KW45 RSSI calculation
Chan_17
hello nxp team,
I am using UI application to receive data, I want to calculate RSSI value from peripheral of sending ble packet is it possible?
i am sending data over BLE from peripheral and i want to calculate sending RSSI means , RSSI value of data we are sending from peripheral to UI app.
i checked in SDK example there is one function :
#define Gap_ReadRssi(deviceId)\
Gap_ReadRadioPowerLevel(gRssi_c, (deviceId))
if i use this in peripheral side is it works? if not is there any way to calculate RSSI from peripheral side.
Ricardo_Zamora
Hope you are doing well. The RSSI (Received Signal Strength Indicator) is read at the receiver side of the connection, not on the transmitter.
You could check different gapRadioPowerLevelReadType_t available that can be used with Gap_ReadRadioPowerLevel.
Ricardo
