The difference is essentially this: From inside of MCUXpresso IDE you import newly generated SDK into the IDE as a plug-in into that IDE. So you cannot use your generated SDK outside of it.
If you generate your package in the builder website, you are to choose the toolchain for whatever IDE you want to use and then you import the package to that IDE manually. For ex. to use Visual Studio you should obviously use website builder and choose ARM GCC toolchain - it will create a project with cmake and you can then use Visual Studio.
Beside that , if importing inside MCUXpresso, I suggest to unzip the package so you will have freedom to use each file by cloning , copying to file system etc. (IDE help shows how to).
