FRDM-MCXN947 Ethernet Issue
WestCoastDaz
Hi NXP Community,
I just purchased 3 FRDM-MCXN947 dev kits for a company project and I can't get the Ethernet port to pass data on one of them.  I am using Zephyr v4.3.0 and I have tested using the `http_server` sample.  This works on the other two but I can't get DHCP or static IPs to work on the remaining on.  The link lights are lit but it just times out trying to get a DHCP address and when static it's not routable.  The device also doesn't show up as a client in our network management tools.
Thoughts on other tests I can run?  Has this happened before?
Thanks in advance,
Daz
Harry_Zhang
Hi @WestCoastDaz
May I ask if all three chips are the same? Has the board been reworked?
I think you can also test the SDK lwIP demos.
If lwIP also fails to get DHCP or cannot respond to ping, I think this may be a hardware issue.
Harry
WestCoastDaz
Unfortunately I can't compare the chip versions as 2 of the DKs are being used in prototypes and I don't have access to them. The box on the non-working DK has a date code from 2429.
I don't have MCUXsspresso SDK installed only Zephyr is there another Zephyr example I could try?
Harry_Zhang
Hi @WestCoastDaz
If you don't have MCUXsspresso SDK installed.
I think you can try to test the
samples/net/sockets/echo_server/
or
samples/net/dhcpv4_client
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2311174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-MCXN947%20Ethernet%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2311174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%20Community%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI%20just%20purchased%203%20FRDM-MCXN947%20dev%20kits%20for%20a%20company%20project%20and%20I%20can't%20get%20the%20Ethernet%20port%20to%20pass%20data%20on%20one%20of%20them.%20%26nbsp%3BI%20am%20using%20Zephyr%20v4.3.0%20and%20I%20have%20tested%20using%20the%20%60http_server%60%20sample.%20%26nbsp%3BThis%20works%20on%20the%20other%20two%20but%20I%20can't%20get%20DHCP%20or%20static%20IPs%20to%20work%20on%20the%20remaining%20on.%20%26nbsp%3BThe%20link%20lights%20are%20lit%20but%20it%20just%20times%20out%20trying%20to%20get%20a%20DHCP%20address%20and%20when%20static%20it's%20not%20routable.%20%26nbsp%3BThe%20device%20also%20doesn't%20show%20up%20as%20a%20client%20in%20our%20network%20management%20tools.%3C%2FP%3E%3CP%3EThoughts%20on%20other%20tests%20I%20can%20run%3F%20%26nbsp%3BHas%20this%20happened%20before%3F%3C%2FP%3E%3CP%3EThanks%20in%20advance%2C%3C%2FP%3E%3CP%3EDaz%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2311174%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3ECommunication%20%26amp%3B%20Control(I3C%20%7C%20I2C%20%7C%20SPI%20%7C%20FlexCAN%20%7C%20Ethernet%20%7C%20FlexIO)%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EDevelopment%20Board%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXN%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2312475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXN947%20Ethernet%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2312475%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258562%22%20target%3D%22_blank%22%3E%40WestCoastDaz%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EMay%20I%20ask%20if%20all%20three%20chips%20are%20the%20same%3F%20Has%20the%20board%20been%20reworked%3F%3C%2FP%3E%0A%3CP%3EI%20think%20you%20can%20also%20test%20the%26nbsp%3BSDK%20lwIP%20demos.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1770257886923.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1770257886923.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1770257886923.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1770257886923.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F375587iB74B5BE6E90DF9A0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1770257886923.png%22%20alt%3D%22Harry_Zhang_0-1770257886923.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIf%20lwIP%20also%20fails%20to%20get%20DHCP%20or%20cannot%20respond%20to%20ping%2C%20I%20think%20this%20may%20be%20a%20hardware%20issue.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2313228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXN947%20Ethernet%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2313228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUnfortunately%20I%20can't%20compare%20the%20chip%20versions%20as%202%20of%20the%20DKs%20are%20being%20used%20in%20prototypes%20and%20I%20don't%20have%20access%20to%20them.%20The%20box%20on%20the%20non-working%20DK%20has%20a%20date%20code%20from%202429.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20don't%20have%20MCUXsspresso%20SDK%20installed%20only%20Zephyr%20is%20there%20another%20Zephyr%20example%20I%20could%20try%3F%3CBR%20%2F%3E%3CBR%20%2F%3EThanks%2C%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2314243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXN947%20Ethernet%20Issue%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2314243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258562%22%20target%3D%22_blank%22%3E%40WestCoastDaz%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIf%20you%20don't%26nbsp%3Bhave%20MCUXsspresso%20SDK%20installed.%3C%2FP%3E%0A%3CP%3EI%20think%20you%20can%20try%20to%20test%20the%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Esamples%2Fnet%2Fsockets%2Fecho_server%2F%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3Eor%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Esamples%2Fnet%2Fdhcpv4_client%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E
