How to add compiler flags in VSCode
tisch
how can I add compiler flags to VSCode?
I started a example from the NXP SDK with the MCUXpressor for VSCode plugin, which works good, but I need to change some compiler settings.
For example I don't need warnings into errors or need to change the optimization for compilation.
How can I change these settings?
Thank you.
carlos_o
Hi @tisch,
Thank you for your post
The compiler Flags at MCUXpresso extension for VSCode could be edited in the CMakeLists.txt file that is located in your Project Files
You could refer to Assembler/Compiler/Linker Flags
For examples if you are using armgcc you need to use
mcux_add_armgcc_configuration(
CC "-O0"
Let me know if this information helps
%3CLINGO-SUB%20id%3D%22lingo-sub-2347172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20add%20compiler%20flags%20in%20VSCode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347172%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3Ehow%20can%20I%20add%20compiler%20flags%20to%20VSCode%3F%3C%2FP%3E%3CP%3EI%20started%20a%20example%20from%20the%20NXP%20SDK%20with%20the%20MCUXpressor%20for%20VSCode%20plugin%2C%20which%20works%20good%2C%20but%20I%20need%20to%20change%20some%20compiler%20settings.%3C%2FP%3E%3CP%3EFor%20example%20I%20don't%20need%20warnings%20into%20errors%20or%20need%20to%20change%20the%20optimization%20for%20compilation.%3C%2FP%3E%3CP%3EHow%20can%20I%20change%20these%20settings%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20How%20to%20add%20compiler%20flags%20in%20VSCode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347431%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261224%22%20target%3D%22_blank%22%3E%40tisch%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EThank%20you%20for%20your%20post%3C%2FP%3E%0A%3CP%3EThe%20compiler%20Flags%20at%20MCUXpresso%20extension%20for%20VSCode%20could%20be%20edited%20in%20the%20CMakeLists.txt%20file%20that%20is%20located%20in%20your%20Project%20Files%3C%2FP%3E%0A%3CP%3EYou%20could%20refer%20to%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fmcuxpresso.nxp.com%2Fmcuxsdk%2Flatest%2Fhtml%2Fdevelop%2Fbuild_system%2FIDE_Project.html%3F_gl%3D1*1bja8dc*_ga*NDYxMDQ4ODkwLjE3NzU2Njg5Njg.*_ga_WM5LE0KMSH*czE3NzU2Njg5NjgkbzEkZzEkdDE3NzU2NjkwMjQkajQkbDAkaDEwNDQ5NTUy%23assembler-compiler-linker-flags%22%20target%3D%22_self%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EAssembler%2FCompiler%2FLinker%20Flags%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EFor%20examples%20if%20you%20are%20using%20armgcc%20you%20need%20to%20use%26nbsp%3B%3C%2FP%3E%0A%3CP%3Emcux_add_armgcc_configuration(%3C%2FP%3E%0A%3CP%3ECC%20%22-O0%22%3C%2FP%3E%0A%3CP%3E)%3C%2FP%3E%0A%3CP%3ELet%20me%20know%20if%20this%20information%20helps%3C%2FP%3E%3C%2FLINGO-BODY%3E
