(SDK) usb MIDI device?
已解决
跳至解决方案
4,780 次查看
mmlee
Is there any chance we will get a midi device class implementation for the USB middleware?
Is it something that's in the pipeline?
1 解答
4,544 次查看
fangfang
I am afriad of the imxrt family there is not the SDK for it.
在原帖中查看解决方案
5 回复数
4,418 次查看
BetoGreen
Looks like the example is not complete....
audio_generator.c is missing, the webpage shows usb_device_descriptor.c twice.
Does anyone have the real audio_generator.c file they can post here?
4,542 次查看
ogawatakeshi
Hello
A simple example is implemented using MCUXpresso USB Stack.
Referenced projects(dev_audio_generator_bm)
modify following code
Please refer to the following article
MCUXpressoSDK USB StackでMIDIStreamingSubClassを使う2 - がれすたさんのDIY日記
(Sorry in japanese......
4,542 次查看
Pavel
NXP LSDK supports USB MIDI driver. For example see the following documents:
https://www.nxp.com/docs/en/user-guide/LS1028ABSPUG.pdf
https://www.nxp.com/files-static/soft_dev_tools/doc/support_info/QorIQ-LS1012A-SDK-v0.4.pdf?&fasp=1&...
Pavel Chubakov
4,542 次查看
mmlee
Any chance we get it to the IMXRTxx series as well?
4,545 次查看
fangfang
