S35NZ55 GrayVIP_S32NZ5x_0_8_0 FSS firmware make generation issue
Jegadeesan
Failed to run generator "Os_TS_T31D62M8I0R0GeneratorId" (mode: "generate") for module "Os_TS_T31D62M8I0R0" INFO 24-07-05,20:27:42 Invariant (20053) Generating file C:\NXP\S32NZ5x_FSS_FW_R21-11_0.8.0\eclipse\plugins\Fss_Firmware_TS_T31D62M8I0R0\examples\EBT\Firmware_EVB_OS_S32NZ5X_FSS\generate\output\Os.epc ERROR 24-07-05,20:27:43 Invariant (20075) The external generator for module Os_TS_T31D62M8I0R0 terminated with exit code 1 Used generator commandline: C:\EB\tresos\..\..\NXP\S32NZ5x_FSS_FW_R21-11_0.8.0\eclipse\plugins\Os_TS_T31D62M8I0R0\ssc\bin\generator\sg.exe -p C:\NXP\S32NZ5x_FSS_FW_R21-11_0.8.0\eclipse\plugins\Fss_Firmware_TS_T31D62M8I0R0\examples\EBT\Firmware_EVB_OS_S32NZ5X_FSS\generate\include\Os_prop.h -h C:\NXP\S32NZ5x_FSS_FW_R21-11_0.8.0\eclipse\plugins\Fss_Firmware_TS_T31D62M8I0R0\examples\EBT\Firmware_EVB_OS_S32NZ5X_FSS\generate\include\Os_cfg.h -c C:\NXP\S32NZ5x_FSS_FW_R21-11_0.8.0\eclipse\plugins\Fss_Firmware_TS_T31D62M8I0R0\examples\EBT\Firmware_EVB_OS_S32NZ5X_FSS\generate\src\Os_cfg.c C:\NXP\S32NZ5x_FSS_FW_R21-11_0.8.0\eclipse\plugins\Fss_Firmware_TS_T31D62M8I0R0\examples\EBT\Firmware_EVB_OS_S32NZ5X_FSS\generate\output\Os.epc
