USB stack check endpoint listening
1,073 次查看
martindusek
using USB stack as USB device. Is there a way to find if host awaits data on IN endpoint? I would like to know if my data will arriveto host (or at least there is a decent probability) before I call USB_DeviceSendRequest().
970 次查看
NicolasP
From my understanding, once the HID device is connected to the host, the host USB HID stack consumes all IN packets.
When an application is connected to the host USB HID stack, these packets are delivered to the application, else they are discarded.
Nicolas
