FRDM-MCXA153 Y1 Crystal
joe1652
Hello, I'm using the FRDM-MCXA153 Eval Kit and I would like to know the purpose of the Y1 Crystal. I see that it is an 8Mhz crystal but it is not populated. Do I need to add that part on the board?
Thank you
Hi @joe1652
Y1 is the reserved footprint for the external 8 MHz crystal on the MCX A153. It is not populated by default on the FRDM-MCXA153 production board. Unless you specifically need to enable an external crystal clock source, there is no need to install it.
Thank you.
Alice
db16122
AN14798 System Oscillator Usage for MCX A series
Frequency is the main parameter for selecting the crystal. For MCX A series MCU, 8 MHz~50 MHz are supported
joe1652
What's the purpose of the crystal?
%3CLINGO-SUB%20id%3D%22lingo-sub-2383710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-MCXA153%20Y1%20Crystal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20I'm%20using%20the%20FRDM-MCXA153%20Eval%20Kit%20and%20I%20would%20like%20to%20know%20the%20purpose%20of%20the%20Y1%20Crystal.%20I%20see%20that%20it%20is%20an%208Mhz%20crystal%20but%20it%20is%20not%20populated.%20Do%20I%20need%20to%20add%20that%20part%20on%20the%20board%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2383710%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EBoard%20Design%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXA153%20Y1%20Crystal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383745%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EAN14798%20System%20Oscillator%20Usage%20for%20MCX%20A%20series%3C%2FP%3E%3CP%3EFrequency%20is%20the%20main%20parameter%20for%20selecting%20the%20crystal.%20For%20MCX%20A%20series%20MCU%2C%208%20MHz~50%20MHz%20are%20supported%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383748%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXA153%20Y1%20Crystal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383748%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EWhat's%20the%20purpose%20of%20the%20crystal%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2384626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXA153%20Y1%20Crystal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2384626%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F138937%22%20target%3D%22_blank%22%3E%40joseph_lindula%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EY1%20is%20the%20reserved%20footprint%20for%20the%20external%208%20MHz%20crystal%20on%20the%20MCX%20A153.%20It%20is%20not%20populated%20by%20default%20on%20the%20FRDM-MCXA153%20production%20board.%20Unless%20you%20specifically%20need%20to%20enable%20an%20external%20crystal%20clock%20source%2C%20there%20is%20no%20need%20to%20install%20it.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EThank%20you.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAlice%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
