Files missing from the MIMX9331 SDK
TK6223
I started writing our firmware using a development board that had a MIMX9352 SoC. Our own hardware has a MIMX9331 SoC, so I downloaded the SDK (25.09) for that chip and updated the project files to use the correct SDK. This resulted in the build failing because the following files were missing:
components/uart/component_lpuart_adapter.MIMX9331.cmake
devices/MIMX9331/all_lib_device.cmake
devices/MIMX9331/cmsis_drivers/driver_cmsis_lpi2c.MIMX9331.cmake
devices/MIMX9331/device_CMSIS.MIMX9331.cmake
devices/MIMX9331/device_startup.MIMX9331.cmake
devices/MIMX9331/device_system.MIMX9331.cmake
devices/MIMX9331/drivers/driver_cache_xcache.MIMX9331.cmake
devices/MIMX9331/drivers/driver_clock.MIMX9331.cmake
devices/MIMX9331/drivers/driver_common.MIMX9331.cmake
devices/MIMX9331/drivers/driver_iomuxc.MIMX9331.cmake
devices/MIMX9331/drivers/driver_lpi2c_edma.MIMX9331.cmake
devices/MIMX9331/drivers/driver_lpuart.MIMX9331.cmake
devices/MIMX9331/drivers/driver_memory.MIMX9331.cmake
devices/MIMX9331/drivers/driver_rgpio.MIMX9331.cmake
devices/MIMX9331/drivers/edma4/driver_edma4.MIMX9331.cmake
devices/MIMX9331/utilities/debug_console_lite/utility_assert_lite.MIMX9331.cmake
devices/MIMX9331/utilities/utilities_misc_utilities.MIMX9331.cmake
devices/MIMX9331/utilities/utility_debug_console_lite.MIMX9331.cmake
devices/MIMX9331/utilities/utility_str.MIMX9331.cmake
The SDK for the MIMX9331 contains also the MIMX9352 files under devices, and the corresponding files for the 9352 exist there. As a workaround I've manually copied the missing files from the 9352 directory and renamed them (+ fixed the contents to refer to the 9331 when necessary).
Will the missing MIMX9331 files be added in an upcoming release?
Bio_TICFSL
Please take this appnote for differences between MX91 and MX93.
https://www.nxp.com/docs/en/application-note/AN14012.pdf
TK6223
Thanks for the reply! These are both i.MX93 chips so I don't see how the MX91 would be relevant here, but please correct me if I'm wrong.
And shouldn't there at least be the all_lib_device.cmake file with the corresponding configuration for the MIMX9331? I didn't check the peripherals related to each of the missing files, but for example the driver_clock, driver_common, driver_iomuxc and driver_rgpio files definitely sound like something that should be there.
%3CLINGO-SUB%20id%3D%22lingo-sub-2174218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFiles%20missing%20from%20the%20MIMX9331%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20started%20writing%20our%20firmware%20using%20a%20development%20board%20that%20had%20a%20MIMX9352%20SoC.%20Our%20own%20hardware%20has%20a%20MIMX9331%20SoC%2C%20so%20I%20downloaded%20the%20SDK%20(25.09)%20for%20that%20chip%20and%20updated%20the%20project%20files%20to%20use%20the%20correct%20SDK.%20This%20resulted%20in%20the%20build%20failing%20because%20the%20following%20files%20were%20missing%3A%3C%2FP%3E%3CP%3Ecomponents%2Fuart%2Fcomponent_lpuart_adapter.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fall_lib_device.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fcmsis_drivers%2Fdriver_cmsis_lpi2c.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdevice_CMSIS.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdevice_startup.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdevice_system.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdrivers%2Fdriver_cache_xcache.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdrivers%2Fdriver_clock.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdrivers%2Fdriver_common.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdrivers%2Fdriver_iomuxc.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdrivers%2Fdriver_lpi2c_edma.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdrivers%2Fdriver_lpuart.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdrivers%2Fdriver_memory.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdrivers%2Fdriver_rgpio.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Fdrivers%2Fedma4%2Fdriver_edma4.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Futilities%2Fdebug_console_lite%2Futility_assert_lite.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Futilities%2Futilities_misc_utilities.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Futilities%2Futility_debug_console_lite.MIMX9331.cmake%3CBR%20%2F%3Edevices%2FMIMX9331%2Futilities%2Futility_str.MIMX9331.cmake%3C%2FP%3E%3CP%3EThe%20SDK%20for%20the%20MIMX9331%20contains%20also%20the%20MIMX9352%20files%20under%20devices%2C%20and%20the%20corresponding%20files%20for%20the%209352%20exist%20there.%20As%20a%20workaround%20I've%20manually%20copied%20the%20missing%20files%20from%20the%209352%20directory%20and%20renamed%20them%20(%2B%20fixed%20the%20contents%20to%20refer%20to%20the%209331%20when%20necessary).%3C%2FP%3E%3CP%3EWill%20the%20missing%20MIMX9331%20files%20be%20added%20in%20an%20upcoming%20release%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Files%20missing%20from%20the%20MIMX9331%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20the%20reply!%20These%20are%20both%20i.MX93%20chips%20so%20I%20don't%20see%20how%20the%20MX91%20would%20be%20relevant%20here%2C%20but%20please%20correct%20me%20if%20I'm%20wrong.%3C%2FP%3E%3CP%3EAnd%20shouldn't%20there%20at%20least%20be%20the%20all_lib_device.cmake%20file%20with%20the%20corresponding%20configuration%20for%20the%20MIMX9331%3F%20I%20didn't%20check%20the%20peripherals%20related%20to%20each%20of%20the%20missing%20files%2C%20but%20for%20example%20the%20driver_clock%2C%20driver_common%2C%20driver_iomuxc%20and%20driver_rgpio%20files%20definitely%20sound%20like%20something%20that%20should%20be%20there.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Files%20missing%20from%20the%20MIMX9331%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CP%3EPlease%20take%20this%20appnote%20for%20differences%20between%20MX91%20and%20MX93.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14012.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14012.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ERegards%3C%2FP%3E%3C%2FLINGO-BODY%3E
