How to Integrate a C++ TFLite Model into a C-Based MCUXpresso Project?
349件の閲覧回数
sivamankomb
Hello NXP Team,
I am integrating a TensorFlow Lite Micro model into my MCUXpresso project for the MCXN947. My application is written in C, while the TensorFlow Lite Micro inference code and generated model are in C++.
I am encountering compilation and linking issues when combining the C and C++ source files. I have already tried using "extern C", but the issue remains.
Could you please advise on the following?
Is it recommended to mix C and C++ source files in an MCUXpresso project?
What is the recommended approach for integrating a C++ TensorFlow Lite Micro model into a C-based application?
Are there any required compiler/linker settings or reference examples for this integration?
Any guidance would be greatly appreciated. Thank you.
ラベル(2)
289件の閲覧回数
Celeste_Liu
Hello @sivamankomb ,
Thanks for your post.
Of course you can mix C and C++ source files in an MCUXpresso project. In fact, this is also the approach used in our SDK demos. For reference, you can review several eIQ-related example projects included in the SDK. The SDK is available for download from Select Board | MCUXpresso SDK Builder.
The key points are as follows:
- .c files are compiled as C code.
- .cpp files are compiled as C++ code.
- The final linking stage must use a toolchain that supports the C++ runtime and C++ symbol resolution.
- C code should only call functions exposed through extern "C" wrappers and should not directly include or use TFLM C++ classes, templates, or namespaces.
Therefore, the recommended approach is to encapsulate the TFLM inference implementation in a .cpp file and expose only a C ABI-compatible wrapper interface to the C application.
For example, in the SDK's tflm_label_image demo, the core TFLM inference logic is implemented in common/tflm/model.cpp. This file uses the TFLM C++ APIs, such as
#include "tensorflow/lite/micro/micro_interpreter.h"
#include "tensorflow/lite/micro/micro_op_resolver.h"
static const tflite::Model* s_model = nullptr;
static tflite::MicroInterpreter* s_interpreter = nullptr;
extern tflite::MicroOpResolver &MODEL_GetOpsResolver();
Then creating a tflite::MicroInterpreter instance and calling AllocateTensors() within MODEL_Init() to perform initialization.
The externally exposed model.h,  provides a C-friendly interface.
#if defined(__cplusplus)
extern "C" {
#endif
status_t MODEL_Init(void);
uint8_t* MODEL_GetInputTensorData(tensor_dims_t* dims, tensor_type_t* type);
uint8_t* MODEL_GetOutputTensorData(tensor_dims_t* dims, tensor_type_t* type);
void MODEL_ConvertInput(uint8_t* data, tensor_dims_t* dims, tensor_type_t type);
status_t MODEL_RunInference(void);
const char* MODEL_GetModelName(void);
#endif
The function declarations are exported through extern "C", allowing C source files to simply #include "model.h" and call functions such as MODEL_Init() and MODEL_RunInference() without needing any knowledge of C++ types like tflite::MicroInterpreter or MicroMutableOpResolver.
This architecture is also the approach adopted by our SDK examples and is generally recommended when integrating TFLM into a C-based application, as it cleanly isolates the C++ implementation details while preserving a pure C interface for the application layer.
If you want to integrate customer ML model to SDK demo, you can refer to AN14241 .
Hope it helps.
Celeste
%3CLINGO-SUB%20id%3D%22lingo-sub-2394072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EC%2B%2B%E3%81%AETFLite%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92C%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AEMCUXpresso%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ENXP%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AE%E7%9A%86%E6%A7%98%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFMCXN947%E3%81%AE%E3%81%9F%E3%82%81%E3%81%ABTensorFlow%20Lite%20Micro%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92MCUXpresso%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AFC%E3%81%A7%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81TensorFlow%20Lite%E3%81%AEMicro%E6%8E%A8%E8%AB%96%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E7%94%9F%E6%88%90%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AFC%2B%2B%E3%81%A7%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EC%E8%A8%80%E8%AA%9E%E3%81%A8C%2B%2B%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%B5%90%E5%90%88%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E3%80%81%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A8%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E6%97%A2%E3%81%AB%E3%80%8Cextern%20C%E3%80%8D%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E7%82%B9%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%A2%E3%83%89%E3%83%90%E3%82%A4%E3%82%B9%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3EMCUXpresso%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7C%E8%A8%80%E8%AA%9E%E3%81%A8C%2B%2B%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%B7%E5%9C%A8%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3EC%2B%2B%20TensorFlow%20Lite%20Micro%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92C%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AE%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E7%B5%B1%E5%90%88%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%EF%BC%8F%E3%83%AA%E3%83%B3%E3%82%AB%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%84%E5%8F%82%E8%80%83%E4%BE%8B%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%8B%E3%81%94%E5%8A%A9%E8%A8%80%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%A4%A7%E5%A4%89%E3%81%82%E3%82%8A%E3%81%8C%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2394072%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCX%20N%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20Integrate%20a%20C%2B%2B%20TFLite%20Model%20into%20a%20C-Based%20MCUXpresso%20Project%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394693%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F262607%22%20target%3D%22_blank%22%3E%40sivamankomb%20%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%82%E3%81%A1%E3%82%8D%E3%82%93%3CSPAN%3E%3C%2FSPAN%3E%3CSPAN%3E%E3%80%81MCUXpresso%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AFC%E3%81%A8C%2B%2B%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%B7%E3%81%9C%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%E5%AE%9F%E9%9A%9B%E3%80%81%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AESDK%E3%83%87%E3%83%A2%E3%81%A7%E3%82%82%E4%BD%BF%E3%82%8F%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%A7%E3%81%99%E3%80%82%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81SDK%E3%81%AB%E5%90%AB%E3%81%BE%E3%82%8C%E3%82%8B%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AEeIQ%E9%96%A2%E9%80%A3%E3%81%AE%E4%BE%8B%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82SDK%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fselect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3ESelect%20Board%20%7CMCUXpresso%20SDK%20Builder%3C%2FA%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Celeste_Liu_0-1784012914332.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Celeste_Liu_0-1784012914332.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392183i2A913368AEA86BFF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Celeste_Liu_0-1784012914332.png%22%20alt%3D%22Celeste_Liu_0-1784012914332.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E7%82%B9%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E-%20.c%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AFC%E8%A8%80%E8%AA%9E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20-%20.cpp%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AFC%2B%2B%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E-%20%E6%9C%80%E7%B5%82%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%81%A7%E3%81%AF%E3%80%81C%2B%2B%E3%83%A9%E3%83%B3%E3%82%BF%E3%82%A4%E3%83%A0%E3%81%8A%E3%82%88%E3%81%B3C%2B%2B%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%E8%A7%A3%E6%B1%BA%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E-%20C%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E5%A4%96%E9%83%A8%E3%81%AE%E3%80%8CC%E3%80%8D%E3%83%A9%E3%83%83%E3%83%91%E3%83%BC%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E5%85%AC%E9%96%8B%E3%81%95%E3%82%8C%E3%81%9F%E9%96%A2%E6%95%B0%E3%81%AE%E3%81%BF%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%80%81TFLM%20C%2B%2B%E3%81%AE%E3%82%AF%E3%83%A9%E3%82%B9%E3%80%81%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%80%81%E5%90%8D%E5%89%8D%E7%A9%BA%E9%96%93%E3%82%92%E7%9B%B4%E6%8E%A5%E5%90%AB%E3%82%81%E3%81%9F%E3%82%8A%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%82%8A%E3%81%97%E3%81%A6%E3%81%AF%E3%81%84%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%AF%E3%80%81TFLM%E6%8E%A8%E8%AB%96%E3%81%AE%E5%AE%9F%E8%A3%85%E3%82%92.cpp%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%82%AB%E3%83%97%E3%82%BB%E3%83%AB%E5%8C%96%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81C%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E3%81%AF%20C%20ABI%20%E4%BA%92%E6%8F%9B%E3%81%AE%E3%83%A9%E3%83%83%E3%83%91%E3%83%BC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%BF%E3%82%92%E5%85%AC%E9%96%8B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E4%BE%8B%E3%81%88%E3%81%B0%E3%80%81SDK%E3%81%AEtflm_label_image%E3%83%87%E3%83%A2%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B3%E3%82%A2%E3%81%A8%E3%81%AA%E3%82%8BTFLM%E6%8E%A8%E8%AB%96%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%81%8Ccommon%2Ftflm%2Fmodel.cpp%E3%81%A7%E5%AE%9F%E8%A3%85%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AFTFLM%20C%2B%2B%20API%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23include%20%22tensorflow%2Flite%2Fmicro%2Fmicro_interpreter.h%22%0A%23include%20%22tensorflow%2Flite%2Fmicro%2Fmicro_op_resolver.h%22%0A%0Astatic%20const%20tflite%3A%3AModel*%20s_model%20%3D%20nullptr%3B%0Astatic%20tflite%3A%3AMicroInterpreter*%20s_interpreter%20%3D%20nullptr%3B%0Aextern%20tflite%3A%3AMicroOpResolver%20%26amp%3BMODEL_GetOpsResolver()%3B%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AC%A1%E3%81%AB%E3%80%81tflite%3A%3AMicroInterpreter%20%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%82%B9%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81MODEL_Init()%20%E5%86%85%E3%81%A7%20AllocateTensors()%20%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E3%81%A6%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A4%96%E9%83%A8%E3%81%AB%E9%9C%B2%E5%87%BA%E3%81%97%E3%81%9F%E3%83%A2%E3%83%87%E3%83%AB.h%E3%80%81C%E3%81%AB%E5%84%AA%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23if%20defined(__cplusplus)%0Aextern%20%22C%22%20%7B%0A%23endif%0A%0Astatus_t%20MODEL_Init(void)%3B%0Auint8_t*%20MODEL_GetInputTensorData(tensor_dims_t*%20dims%2C%20tensor_type_t*%20type)%3B%0Auint8_t*%20MODEL_GetOutputTensorData(tensor_dims_t*%20dims%2C%20tensor_type_t*%20type)%3B%0Avoid%20MODEL_ConvertInput(uint8_t*%20data%2C%20tensor_dims_t*%20dims%2C%20tensor_type_t%20type)%3B%0Astatus_t%20MODEL_RunInference(void)%3B%0Aconst%20char*%20MODEL_GetModelName(void)%3B%0A%0A%23if%20defined(__cplusplus)%0A%7D%0A%23endif%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%96%A2%E6%95%B0%E5%AE%A3%E8%A8%80%E3%81%AF%E5%A4%96%E9%83%A8%E3%80%8CC%E3%80%8D%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%E3%81%95%E3%82%8C%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81C%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E5%8D%98%E3%81%AB%E3%80%8Cmodel.h%E3%80%8D%23include%20%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81tflite%3A%3AMicroInterpreter%E3%82%84MicroMutableOpResolver%E3%81%AE%E3%82%88%E3%81%86%E3%81%AAC%2B%2B%E5%9E%8B%E3%81%AE%E7%9F%A5%E8%AD%98%E3%82%92%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%9B%E3%81%9A%E3%81%AB%E3%80%81MODEL_Init()%E3%82%84MODEL_RunInference()%E3%81%AA%E3%81%A9%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%AF%E5%BD%93%E7%A4%BE%E3%81%AESDK%E4%BE%8B%E3%81%A7%E3%82%82%E6%8E%A1%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81C%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%ABTFLM%E3%82%92%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%AA%E3%81%9C%E3%81%AA%E3%82%89%E3%80%81C%2B%2B%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%82%92%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%81%AB%E5%88%86%E9%9B%A2%E3%81%97%E3%81%A4%E3%81%A4%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E5%B1%A4%E3%81%AE%E7%B4%94%E7%B2%8B%E3%81%AAC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BF%9D%E6%8C%81%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%A7%E5%AE%A2%E3%81%AEML%E3%83%A2%E3%83%87%E3%83%AB%E3%82%92SDK%E3%83%87%E3%83%A2%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%97%E3%81%9F%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DAN14241%26amp%3Blocation%3Dnull%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAN14241%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%BB%E3%83%AC%E3%82%B9%E3%83%86%3C%2FP%3E%3C%2FLINGO-BODY%3E
