Hello NXP Support Team,
Board: FRDM-MCXE31B
I am working with the NXP FRDM-MCXE31B / MCXE31 and would like to clarify a few points regarding the HSE FW feature flag, password handling, and Secure BAF behavior during Life Cycle (LC) advancement.
Could you please clarify the following:
Password location when HSE FW feature flag is enabled
According to Table 159, when the HSE FW feature flag is enabled, "the password is programmed by HSE firmware at different location” and is scanned by DCM during reset and retained in Standby.
Could you please provide the specific address or memory region where the password is programmed by the HSE firmware?
Also, which HSE firmware component/version is responsible for programming this password?
Behavior of address 0x1B00_0080
When the HSE FW feature flag is enabled, is the password location at 0x1B00_0080 completely ignored by the Secure BAF/DCM, or does it have any role in the authentication process?
Password continuity during LC advancement
If a password was previously programmed at 0x1B00_0080 while the HSE FW feature flag was disabled, and the device is subsequently configured with the HSE FW feature flag enabled, will the same previously programmed password still be used when advancing the device from OEM_PROD to IN_FIELD?
If not, could you please clarify how the password transition/handling is performed in this scenario?
HSE FW feature flag enabled without HSE firmware installed
Referring to Section 31.4.1 (page 790) and Section 31.4.4.1 (page 793), if the HSE FW feature flag at 0x1B00_0000 is enabled but no HSE firmware is installed, what is the expected behavior of the Secure BAF when an LC advancement is requested through the IVT LCConfig field?
Specifically:
Does Secure BAF wait for or expect the password at the HSE-managed password location?
Can the LC advancement still be performed without HSE firmware?
If the LC advancement is successful without HSE firmware, how is debug authentication/password verification handled in this case?
A clarification on these points would help us understand the exact password flow and Secure BAF/DCM behavior for different HSE FW configurations.
Thank you for your support.
