%3E%3CSPAN%3E(SCT0_PERIPHERAL%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_OutputRiseEvent%3C%2FSPAN%3E%3CSPAN%3E%2C%200%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Out_0%3C%2FSPAN%3E%3CSPAN%3E%2C%20%3C%2FSPAN%3E%3CSPAN%3EkSCTIMER_Counter_U%3C%2FSPAN%3E%3CSPAN%3E%2C%20%26amp%3BSCT0_event_startCTimer)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_SetCallback(SCT0_PERIPHERAL%2C%20Start_CTIMER%2C%20SCT0_event_startCTimer)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESCTIMER_EnableInterrupts(SCT0%2C%20(1U%20%26lt%3B%26lt%3B%20SCT0_event_startCTimer))%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EEnableIRQ(%3C%2FSPAN%3E%3CSPAN%3ESCT0_IRQn%3C%2FSPAN%3E%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Kevin_Pang_0-1752496755589.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Kevin_Pang_0-1752496755589.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F347429i3EAE56E208605257%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Kevin_Pang_0-1752496755589.png%22%20alt%3D%22Kevin_Pang_0-1752496755589.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKevin_Pang_0-1752496755589.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
