#MCXN547 ethernet
#MCXN547 ethernet
jeremyyang
HI Sir ,
We use MCXN547VKLT MCU + KSZ8081RNBIA (PHY ) ,
and need to test 10M Compliance test , After check to Microchip ,
We need set register form MCU to pseudo random pattern ,
DO you know how to set up the Firmware ?@joey
from microship as below
the test signal need generate from MAC' and through MII/RMII to PHY to generate packets
Labels (2)
Tags (2)
EdwinHz
Hi @jeremyyang,
Please take a look at the enet example codes that you can find from the MCX-N5XX-EVK SDK. There, you will find the base line on how to configure the ethernet peripheral for the compliance test your require.
BR,
Edwin.
jeremyyang
from lab , need configure idle pattern (random Data )
how to configure ?
jeremyyang
add test item
