Hello @Fpetersen, I'm doing good, thank you.
Could you please also share with me which MCUXpresso and SDK you are using? Additionally, since the "frdmmcxn947_lwip_ping_freertos_cm33" example is meant to be used with static IP assignment, could you please confirm if you are setting your PC IP to the one used in the example and the subnet mask to "255.255.255.0"?
If you have not changed your PC IP and subnet mask, please try by changing these parameters. If you have changed them, please try to do a mass erase (you should be able to do it in MCUXpresso with the GUI Flash Tool) and let me know if the behavior persists.
Best Regards!
