Run External Flash
Run External Flash
Ashish-625
Hello everyone,
I am using the MCXN547-EVK development board and trying to interface an external W25Q64JWTBJQ flash memory using Quad SPI (FlexSPI). I am building the project with IAR Embedded Workbench.
While building the spi_flash example from the MCUXpresso SDK, I encounter the following error:
CMake Error:
Cannot find source file:
.../examples/_boards/mcxn5xxevk/demo_apps/spi/spi_flash/cm33_core0/pin_mux.c
Has anyone encountered this issue before? Could you please help me understand what is causing it and how to resolve it?
Any suggestions would be greatly appreciated. Thank you!
Hello @Ashish-625
Could you please verify whether the pin_mux.c file exists at the following path?
In addition, please confirm which MCUXpresso SDK version you are using and whether the spi_flash demo is download based on  IAR Embedded Workbench.
Thank you.
Alice
