MCF5480 boot debug error
2,060件の閲覧回数
manonroad
i repaired a MCF5480 board,while booting,i meet some UART error. i want to know,if this error caused by hardware damage?
4 返答(返信)
1,930件の閲覧回数
manonroad
Thanks for your reply.This error occured  between MCF5480 and a DSP chip .They communicated through UART3,While system init, RTS and CTS signals reported error.This snap picture's messages obtained from the debug UART Port. Did this error caused by a hardware fault?
1,924件の閲覧回数
Bio_TICFSL
Yes, Change the configuration in the DSP.
1,899件の閲覧回数
manonroad
The MCF5480 and DSP worked correctly everbefore.I didn't change anything about hardware or  software.  While  VFP software displayed  "Dual Port RAM Uninitialized".
   As you mean,how to change DSP's program?
1,944件の閲覧回数
Bio_TICFSL
The error "RTS 200100 was not 0" in ColdFire processors indicates a critical communication failure between the debugger and the chip. This code is often tied to "invalid parameters" or a synchronization mismatch during the flash programming or erase process.
Key Causes and Solutions
  • Debugger Driver Incompatibility: This is the most common cause. Using older versions of CodeWarrior on modern operating systems (Windows 10/11) often causes driver conflicts with the P&E Multilink interface.
    • Solution: Install the latest P&E Micro drivers or run your development environment in a Windows XP/7 Virtual Machine.
  • Target Initialization Issues: The target initialization file (often a .tcl or .cfg script) might contain incorrect parameters for the flash base address, bank size, or clock settings (PLL).
    • Solution: Verify that the flash base address and memory map in your project settings match your specific ColdFire model Enable "Verify Target Memory Writes" in the Target Configuration to check if the algorithm downloads correctly.
  • USB Port Speed Issues: High-speed USB 3.0 ports can sometimes be too fast for older BDM/JTAG debuggers, leading to timing errors.
    • Solution: Connect the debugger through a powered USB 2.0 hub or try a different USB port on your machine.
  • Hardware Interference: Improper hardware connections or interference on the BDM lines can trigger communication losses.
    • Solution: Check for cold solder joints on the BDM header and ensure you are not using an excessively long ribbon cable.
Debugging Steps
  1. Check for duplicate processes: Open Task Manager and ensure there isn't another instance of pegdbserver_console or the debugger running.
  2. Verify the Hardware ID: Ensure the hardware selected in the NXP Community or IDE matches the physical chip on your board (e.g., ColdFire V1 vs V2).
  3. Power Cycle: Completely power down both the target board and the debugger to reset the communication interface.
%3CLINGO-SUB%20id%3D%22lingo-sub-2346695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCF5480%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMCF5480%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BF%AE%E7%90%86%E3%81%97%E3%81%9F%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%81%ABUART%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%90%8D%E5%82%B7%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381513i1475F92018BD69A6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381512i2DEA59159B870BCF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2346695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%96%E3%83%BC%E3%83%88ROM%7C%E3%83%96%E3%83%BC%E3%83%88%7C%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCF5480%20boot%20debug%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMCF5480%E3%81%A8DSP%E3%81%AF%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%9A%E3%81%A3%E3%81%A8%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%82%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%82%E4%BD%95%E3%82%82%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82VFP%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%AF%E3%80%8C%3CSPAN%3E%E3%83%87%E3%83%A5%E3%82%A2%E3%83%AB%E3%83%9D%E3%83%BC%E3%83%88RAM%E3%81%8C%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%E3%80%8D%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81DSP%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%8B%E3%81%A8%E3%81%84%E3%81%86%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%AD%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCF5480%20boot%20debug%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%81%AF%E3%81%84%E3%80%81DSP%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCF5480%20boot%20debug%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AFMCF5480%E3%81%A8DSP%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E9%96%93%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E4%B8%A1%E8%80%85%E3%81%AFUART3%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E9%80%9A%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%88%9D%E6%9C%9F%E5%8C%96%E4%B8%AD%E3%81%ABRTS%E3%81%8A%E3%82%88%E3%81%B3CTS%E4%BF%A1%E5%8F%B7%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%81%AE%E3%82%B9%E3%83%8A%E3%83%83%E3%83%97%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E7%94%BB%E5%83%8F%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%B0UART%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8B%E3%82%89%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%95%85%E9%9A%9C%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCF5480%20boot%20debug%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAhAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3EColdFire%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%80%8CRTS%20200100%E3%81%8C0%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%8D%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%A8%E3%83%81%E3%83%83%E3%83%97%E9%96%93%E3%81%AE%E9%87%8D%E5%A4%A7%E3%81%AA%E9%80%9A%E4%BF%A1%E9%9A%9C%E5%AE%B3%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%BE%E3%81%9F%E3%81%AF%E6%B6%88%E5%8E%BB%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E4%B8%AD%E3%81%AE%E3%80%8C%E7%84%A1%E5%8A%B9%E3%81%AA%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%80%8D%E3%81%BE%E3%81%9F%E3%81%AF%E5%90%8C%E6%9C%9F%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%A4%9A%E3%81%84%E3%81%A7%E3%81%99%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_m%2CK4nz9c_n%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_l%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FDIV%3E%0A%3CDIV%20class%3D%22Fsg96%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22otQkpb%22%20role%3D%22heading%22%20data-sae%3D%22%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%20data-animation-nesting%3D%22%22%20aria-level%3D%223%22%3E%E4%B8%BB%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%A8%E8%A7%A3%E6%B1%BA%E7%AD%96%3C%2FDIV%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E5%95%8F%E9%A1%8C%EF%BC%9A%E3%81%93%E3%82%8C%E3%81%8C%E6%9C%80%E3%82%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E5%8E%9F%E5%9B%A0%E3%81%A7%E3%81%99%E3%80%82%E6%9C%80%E6%96%B0%E3%81%AE%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%EF%BC%88Windows%2010%2F11%EF%BC%89%E3%81%A7%E5%8F%A4%E3%81%84%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AECodeWarrior%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%3CA%20class%3D%22H23r4e%22%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Fsupport%2Findex.cfm%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-sb%3D%22%2Furl%3Fsa%3Di%26amp%3Bsource%3Dweb%26amp%3Brct%3Dj%26amp%3Burl%3Dhttps%3A%2F%2Fwww.pemicro.com%2Fsupport%2Findex.cfm%26amp%3Bved%3D2ahUKEwiv6YfVguuTAxXZg2oFHYDEFygQy_kOegYIAQgDEAE%26amp%3Bopi%3D89978449%26amp%3Bcd%26amp%3Bpsig%3DAOvVaw2gAIC1XNa4xs7m04Q4K7N6%26amp%3Bust%3D1776176351380000%22%20data-hveid%3D%22CAEIAxAB%22%20target%3D%22_blank%22%3E%E3%80%81P%26amp%3BE%20Multilink%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3C%2FA%3E%E3%81%A8%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E7%AB%B6%E5%90%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%88%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_y%2CK4nz9c_z%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_x%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAE%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%EF%BC%9A%E6%9C%80%E6%96%B0%E3%81%AE%3CA%20class%3D%22H23r4e%22%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Fsupport%2Fdownload_processor.cfm%3Ftype%3D5%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-sb%3D%22%2Furl%3Fsa%3Di%26amp%3Bsource%3Dweb%26amp%3Brct%3Dj%26amp%3Burl%3Dhttps%3A%2F%2Fwww.pemicro.com%2Fsupport%2Fdownload_processor.cfm%3Ftype%253D5%26amp%3Bved%3D2ahUKEwiv6YfVguuTAxXZg2oFHYDEFygQy_kOegYIAQgDEAU%26amp%3Bopi%3D89978449%26amp%3Bcd%26amp%3Bpsig%3DAOvVaw2gAIC1XNa4xs7m04Q4K7N6%26amp%3Bust%3D1776176351380000%22%20data-hveid%3D%22CAEIAxAF%22%20target%3D%22_blank%22%3EP%26amp%3BE%20Micro%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%3C%2FA%3E%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E9%96%8B%E7%99%BA%E7%92%B0%E5%A2%83%E3%82%92Windows%20XP%2F7%E4%BB%AE%E6%83%B3%E3%83%9E%E3%82%B7%E3%83%B3%E4%B8%8A%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAG%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AE%E5%95%8F%E9%A1%8C%3A%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E5%88%9D%E6%9C%9F%E5%8C%96%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20(%E5%A4%9A%E3%81%8F%E3%81%AE%E5%A0%B4%E5%90%88%3CCODE%20class%3D%22KDcb0c%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E.tcl%3C%2FCODE%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB)%E3%81%BE%E3%81%9F%E3%81%AF%3CCODE%20class%3D%22KDcb0c%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E.cfg%3C%2FCODE%3E%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%EF%BC%89%E3%81%AB%E3%81%AF%E3%80%81%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%80%81%E3%83%90%E3%83%B3%E3%82%AF%E3%82%B5%E3%82%A4%E3%82%BA%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E8%A8%AD%E5%AE%9A%EF%BC%88PLL%EF%BC%89%E3%81%AE%E8%AA%A4%E3%81%A3%E3%81%9F%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_1c%2CK4nz9c_1d%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_1b%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAJ%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%3A%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AE%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%99%E3%83%BC%E3%82%B9%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%A8%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9E%E3%83%83%E3%83%97%E3%81%8C%E3%80%81%E3%81%94%E4%BD%BF%E7%94%A8%E3%81%AE%20ColdFire%20%E3%83%A2%E3%83%87%E3%83%AB%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E6%A7%8B%E6%88%90%E3%81%A7%E3%80%8C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%A1%E3%83%A2%E3%83%AA%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AE%E6%A4%9C%E8%A8%BC%E3%80%8D%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_1l%2CK4nz9c_1m%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_1k%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAM%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3EUSB%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E9%80%9F%E5%BA%A6%E3%81%AE%E5%95%8F%E9%A1%8C%3A%20%E9%AB%98%E9%80%9F%20USB%203.0%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AF%E3%80%81%E5%8F%A4%E3%81%84%20BDM%2FJTAG%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%AB%E3%81%AF%E9%80%9F%E3%81%99%E3%81%8E%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%20%E3%82%A8%E3%83%A9%E3%83%BC%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_1s%2CK4nz9c_1t%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_1r%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAP%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%EF%BC%9A%E9%9B%BB%E6%BA%90%E4%BB%98%E3%81%8D%E3%81%AEUSB%202.0%E3%83%8F%E3%83%96%E7%B5%8C%E7%94%B1%E3%81%A7%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%82%92%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%94%E3%83%A5%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E5%88%A5%E3%81%AEUSB%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAQ%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E5%B9%B2%E6%B8%89%3A%20%E4%B8%8D%E9%81%A9%E5%88%87%E3%81%AA%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%8E%A5%E7%B6%9A%E3%81%BE%E3%81%9F%E3%81%AF%20BDM%20%E3%83%A9%E3%82%A4%E3%83%B3%E4%B8%8A%E3%81%AE%E5%B9%B2%E6%B8%89%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E9%80%9A%E4%BF%A1%E6%90%8D%E5%A4%B1%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_24%2CK4nz9c_25%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_23%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAT%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E8%A7%A3%E6%B1%BA%E7%AD%96%EF%BC%9ABDM%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AE%E3%81%AF%E3%82%93%E3%81%A0%E4%BB%98%E3%81%91%E4%B8%8D%E8%89%AF%E3%81%8C%E3%81%AA%E3%81%84%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%80%81%E3%83%AA%E3%83%9C%E3%83%B3%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E9%95%B7%E3%81%99%E3%81%8E%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CDIV%20class%3D%22Fsg96%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22otQkpb%22%20role%3D%22heading%22%20data-sae%3D%22%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%20data-animation-nesting%3D%22%22%20aria-level%3D%223%22%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%89%8B%E9%A0%86%3C%2FDIV%3E%0A%3COL%20class%3D%22IaGLZe%20VimKh%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E9%87%8D%E8%A4%87%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%99%3A%20%E3%82%BF%E3%82%B9%E3%82%AF%E3%83%9E%E3%83%8D%E3%83%BC%E3%82%B8%E3%83%A3%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%20%3CCODE%20class%3D%22KDcb0c%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3Epegdbserver_console%3C%2FCODE%3E%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%AE%E5%88%A5%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_2p%2CK4nz9c_2q%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_2o%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAD%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20ID%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%3A%20%3CA%20class%3D%22H23r4e%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2F%22%20data-sb%3D%22%2Furl%3Fsa%3Di%26amp%3Bsource%3Dweb%26amp%3Brct%3Dj%26amp%3Burl%3Dhttps%3A%2F%2Fcommunity.nxp.com%2F%26amp%3Bved%3D2ahUKEwiv6YfVguuTAxXZg2oFHYDEFygQy_kOegYIAQgEEAQ%26amp%3Bopi%3D89978449%26amp%3Bcd%26amp%3Bpsig%3DAOvVaw2gAIC1XNa4xs7m04Q4K7N6%26amp%3Bust%3D1776176351380000%22%20data-hveid%3D%22CAEIBBAE%22%20target%3D%22_blank%22%3ENXP%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%83%86%E3%82%A3%3C%2FA%3E%E3%81%BE%E3%81%9F%E3%81%AF%20IDE%20%E3%81%A7%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E7%89%A9%E7%90%86%E3%83%81%E3%83%83%E3%83%97%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%20(%E4%BE%8B%3A%20ColdFire%20V1%20%E3%81%A8%20V2)%20%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_2x%2CK4nz9c_2y%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_2w%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAH%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20aria-owns%3D%22action-menu-parent-container%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E9%9B%BB%E6%BA%90%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%EF%BC%9A%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A8%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E5%88%87%E3%81%A3%E3%81%A6%E3%80%81%E9%80%9A%E4%BF%A1%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%20class%3D%22T286Pc%22%20aria-owns%3D%22action-menu-parent-container%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
