Differences mpn UJA1076ATW/5V0/WD
jesusmorales24
Hello NXP support team,
My customer is looking for item #UJA1076ATW/5V0/WD,
I can propose either mpn UJA1076ATW/5V0/WDJ or mpn UJA1076ATW/5V0/WD,1
From the information provided online I could see that sufix "J" refers to the part being double sourced and suffix ",1" reffers to the part having automotive grade,
Can you please confirm if this is the only difference between the part required and my proposals? Can you please expand the information towards these differences?
Thanks!
JozefKozon
Hello Jesus,
technically there is no difference between these three part numbers (UJA1076ATW/5V0/WD, UJA1076ATW/5V0/WDJ and UJA1076ATW/5V0/WD,1).
The letters and numbers after the WD are just for marketing recognition. They have nothing to do with technical parameters. You can propose the two latter components as a replacement for the UJA1076ATW/5V0/WD.
With Best Regards,
Jozef
