MIMX8ML8 SDK optimized memcpy routine bug
487 次查看
bjoern_almqvist
I had trouble getting RPMsg-Lite to run continuously on the i.MX8M Plus Cortex-M7 (FreeRTOS, MCUXpresso SDK 2.16.000, arm-gnu-toolchain 13.3) with a 1 ms request/response cycle to Linux. After a variable number of cycles the communication froze hard and the M7 stopped servicing the incoming messages.
I added a SysTick watchdog that samples the interrupted program counter when the app stopped. During a freeze it consistently showed the M7 stuck in the size_ge_16 burst loop in fsl_memcpy.S, with the link register pointing back into rpmsg_queue_recv, inside env_memcpy(data, msg.data, msg.len) while copying a received payload out of the vring buffer.
It looks like a latent alignment bug in the optimized memcpy routine, exposed by the specific alignment of the rpmsg shared-memory buffers it’s asked to copy. (I did not isolate the exact faulty instruction.)
Swapping to the standard libc memcpy fixed it for me, i.e. changing the SDK_MISC_OVERRIDE_MEMCPY define to 0.
Is this something that is logged and fixed in later SDK versions?
1 回复
408 次查看
Manuel_Salas
Hello @bjoern_almqvist
Hope you are doing very well.
The structure of the SDK regarding to the RPMSG has not any change from that Version.
Actually, in that case it is a good and functional workaround.
RPMSG is commonly used to send flags and short messages instead of big amount of data in the buffer, then M and A cores can access to the shared memory.
Salas.
%3CLINGO-SUB%20id%3D%22lingo-sub-2377258%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMX8ML8%20SDK%20%E4%BC%98%E5%8C%96%E7%9A%84%20memcpy%20%E4%BE%8B%E7%A8%8B%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2377258%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%AE%A9%20RPMSG-Lite%20%E5%9C%A8%20i.MX8M%20Plus%20Cortex-M7%EF%BC%88FreeRTOS%E3%80%81MCUXpresso%20SDK%202.16.000%E3%80%81arm-gnu-toolchain%2013.3%EF%BC%89%E4%B8%8A%E6%8C%81%E7%BB%AD%E8%BF%90%E8%A1%8C%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E9%BA%BB%E7%83%A6%EF%BC%8C%E5%AF%B9%20Linux%20%E7%9A%84%E8%AF%B7%E6%B1%82%2F%E5%93%8D%E5%BA%94%E5%91%A8%E6%9C%9F%E4%B8%BA%201%20%E6%AF%AB%E7%A7%92%E3%80%82%E7%BB%8F%E8%BF%87%E4%B8%8D%E5%90%8C%E6%AC%A1%E6%95%B0%E7%9A%84%E5%BE%AA%E7%8E%AF%E5%90%8E%EF%BC%8C%E9%80%9A%E4%BF%A1%E4%B8%A5%E9%87%8D%E5%86%BB%E7%BB%93%EF%BC%8CM7%20%E5%81%9C%E6%AD%A2%E6%8E%A5%E6%94%B6%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%B8%80%E4%B8%AA%20SysTick%20%E7%9C%8B%E9%97%A8%E7%8B%97%EF%BC%8C%E5%9C%A8%E7%A8%8B%E5%BA%8F%E5%81%9C%E6%AD%A2%E6%97%B6%E5%AF%B9%E4%B8%AD%E6%96%AD%E7%9A%84%E7%A8%8B%E5%BA%8F%E8%AE%A1%E6%95%B0%E5%99%A8%E8%BF%9B%E8%A1%8C%E9%87%87%E6%A0%B7%E3%80%82%E5%9C%A8%E5%86%BB%E7%BB%93%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E5%AE%83%E6%8C%81%E7%BB%AD%E6%98%BE%E7%A4%BA%20M7%20%E5%81%9C%E7%95%99%E5%9C%A8%20fsl_memcpy.S%20%E7%9A%84%20size_ge_16%20burst%20%E5%BE%AA%E7%8E%AF%E4%B8%AD%EF%BC%8C%E9%93%BE%E6%8E%A5%E5%AF%84%E5%AD%98%E5%99%A8%E6%8C%87%E5%90%91%20rpmsg_queue_recv%EF%BC%8C%E5%9C%A8%20env_memcpy(data%2C%20msg.data%2C%20msg.len)%20%E4%B8%AD%EF%BC%8C%E5%90%8C%E6%97%B6%E4%BB%8E%20vring%20%E7%BC%93%E5%86%B2%E5%8C%BA%E5%A4%8D%E5%88%B6%E6%8E%A5%E6%94%B6%E5%88%B0%E7%9A%84%E6%9C%89%E6%95%88%E8%BD%BD%E8%8D%B7%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%83%8F%E6%98%AF%E4%BC%98%E5%8C%96%20memcpy%20%E4%BE%8B%E7%A8%8B%E4%B8%AD%E7%9A%84%E4%B8%80%E4%B8%AA%E6%BD%9C%E5%9C%A8%E5%AF%B9%E9%BD%90%E9%94%99%E8%AF%AF%EF%BC%8C%E5%AE%83%E8%A2%AB%E8%A6%81%E6%B1%82%E5%A4%8D%E5%88%B6%E7%9A%84%20rpmsg%20%E5%85%B1%E4%BA%AB%E5%86%85%E5%AD%98%E7%BC%93%E5%86%B2%E5%8C%BA%E7%9A%84%E7%89%B9%E5%AE%9A%E5%AF%B9%E9%BD%90%E6%96%B9%E5%BC%8F%E6%9A%B4%E9%9C%B2%E4%BA%86%E5%87%BA%E6%9D%A5%E3%80%82(%E6%88%91%E6%B2%A1%E6%9C%89%E6%89%BE%E5%87%BA%E7%A1%AE%E5%88%87%E7%9A%84%E9%94%99%E8%AF%AF%E6%8C%87%E4%BB%A4%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%8D%A2%E6%88%90%E6%A0%87%E5%87%86%20libc%20memcpy%20%E5%90%8E%EF%BC%8C%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E5%B0%B1%E8%A7%A3%E5%86%B3%E4%BA%86%EF%BC%8C%E5%8D%B3%E6%8A%8A%20SDK_MISC_OVERRIDE_MEMCPY%20%E5%AE%9A%E4%B9%89%E6%94%B9%E4%B8%BA%200%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E5%90%A6%E4%BC%9A%E5%9C%A8%E4%BB%A5%E5%90%8E%E7%9A%84%20SDK%20%E7%89%88%E6%9C%AC%E4%B8%AD%E8%A2%AB%E8%AE%B0%E5%BD%95%E5%92%8C%E4%BF%AE%E5%A4%8D%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MIMX8ML8%20SDK%20optimized%20memcpy%20routine%20bug%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F263488%22%20target%3D%22_blank%22%3E%40bjoern_almqvist%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%83%BD%E5%A5%BD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%9C%89%E5%85%B3%20RPMSG%20%E7%9A%84%20SDK%20%E7%BB%93%E6%9E%84%E4%B8%8E%E8%AF%A5%E7%89%88%E6%9C%AC%E7%9B%B8%E6%AF%94%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AE%9E%E9%99%85%E4%B8%8A%EF%BC%8C%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E5%BE%88%E5%A5%BD%E7%9A%84%E5%AE%9E%E7%94%A8%E5%8F%98%E9%80%9A%E5%8A%9E%E6%B3%95%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERPMSG%20%E9%80%9A%E5%B8%B8%E7%94%A8%E4%BA%8E%E5%8F%91%E9%80%81%E6%A0%87%E5%BF%97%E5%92%8C%E7%9F%AD%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%9C%A8%E7%BC%93%E5%86%B2%E5%8C%BA%E4%B8%AD%E5%8F%91%E9%80%81%E5%A4%A7%E9%87%8F%E6%95%B0%E6%8D%AE%EF%BC%8C%E8%BF%99%E6%A0%B7%20M%20%E6%A0%B8%E5%92%8C%20A%20%E6%A0%B8%E5%B0%B1%E5%8F%AF%E4%BB%A5%E8%AE%BF%E9%97%AE%E5%85%B1%E4%BA%AB%E5%86%85%E5%AD%98%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%90%A8%E6%8B%89%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
