RT1172 Bott Config
RT1172 Bott Config
dongjun
Hi, There
we are using RT1172 on our new PCB board, and boot mode =0x10(Internal boot),
but the problem is, all boot config is NC(not connect) pin,  in this case,  where will the MCU boot up? or do you have any good idea can help us? thanks...
marek-trmac
Hi @dongjun ,
BT_FUSE_SEL eFuse might help with this.
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
