KW45 RSSI calculation
Chan_17
hello nxp team,
I am using UI application to receive data, I want to calculate RSSI value from peripheral of sending ble packet is it possible?
i am sending data over BLE from peripheral and i want to calculate sending RSSI means , RSSI value of data we are sending from peripheral to UI app.
i checked in SDK example there is one function :
#define Gap_ReadRssi(deviceId)\
Gap_ReadRadioPowerLevel(gRssi_c, (deviceId))
if i use this in peripheral side is it works? if not is there any way to calculate RSSI from peripheral side.
Ricardo_Zamora
Hope you are doing well. The RSSI (Received Signal Strength Indicator) is read at the receiver side of the connection, not on the transmitter.
You could check different gapRadioPowerLevelReadType_t available that can be used with Gap_ReadRadioPowerLevel.
Ricardo
%3CLINGO-SUB%20id%3D%22lingo-sub-2146709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW45%20RSSI%20calculation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Ehello%20nxp%20team%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20am%20using%20UI%20application%20to%20receive%20data%2C%20I%20want%20to%20calculate%20RSSI%20value%20from%20peripheral%20of%20sending%20ble%20packet%20is%20it%20possible%3F%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ei%20am%20sending%20data%20over%20BLE%20from%20peripheral%20and%20i%20want%20to%20calculate%20sending%20RSSI%20means%20%2C%20RSSI%20value%20of%20data%20we%20are%20sending%20from%20peripheral%20to%20UI%20app.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ei%20checked%20in%20SDK%20example%20there%20is%20one%20function%20%3A%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3E%23define%3C%2FSPAN%3E%20%3CSPAN%3EGap_ReadRssi%3C%2FSPAN%3E%3CSPAN%3E(deviceId)%5C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EGap_ReadRadioPowerLevel(g%3C%2FSPAN%3E%3CSPAN%3ERssi%3C%2FSPAN%3E%3CSPAN%3E_c%2C%20(deviceId))%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3Eif%20i%20use%20this%20in%20peripheral%20side%20is%20it%20works%3F%20if%20not%20is%20there%20any%20way%20to%20calculate%20RSSI%20from%20peripheral%20side.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2146709%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ECommunication%20%26amp%3B%20Control(I3C%20%7C%20I2C%20%7C%20SPI%20%7C%20FlexCAN%20%7C%20Ethernet%20%7C%20FlexIO)%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EDevelopment%20Board%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20RSSI%20calculation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147810%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHope%20you%20are%20doing%20well.%20The%20RSSI%20(Received%20Signal%20Strength%20Indicator)%20is%20read%20at%20the%20receiver%20side%20of%20the%20connection%2C%20not%20on%20the%20transmitter.%3C%2FP%3E%0A%3CP%3EYou%20could%20check%20different%20gapRadioPowerLevelReadType_t%20available%20that%20can%20be%20used%20with%20Gap_ReadRadioPowerLevel.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ERicardo%3C%2FP%3E%3C%2FLINGO-BODY%3E
