How to flash a .bin at a specific flash offset on i.MX RT1064 using PEMicro Multilink LC?
333 次查看
shreya_v16
I’m working with an i.MX RT1064 and using a PEMicro Multilink LC debug probe.
I need to program a bootloader and application at different offsets in program flash. For example, the bootloader would be placed at the start of flash and the application at a defined offset.
With the i.MX RT1064 EVK, I was able to use LinkFlash to program a .bin file at a specified flash address. However, I’m now using the PEMicro Multilink LC and would like to know what the equivalent programming workflow is.
I cannot merge the bootloader and application into a single .bin, because the application is part of a partitioned firmware layout and needs to be signed as a separate firmware image. Therefore, I need to keep the bootloader and application as separate binaries and program the application at its designated flash offset.
What external programming application/tool should I use with the PEMicro Multilink LC to flash a .bin file at a specific address/offset on the i.MX RT1064?
Ideally, I would like to be able to select the .bin file, specify its destination address, and program it directly, without having to merge the bootloader and application into a single binary.
Thanks!
303 次查看
Gavin_Jia
Hi @shreya_v16 ,
NXP LinkServer/LinkFlash supports programming a standalone .bin file at a specified address, but it does not support the PEMicro Multilink LC probe.
To continue using the PEMicro Multilink LC, please use PEmicro PROG-HL-ARM (PROGACMP). Recent versions support the QB command. Therefore, the bootloader and signed application can remain separate and be programmed at their respective addresses without merging them.
Please refer to:
1. https://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320181
2. https://www.nxp.com/docs/en/user-guide/PROGACMP_UM.pdf
Gavin
279 次查看
shreya_v16
Hi @Gavin_Jia,
Thank you for your prompt reply. Yes, I am aware of PROG-HL-ARM (PROGACMP) but as you know it is a paid tool. I was looking for any free alternatives. Please suggest if you know of any
%3CLINGO-SUB%20id%3D%22lingo-sub-2407673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%88%B7%E5%86%99%20.bin%20%E6%96%87%E4%BB%B6%E5%9C%A8%20i.MX%20RT1064%20%E4%B8%8A%E4%BD%BF%E7%94%A8%20PEMicro%20Multilink%20LC%20%E6%97%B6%EF%BC%8C%E5%9C%A8%E7%89%B9%E5%AE%9A%E7%9A%84%E9%97%AA%E5%AD%98%E5%81%8F%E7%A7%BB%E9%87%8F%E4%B8%8B%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3Ei.MX%20RT1064%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%E5%92%8C%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3EPEMicro%20Multilink%20LC%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%E8%B0%83%E8%AF%95%E6%8E%A2%E9%92%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%86%E5%BC%95%E5%AF%BC%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3E%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%88%86%E5%88%AB%E5%86%99%E5%85%A5%E7%BC%96%E7%A8%8B%E9%97%AA%E5%AD%98%E7%9A%84%E4%B8%8D%E5%90%8C%E5%81%8F%E7%A7%BB%E4%BD%8D%E7%BD%AE%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%B0%86%E6%94%BE%E7%BD%AE%E5%9C%A8%E9%97%AA%E5%AD%98%E7%9A%84%E8%B5%B7%E5%A7%8B%E4%BD%8D%E7%BD%AE%EF%BC%8C%E8%80%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%88%99%E6%94%BE%E7%BD%AE%E5%9C%A8%E6%8C%87%E5%AE%9A%E7%9A%84%E5%81%8F%E7%A7%BB%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E4%BD%BF%E7%94%A8%20i.MX%20RT1064%20EVK%20%E6%97%B6%EF%BC%8C%E6%88%91%E8%83%BD%E5%A4%9F%E4%BD%BF%E7%94%A8%3C%2FSPAN%3E%3CSTRONG%3E%3CSPAN%3ELinkFlash%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSPAN%3E%E5%B0%86%3C%2FSPAN%3E%3CSPAN%3E.bin%3C%2FSPAN%3E%3CSPAN%3E%E6%96%87%E4%BB%B6%E7%BC%96%E7%A8%8B%E5%88%B0%E6%8C%87%E5%AE%9A%E7%9A%84%E9%97%AA%E5%AD%98%E5%9C%B0%E5%9D%80%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E7%8E%B0%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20PEMicro%20Multilink%20LC%EF%BC%8C%E6%83%B3%E7%9F%A5%E9%81%93%E7%AD%89%E6%95%88%E7%9A%84%E7%BC%96%E7%A8%8B%E6%B5%81%E7%A8%8B%E6%98%AF%E4%BB%80%E4%B9%88%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E6%88%91%3CSTRONG%3E%E6%97%A0%E6%B3%95%E5%B0%86%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%88%E5%B9%B6%E5%88%B0%E5%8D%95%E4%B8%AA%3C%2FSTRONG%3E%3CSTRONG%3E.bin%3C%2FSTRONG%3E%E6%96%87%E4%BB%B6%E4%B8%AD%E3%80%82%E5%9B%A0%E4%B8%BA%E8%AF%A5%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%98%AF%E5%88%86%E5%8C%BA%E5%9B%BA%E4%BB%B6%E5%B8%83%E5%B1%80%E7%9A%84%E4%B8%80%E9%83%A8%E5%88%86%EF%BC%8C%E9%9C%80%E8%A6%81%3CSTRONG%3E%E4%BD%9C%E4%B8%BA%E5%8D%95%E7%8B%AC%E7%9A%84%E5%9B%BA%E4%BB%B6%E6%98%A0%E5%83%8F%E8%BF%9B%E8%A1%8C%E7%AD%BE%E5%90%8D%3C%2FSTRONG%3E%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%86%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BD%9C%E4%B8%BA%E5%8D%95%E7%8B%AC%E7%9A%84%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%BC%96%E7%A8%8B%E5%88%B0%E5%85%B6%E6%8C%87%E5%AE%9A%E7%9A%84%E9%97%AA%E5%AD%98%E5%81%8F%E7%A7%BB%E9%87%8F%E5%A4%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSTRONG%3E%3CSPAN%3E%E6%88%91%E5%BA%94%E8%AF%A5%E4%BD%BF%E7%94%A8%E4%BB%80%E4%B9%88%E5%A4%96%E9%83%A8%E7%BC%96%E7%A8%8B%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%2F%E5%B7%A5%E5%85%B7%E9%85%8D%E5%90%88%20PEMicro%20Multilink%20LC%20%E5%B0%86%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CSPAN%3E.bin%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CSTRONG%3E%3CSPAN%3E%E6%96%87%E4%BB%B6%E7%83%A7%E5%BD%95%E5%88%B0%20i.MX%20RT1064%20%E7%9A%84%E7%89%B9%E5%AE%9A%E5%9C%B0%E5%9D%80%2F%E5%81%8F%E7%A7%BB%E9%87%8F%E5%A4%84%EF%BC%9F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20class%3D%22%22%3E%3CSPAN%3E%E7%90%86%E6%83%B3%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%88%91%E5%B8%8C%E6%9C%9B%E8%83%BD%E5%A4%9F%E9%80%89%E6%8B%A9%3C%2FSPAN%3E%3CSPAN%3E.bin%3C%2FSPAN%3E%3CSPAN%3E%E6%96%87%E4%BB%B6%EF%BC%8C%E6%8C%87%E5%AE%9A%E5%85%B6%E7%9B%AE%E6%A0%87%E5%9C%B0%E5%9D%80%EF%BC%8C%E5%B9%B6%E7%9B%B4%E6%8E%A5%E5%AF%B9%E5%85%B6%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E5%B0%86%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%88%E5%B9%B6%E5%88%B0%E5%8D%95%E4%B8%AA%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E4%B8%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2407673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%90%AF%E5%8A%A8%20ROM%20%7C%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%20%7C%20%E9%97%AA%E5%AD%98%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20flash%20a%20.bin%20at%20a%20specific%20flash%20offset%20on%20i.MX%20RT1064%20using%20PEMicro%20Multilink%20LC%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408407%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265875%22%20target%3D%22_blank%22%3E%40shreya_v16%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3ENXP%20LinkServer%2FLinkFlash%20%E6%94%AF%E6%8C%81%E5%AF%B9%20%E7%8B%AC%E7%AB%8B%E7%BB%84%E7%BD%91%20(SA)%20.bin%20%E6%96%87%E4%BB%B6%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E3%80%82%E6%96%87%E4%BB%B6%E4%BD%8D%E4%BA%8E%E6%8C%87%E5%AE%9A%E5%9C%B0%E5%9D%80%EF%BC%8C%E4%BD%86%E4%B8%8D%E6%94%AF%E6%8C%81%20PEMicro%20Multilink%20LC%20%E6%8E%A2%E9%92%88%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E7%BB%A7%E7%BB%AD%E4%BD%BF%E7%94%A8%20PEMicro%20Multilink%20LC%EF%BC%8C%E8%AF%B7%E4%BD%BF%E7%94%A8%20PEmicro%20PROG-HL-ARM%20(PROGACMP)%E3%80%82%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E6%94%AF%E6%8C%81%20QB%20%E5%91%BD%E4%BB%A4%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%92%8C%E5%B7%B2%E7%AD%BE%E5%90%8D%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%8F%AF%E4%BB%A5%E4%BF%9D%E6%8C%81%E5%88%86%E7%A6%BB%EF%BC%8C%E5%B9%B6%E5%9C%A8%E5%90%84%E8%87%AA%E7%9A%84%E5%9C%B0%E5%9D%80%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%EF%BC%8C%E8%80%8C%E6%97%A0%E9%9C%80%E5%90%88%E5%B9%B6%E5%AE%83%E4%BB%AC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%EF%BC%9A%3C%2FP%3E%0A%3CP%3E1.%20%3CA%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Fproducts%2Fproduct_viewDetails.cfm%3Fproduct_id%3D15320181%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.pemicro.com%2Fproducts%2Fproduct_viewDetails.cfm%3Fproduct_id%3D15320181%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E2.%20%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FPROGACMP_UM.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FPROGACMP_UM.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E5%8A%A0%E6%96%87%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2409063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20flash%20a%20.bin%20at%20a%20specific%20flash%20offset%20on%20i.MX%20RT1064%20using%20PEMicro%20Multilink%20LC%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2409063%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F203261%22%20target%3D%22_blank%22%3E%40Gavin_Jia%3C%2FA%3E%20%EF%BC%8C%3CBR%20%2F%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8A%E6%97%B6%E5%9B%9E%E5%A4%8D%E3%80%82%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E7%9F%A5%E9%81%93%20PROG-HL-ARM%20(PROGACMP)%EF%BC%8C%E4%BD%86%E5%A6%82%E6%82%A8%E6%89%80%E7%9F%A5%EF%BC%8C%E5%AE%83%E6%98%AF%E4%B8%80%E4%B8%AA%E4%BB%98%E8%B4%B9%E5%B7%A5%E5%85%B7%E3%80%82%E6%88%91%E6%AD%A3%E5%9C%A8%E5%AF%BB%E6%89%BE%E4%BB%BB%E4%BD%95%E5%85%8D%E8%B4%B9%E7%9A%84%E6%9B%BF%E4%BB%A3%E6%96%B9%E6%A1%88%E3%80%82%E5%A6%82%E6%9E%9C%E6%82%A8%E7%9F%A5%E9%81%93%E4%BB%BB%E4%BD%95%E7%9B%B8%E5%85%B3%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E6%8F%90%E5%87%BA%E5%BB%BA%E8%AE%AE%E3%80%82%3C%2FLINGO-BODY%3E
