KW45 noinit ram section
jiajun_cheng
Hi,nxp Expert:
I want to isolate a portion of RAM in kw45 for storing some flags. However, currently when I try to write 0xa5a5a5a5 to address 0x02000000 and then perform a soft reset, the value read from address 0x02000000 after the reset is 0. Could you please help me figure out how to ensure that the value read after the soft reset remains the same as before the reset?
KW45
Christine_Li
Hi, @jiajun_cheng
From the code side, you are right, it will clear this area.
You need to modify, and not perform any write operations to this region during startup.
Below is my suggestions:
1.remove this initialization for the retention RAM section.
or
2. You can keep those loops but skip the retention RAM range.
or
3. Ensure the initialization table does not include the retention RAM region at all.
Please let me know whether have any other concerns on this case.
Christine.
Christine_Li
Hi, @jiajun_cheng
The last 8 KB RAM (0x2001_A000) is from independent power switch domain which can keep data retention in all power modes.
For details, please refer to KW45 Reference Manual
Otherwise, please do not hesitate to mark my answer as a solution, so that we can close this case.
Christine.
jiajun_cheng
Hi, @Christine_Li :
However, I noticed this section of code again in the startup file startup_KW45B41Z83.S—doesn’t it clear the memory range from 0x2001_A000 to 0x2001_C000?
.ram_init_stcm5:
    ldr     r0, =0x2001a000
    ldr     r1, =0x2001c000
.loop5:                         /* Initialize stcm5 */
    stmia   r0!, {r2 - r5}
    cmp     r0, r1
    bcc.n   .loop5
Christine_Li
Hi, @jiajun_cheng
or
or
Christine.
Christine_Li
Hi, @jiajun_cheng
Anything else I can do for you on this case?
Christine.
%3CLINGO-SUB%20id%3D%22lingo-sub-2250923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKW45%20noinit%20ram%20section%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2Cnxp%20Expert%EF%BC%9A%3CBR%20%2F%3EI%20want%20to%20isolate%20a%20portion%20of%20RAM%20in%20kw45%20for%20storing%20some%20flags.%20However%2C%20currently%20when%20I%20try%20to%20write%200xa5a5a5a5%20to%20address%200x02000000%20and%20then%20perform%20a%20soft%20reset%2C%20the%20value%20read%20from%20address%200x02000000%20after%20the%20reset%20is%200.%20Could%20you%20please%20help%20me%20figure%20out%20how%20to%20ensure%20that%20the%20value%20read%20after%20the%20soft%20reset%20remains%20the%20same%20as%20before%20the%20reset%3F%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FKW45%2Fpd-p%2FKW45%22%20class%3D%22lia-product-mention%22%20data-product%3D%22615-1%22%20target%3D%22_blank%22%3EKW45%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2251531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20noinit%20ram%20section%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2251531%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205377%22%20target%3D%22_blank%22%3E%40Christine_Li%3C%2FA%3E%26nbsp%3B%3A%3C%2FP%3E%3CP%3E%3CSPAN%3EHowever%2C%20I%20noticed%20this%20section%20of%20code%20again%20in%20the%20startup%20file%26nbsp%3B%3C%2FSPAN%3Estartup_KW45B41Z83.S%3CSPAN%3E%E2%80%94doesn%E2%80%99t%20it%20clear%20the%20memory%20range%20from%26nbsp%3B%3C%2FSPAN%3E0x2001_A000%3CSPAN%3E%26nbsp%3Bto%26nbsp%3B%3C%2FSPAN%3E0x2001_C000%3CSPAN%3E%3F%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E.ram_init_stcm5%3A%0A%20%20%20%20ldr%20%20%20%20%20r0%2C%20%3D0x2001a000%0A%20%20%20%20ldr%20%20%20%20%20r1%2C%20%3D0x2001c000%0A.loop5%3A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%2F*%20Initialize%20stcm5%20*%2F%0A%20%20%20%20stmia%20%20%20r0!%2C%20%7Br2%20-%20r5%7D%0A%20%20%20%20cmp%20%20%20%20%20r0%2C%20r1%0A%20%20%20%20bcc.n%20%20%20.loop5%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2251114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20noinit%20ram%20section%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2251114%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241854%22%20target%3D%22_blank%22%3E%40jiajun_cheng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20last%208%20KB%20RAM%20(0x2001_A000)%20is%20from%20independent%20power%20switch%20domain%20which%20can%20keep%20data%20retention%20in%20all%20power%20modes.%3C%2FP%3E%0A%3CP%3EFor%20details%2C%20please%20refer%20to%26nbsp%3B%3CA%20id%3D%22relatedDocsClickPDF_1%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DKW45RM%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsearchresulttitle%3D%22KW45%20Reference%20Manual%22%20data-dtmsubaction%3D%22KW45%20Reference%20Manual%20-%20NXP%20-%20Reference%20Manual%20-%20English%22%20data-cl-id%3D%221853962181%22%3E%3CSPAN%3EKW45%20Reference%20Manual%3C%2FSPAN%3E%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EPlease%20let%20me%20know%20whether%20have%20any%20other%20concerns%20on%20this%20case.%3C%2FP%3E%0A%3CP%3EOtherwise%2C%20please%20do%20not%20hesitate%20to%20mark%20my%20answer%20as%20a%20solution%2C%20so%20that%20we%20can%20close%20this%20case.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KW45%20noinit%20ram%20section%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253620%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F241854%22%20target%3D%22_blank%22%3E%40jiajun_cheng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAnything%20else%20I%20can%20do%20for%20you%20on%20this%20case%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E
