Power Estimation Tool for MPC5777C
1,023 次查看
Gabgoes
Hello, my name is Gabriel.
I would like to know if there is a tool or spreadsheet to estimate electrical power dissipation in processor MPC5777C.
Gabriel Napoli Goes
Electronics Hardware Engineer.
标签 (1)
1 回复
1,007 次查看
davidtosenovjan
This device is not primarily targeted for low-power applications so Power estimation tool is not provided.
The only information we have on current is in the datasheet where we give only the worst-case figures.  We do not have data taken for single core operation or reduced frequency operation.  The worst-case current draw is dominated by leakage current at hot temperature and fast process.  Clock speed does not significantly reduce this number.
As for I/O current, this depends on pad usage in the customer application.  See table 11 in the datasheet, rev 14.
