Resover mode/demod
Resover mode/demod
6,935件の閲覧回数
erikraynolds
any recommedantion how to implement Resover mode/demon, which units preferale to use for modulation and demodulation resolver signal?
タグ(1)
4 返答(返信)
6,909件の閲覧回数
xiangjun_rong
do you means resolver sensor, which can provide the rotor position information even if the motor is in still state?
If it is the case, pls refer to the application note.
In the following library, you can get angle based on the voltage of 2-phase coordinator.
https://www.nxp.com/design/design-center/software/embedded-software/real-time-control-embedded-softw...
Hope it can help you
XiangJun Rong
6,905件の閲覧回数
xiangjun_rong
I am sorry, I forgot to attach the docs.
I attach them here.
XiangJun Rong
6,899件の閲覧回数
erikraynolds
Yes, I meant RD C resolver to dogital conversion, is it source code available when I need to improve, filter more the SIN//COS and want to build upon existing code?
6,870件の閲覧回数
xiangjun_rong
As you know that the resolver sensor is third party product, I suppose there is resolver sensor on market, which can output digital angle directly.
https://www.analog.com/en/resources/analog-dialogue/articles/precision-rtdc-measures-angular-positio...
I just browse the product, I do not know the detail, pls check yourself.
XiangJun Rong
