RT1061使用FreeRTOS配置使用双网口
陈华
我查了RT1061的示例:lwip_examples示例中,裸机程序有配置使用双网口的,但是使用FreeRTOS却是没有配置使用双网口,我公司现在需要跑FreeRTOS,并且需要使用双网口配置,我在飞凌嵌入式的OK1061-S开发板上跑示例。使用裸机是完全没问题。参考裸机示例,配置FreeRTOS使用双网口,一直无法配置成功!请求贵公司技术支持,给一个FreeRTOS配置使用双网口的示例,谢谢。
Labels (2)
Gavin_Jia
Hi @陈华 ,
感谢您联系NXP支持团队!
我已经通过SFDC发送邮件给您,请查收!
Gavin
Gavin_Jia
Hi @陈华 ,
感谢您联系NXP支持团队!
Gavin
%3CLINGO-SUB%20id%3D%22lingo-sub-2182815%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERT1061%20configured%20to%20use%20dual%20network%20ports%20using%20FreeRTOS%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182815%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EI%20checked%20the%20RT1061%20examples%3A%20in%20the%20lwip_examples%20example%2C%20the%20bare-metal%20program%20is%20configured%20to%20use%20dual%20network%20ports%2C%20but%20there%20is%20no%20configuration%20to%20use%20dual%20network%20ports%20when%20using%20FreeRTOS%2C%20my%20company%20now%20needs%20to%20run%20FreeRTOS%20and%20needs%20to%20use%20dual%20network%20port%20configuration%2C%20I%20ran%20the%20examples%20on%20the%20Flying%20Embedded%20OK1061-S%20development%20board.%20I%20am%20running%20the%20example%20on%20a%20Flying%20Embedded%20OK1061-S%20development%20board.%20Using%20bare%20metal%20is%20no%20problem%20at%20all.%20I%20refer%20to%20the%20bare%20metal%20example%20and%20configure%20FreeRTOS%20with%20dual%20network%20ports%2C%20but%20I%20have%20not%20been%20able%20to%20do%20it%20successfully!%20I%20would%20like%20to%20request%20your%20technical%20support%20to%20give%20me%20an%20example%20of%20FreeRTOS%20configuration%20using%20dual%20network%20ports.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2182815%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EDevelopment%20Board%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183409%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT1061%E4%BD%BF%E7%94%A8FreeRTOS%E9%85%8D%E7%BD%AE%E4%BD%BF%E7%94%A8%E5%8F%8C%E7%BD%91%E5%8F%A3%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183409%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F255338%22%20target%3D%22_blank%22%3E%40ChenHua%3C%2FA%3E.%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20contacting%20the%20NXP%20support%20team!%3C%2FP%3E%0A%3CP%3EI%20have%20sent%20you%20an%20email%20via%20SFDC%2C%20please%20check%20it%20out!%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%20%3CBR%20%2F%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E
