MCXA265VPN Layout Suggestion
DanRogers
NXP Team,
Do you have a MCXA265VPN fanout example?  Need recommended via pad and hole size.  Are the vias in pads or between pins?  Need to have a solid GND plane under BGA?
Please help.
Thanks Dan Rogers
db16122
DanRogers
Team,
Do you have a demo board with suggested routing? I need to know:
Trace widths sizes used to route between BGA pins?
Via types used and pad sizes with hole size?
  • thru hole, bbvia, stacked?
Spacings used between pins after routing?
DESCRIPTION = MCXA265VPN, NXP SEMICONDUCTORS
MXCA_169_BGA169 (10 mil pads with 19.7 mil pitch between pins)
Thank you very much. for your support.
Dan Rogers
%3CLINGO-SUB%20id%3D%22lingo-sub-2387350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCXA265VPN%20Layout%20Suggestion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2387350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%20Team%2C%3C%2FP%3E%3CP%3EDo%20you%20have%20a%26nbsp%3BMCXA265VPN%20fanout%20example%3F%26nbsp%3B%20Need%20recommended%20via%20pad%20and%20hole%20size.%26nbsp%3B%20Are%20the%20vias%20in%20pads%20or%20between%20pins%3F%26nbsp%3B%20Need%20to%20have%20a%20solid%20GND%20plane%20under%20BGA%3F%3C%2FP%3E%3CP%3EPlease%20help.%3C%2FP%3E%3CP%3EThanks%20Dan%20Rogers%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2387350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EBoard%20Design%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXA265VPN%20Layout%20Suggestion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395964%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ETeam%2C%3C%2FP%3E%3CP%3EDo%20you%20have%20a%20demo%20board%20with%20suggested%20routing%3F%20I%20need%20to%20know%3A%3C%2FP%3E%3CP%3ETrace%20widths%20sizes%20used%20to%20route%20between%20BGA%20pins%3F%3C%2FP%3E%3CP%3EVia%20types%20used%20and%20pad%20sizes%20with%20hole%20size%3F%3C%2FP%3E%3CUL%3E%3CLI%3Ethru%20hole%2C%20bbvia%2C%20stacked%3F%3C%2FLI%3E%3C%2FUL%3E%3CP%3ESpacings%20used%20between%20pins%20after%20routing%3F%3C%2FP%3E%3CP%3E%3CSPAN%3EDESCRIPTION%20%3D%20MCXA265VPN%2C%20NXP%20SEMICONDUCTORS%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EMXCA_169_BGA169%20(10%20mil%20pads%20with%2019.7%20mil%20pitch%20between%20pins)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThank%20you%20very%20much.%20for%20your%20support.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EDan%20Rogers%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
