Pin Assigment Tool Bugged For GPIOs
1,386件の閲覧回数
c_nebe
When I use the pin tool and assign GPIO pins the generated code incorrectly assigns the PORT macro to the initialization code instead of the GPIO macro:
expected 'GPIO_Type *' but argument is of type 'PORT_Type *'
hal_gpio_pin_config_t createAdapterGpioPinConfig(GPIO_Type *port, uint8_t pin, hal_gpio_direction_t direction, uint8_t level)
e.g in my pin_mux.h:
/* Symbols to be used with GPIO driver */
#define BOARD_INITPINS_LCD_BL_GPIO GPIOA /*!<@brief GPIO peripheral base pointer */
#define BOARD_INITPINS_LCD_BL_INIT_GPIO_VALUE 1U /*!<@brief GPIO output initial state */
#define BOARD_INITPINS_LCD_BL_GPIO_PIN_MASK (1U << 17U) /*!<@brief GPIO pin mask */
/* Symbols to be used with PORT driver */
#define BOARD_INITPINS_LCD_BL_PORT PORTA /*!<@brief PORT peripheral base pointer */
#define BOARD_INITPINS_LCD_BL_PIN 17U /*!<@brief PORT pin number */
#define BOARD_INITPINS_LCD_BL_PIN_MASK (1U << 17U) /*!<@brief PORT pin mask */
Then in peripherals.c
gpioPinConfig = createAdapterGpioPinConfig(BOARD_INITPINS_LCD_BL_PORT, BOARD_INITPINS_LCD_BL_PIN, BOARD_INITPINS_LCD_BL_PIN_DIRECTION, BOARD_INITPINS_LCD_BL_PIN_LEVEL);
I need to change to:
gpioPinConfig = createAdapterGpioPinConfig(BOARD_INITPINS_LCD_BL_GPIO, BOARD_INITPINS_LCD_BL_PIN, BOARD_INITPINS_LCD_BL_PIN_DIRECTION, BOARD_INITPINS_LCD_BL_PIN_LEVEL);
This requires a manual edit of the peripherals.c code every time I make a change to the configuration. Is there any way to fix this permanently?
Target Processor: MCXW71
タグ(1)
1,364件の閲覧回数
Harry_Zhang
Hi @c_nebe
I tested it on my end.
/* Get GPIO pin configuration */
hal_gpio_pin_config_t createAdapterGpioPinConfig(GPIO_Type *port, uint8_t pin, hal_gpio_direction_t direction, uint8_t level){
  hal_gpio_pin_config_t temp;
The generated code is correct.
How can i reproduce this issue?
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2351026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGPIO%E3%83%94%E3%83%B3%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AB%E3%83%90%E3%82%B0%E3%81%8C%E3%81%82%E3%82%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2351026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%94%E3%83%B3%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6GPIO%E3%83%94%E3%83%B3%E3%82%92%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%8B%E3%81%A8%E3%80%81%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8CGPIO%E3%83%9E%E3%82%AF%E3%83%AD%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FPORT%E3%83%9E%E3%82%AF%E3%83%AD%E3%82%92%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E8%AA%A4%E3%81%A3%E3%81%A6%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%3E%3CPRE%20translate%3D%22no%22%3Eexpected%20'GPIO_Type%20*'%20but%20argument%20is%20of%20type%20'PORT_Type%20*'%3CBR%20%2F%3Ehal_gpio_pin_config_t%20createAdapterGpioPinConfig(GPIO_Type%20*port%2C%20uint8_t%20pin%2C%20hal_gpio_direction_t%20direction%2C%20uint8_t%20level)%3C%2FPRE%3E%3CP%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81%E7%A7%81%E3%81%AEpin_mux.h%E3%81%A7%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CDIV%3E%3CPRE%20translate%3D%22no%22%3E%3CFONT%20size%3D%222%22%3E%2F*%20Symbols%20to%20be%20used%20with%20GPIO%20driver%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%23define%20BOARD_INITPINS_LCD_BL_GPIO%20GPIOA%20%2F*!%26lt%3B%40brief%20GPIO%20peripheral%20base%20pointer%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%23define%20BOARD_INITPINS_LCD_BL_INIT_GPIO_VALUE%201U%20%2F*!%26lt%3B%40brief%20GPIO%20output%20initial%20state%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%23define%20BOARD_INITPINS_LCD_BL_GPIO_PIN_MASK%20(1U%20%26lt%3B%26lt%3B%2017U)%20%2F*!%26lt%3B%40brief%20GPIO%20pin%20mask%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%3CBR%20%2F%3E%2F*%20Symbols%20to%20be%20used%20with%20PORT%20driver%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%23define%20BOARD_INITPINS_LCD_BL_PORT%20PORTA%20%2F*!%26lt%3B%40brief%20PORT%20peripheral%20base%20pointer%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%23define%20BOARD_INITPINS_LCD_BL_PIN%2017U%20%2F*!%26lt%3B%40brief%20PORT%20pin%20number%20*%2F%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%23define%20BOARD_INITPINS_LCD_BL_PIN_MASK%20(1U%20%26lt%3B%26lt%3B%2017U)%20%2F*!%26lt%3B%40brief%20PORT%20pin%20mask%20*%2F%3C%2FFONT%3E%3C%2FPRE%3E%3C%2FDIV%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AC%A1%E3%81%AB%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB.c%E3%81%A7%3C%2FP%3E%3CDIV%3E%3CPRE%20translate%3D%22no%22%3EgpioPinConfig%20%3D%20createAdapterGpioPinConfig(%3CSTRONG%3EBOARD_INITPINS_LCD_BL_PORT%3C%2FSTRONG%3E%2C%20BOARD_INITPINS_LCD_BL_PIN%2C%20BOARD_INITPINS_LCD_BL_PIN_DIRECTION%2C%20BOARD_INITPINS_LCD_BL_PIN_LEVEL)%3B%3C%2FPRE%3E%3CP%3E%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3EgpioPinConfig%20%3D%20createAdapterGpioPinConfig(%3CSTRONG%3EBOARD_INITPINS_LCD_BL_GPIO%3C%2FSTRONG%3E%2C%20BOARD_INITPINS_LCD_BL_PIN%2C%20BOARD_INITPINS_LCD_BL_PIN_DIRECTION%2C%20BOARD_INITPINS_LCD_BL_PIN_LEVEL)%3B%3C%2FPRE%3E%3C%2FDIV%3E%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81peripherals.c%20%E3%81%AE%E6%89%8B%E5%8B%95%E7%B7%A8%E9%9B%86%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E6%81%92%E4%B9%85%E7%9A%84%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%AF%BE%E8%B1%A1%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%3A%20MCXW71%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2351026%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%A8IO%7CGPIO%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2351108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Pin%20Assigment%20Tool%20Bugged%20For%20GPIOs%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2351108%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F257898%22%20target%3D%22_blank%22%3E%40cnebe-autopac%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E8%87%AA%E8%BA%AB%E3%82%82%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2026-04-15_12-25-10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-04-15_12-25-10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382384i66CB387E559549DF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snipaste_2026-04-15_12-25-10.png%22%20alt%3D%22Snipaste_2026-04-15_12-25-10.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%2F*%20Get%20GPIO%20pin%20configuration%20*%2F%0Ahal_gpio_pin_config_t%20createAdapterGpioPinConfig(GPIO_Type%20*port%2C%20uint8_t%20pin%2C%20hal_gpio_direction_t%20direction%2C%20uint8_t%20level)%7B%0A%20%20hal_gpio_pin_config_t%20temp%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Snipaste_2026-04-15_12-25-10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Snipaste_2026-04-15_12-25-10.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382385i1F09589ED3EFE9A4%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Snipaste_2026-04-15_12-25-10.png%22%20alt%3D%22Snipaste_2026-04-15_12-25-10.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
